* * * * * 2 votes
Tds Mk1 Rebuild Thread
156 replies to this topic
#61 TonyDevil
Posted 18 January 2010 - 07:10 pm
QUOTE(ChrisG @ Mon 18th Jan 2010, 07:07 PM) <{POST_SNAPBACK}>
He's also got previous for doing the opposite, look how happy he was with his wiring abilities biggrin.gif
if i remember rightly you were flouncing about in the kitchen while i was stripping the bike we bought for parts tongue.gif
what did it take to strip it? an hour or 2?
#62 TonyDevil
Posted 18 January 2010 - 08:23 pm
tada
http://www.facebook.com/v/257091677668
still not revving right but getting there
#63 ChrisG
Posted 18 January 2010 - 08:29 pm
Now I'm pissed off I mised that set of Pro Stocks that showed up on e-bay a few months back
#64 aircooled68
Posted 18 January 2010 - 08:37 pm
QUOTE(TonyDevil @ Mon 18th Jan 2010, 08:23 PM) <{POST_SNAPBACK}>
tada
#65 TonyDevil
Posted 18 January 2010 - 09:12 pm
QUOTE(aircooled68 @ Mon 18th Jan 2010, 08:37 PM) <{POST_SNAPBACK}>
i've changed the permissions so non-facebookers can view it
#66 aircooled68
Posted 18 January 2010 - 09:58 pm
Edited by aircooled68, 18 January 2010 - 09:58 pm.
#67 TonyDevil
Posted 19 January 2010 - 09:32 pm
if you ever need tyres and you're near Reading you could do a lot worse than head over to Ride-In Bike tyres just off the ringroad
http://www.rideinbiketyres.co.uk/
a fiver for removing tyre, fitting a new valve, refitting tyre and balancing
nothing else to report other than i have discovered 2 really nice bottles of wine
Willunga100 Grenache and Oxford landing GSM (Grenache Shiraz Mourvedre)
#68 sweep
sweep
  • 120 posts
Posted 19 January 2010 - 09:39 pm
That exhaust sounds really nice clapping.gif . I wish I had courage to do something like that. I do think the twin exhaust looks better than a single on the TDM. I once saw a ZRX with a twin ..... Looked a little unusual blink.gif .
#69 TonyDevil
Posted 20 January 2010 - 06:01 pm
put the garage creeper and seat thingy together that i got from lidl, £20 well spent! good.gif
went to fit the front wheel and noticed fork oil leak from RHS damper rod bolt
checked it and fecking thing was well loose, managed to torque it up by compressing the fork which saved me stripping them down (thnx to JHT for that tip)
will still need to change the oil tho
fitted a fender extender to the mudguard and rivetted the fecker on (lost one before despite following their instructions to stick it on dry.gif)
changed the brake fluid on the front brakes, they now feel lubberly
wondering if carb diaphrams had dried out and an overnight soaking has eased everything up? doubtfull.gif
#70 Studley Ramrod
Posted 20 January 2010 - 07:47 pm
Yaaa, I'd a thought the soaking might have freed up any gooey bits, or maybe an air lock in the carby/fuel supply freed up.
Did you charge the battery up last nite ?
Sooo, if you have a rough running mk1 the best way to fix the problem is to drink 2 ltrs of vive click 69 and it'll be fine by the time you are ! Coool cool.gif
#71 TonyDevil
Posted 20 January 2010 - 10:38 pm
i forgot to turn the fuel tap on so ended up with air in the fuel lines
it was a bitch to get running again, so now i'm wondering if its the fuel pump
and i managed to break a nozzle off my spare fuel pump by dropping it ranting.gif
if only there was a bike with a similar fuel pump close by that i could use to swap bits around....... rolleyes.gif
but that can wait for tomorrow
#72 dapleb
  • 18,386 posts
Posted 21 January 2010 - 07:47 am
Sounds loike you are just ironing out the fiddly bits now. YEAH.....new pic time?
#73 TonyDevil
Posted 21 January 2010 - 11:17 am
QUOTE(dapleb @ Thu 21st Jan 2010, 07:47 AM) <{POST_SNAPBACK}>
i'll 'borrow' the fuel pump off my XTZ tonight to confirm its the pump...
then i'm just waiting for chain adjuster & number plate to turn up for an MoT smile.gif
#74 Studley Ramrod
Posted 21 January 2010 - 01:25 pm
I've got a spare fuel pump, not been tested but I've checked it out and all looks well. PM me yer details if you want it me'owd.
Have a look here
http://www.carpe-tdm...mp;hl=fuel pump
Edited by Studley Ramrod, 21 January 2010 - 01:28 pm.
#75 TonyDevil
Posted 23 January 2010 - 01:32 pm
well i'm pretty sure its the fuel pump now
a vaccum pump thats working properly would only take 10-15secs on the starter button to get fuel to the carbs
when this ran dry i had to force fuel thru under pressure to get fuel to the carbs
number plate still hasnt arrived so wont be going for MOT today anyway sad.gif
#76 Studley Ramrod
Posted 23 January 2010 - 01:43 pm
Takes me a lot longer than 15 secs if I don't catch it on the reserve in time.
Might be worth checking the pump casing bolts are tweaked up nicely and the vac pipe is ok.
#77 TonyDevil
Posted 23 January 2010 - 02:35 pm
cheers matey, well its not the pump had that apart and its clean as a whistle
checked the pump and its running lovely now, think it may have been an issue with vaccum house
now i have a slight problem with it running rich....very rich...
as in popping farting and occasional half foot flames on the overrun.....
so....to the carbs.....
#78 TonyDevil
Posted 23 January 2010 - 05:12 pm
well they were a complete mess
whoever had em open before had managed to twist one of the floatbowl gaskets and catch one of he diaphrams when refitting which caused a tear
lucky i have lots of spares here.....
#79 dapleb
  • 18,386 posts
Posted 23 January 2010 - 05:37 pm
Hmm let me think who that might have been laugh.gif .....were the carbs the ones on there when you got it? Freddie Fokkepie is the king of servicing, first time I met him he was "adjusting" G's chain for him. After watching him belting the living foobar out of the back wheel I mentioned he might try undoing the caliper bolt....he said it didnt need to be undone for "small adjustments". laugh.gif
#80 TonyDevil
Posted 23 January 2010 - 05:46 pm
and now i've run out of carb cleaner......
