Edited by gilbert, 21 January 2009 - 03:43 pm.
Mk1 TDM850 Electric Fuel Pump Install
#61
Posted 21 January 2009 - 03:42 pm
#62
Posted 21 January 2009 - 07:30 pm
Could this one fit?
http://cgi.ebay.com/...2...A1|240:1318
or this one
http://cgi.ebay.co.u...-...A1|240:1318
Thinking on next oil change to get hands to work and do it all at once.
Thanks in advance
Oigres
Edited by Oigres, 21 January 2009 - 08:50 pm.
#63
Posted 19 May 2009 - 07:46 pm
Could this one fit?
or this one
Thanks in advance
Oigres
Hi guys ... new to the forum and TDMs but I think my problem is in here somewhere ... Just bought an early MK1 TDM. It started when I got it ... ran for a few minutes and put it in the garage ... Next day it wouldn't start. Good spark and plenty of petrol.... now I read bits about a fuel pump ... is this my prob and can it be fixed... any advice accepted .. Cheetrs Iain.
#64
Posted 19 May 2009 - 09:09 pm
Bought the sucker but havent installed it yet, only at the end of summer. She only complains in the winter time so no need to mode it now.
Somebody will help ya soon i betcha.
Behave
Oigres
#65
Posted 19 May 2009 - 10:25 pm
Before you go to all the trouble of changing out a fuel pump I have two words... Dirty Petrol.
Drain that tank dry (and your carb float bowls too) run carb cleaner thru it when you get it started.
Your carbs may be varnished from the old fuel.
#66
Posted 20 May 2009 - 09:33 am
What a difference a day makes ... Went out this morning ... wouldn't start .... stripped off the tank and seat ... located the pump ... took it off.... looked at it ... looked at it again ... turned the key .... and low and behold ... the bitch started ... Will drain the system and replace petrol ... and keep the fingers crossed ... Cheers Iain
#67
Posted 13 March 2010 - 11:07 pm
Before I start this mod, can anyone clarify which fuel pump is better to use - the R1, or R6? Also, I need to get a fuel pump from a NON fuel-injected R1/R6, correct?
What relay are you guys using? Are you buying a Yamaha OEM relay? If so, does anyone have a part number.
Sorry to be a sticklet, but if I'm going to do this, I want to do it right! Thanks.
#68
Guest_LDRider_*
Posted 14 March 2010 - 12:04 am
Definitely need a non-FI pump - I don't know if R1 or R6 is better; they might be the same anyway.
#69
Posted 14 March 2010 - 12:46 am
I haven't been able to locate a pump on eBay, but I called the local dealer, and was told that a NON-fuel injected R1 fuel pump is $298. Yikes.
#70
Guest_LDRider_*
Posted 14 March 2010 - 01:20 am
http://cgi.ebay.com/...=item5ad79cf2e7
#71
Posted 14 March 2010 - 01:36 am
Hmm....never bought anything on eBay overseas. I might give it a go. I'd wonder if it comes with all the parts, as I'd no idea what to look for on a used fuel pump.
#72
Posted 14 March 2010 - 09:10 am
Thoughts?
#73
Posted 14 March 2010 - 09:16 am
One's the vacuum feed, which you need to plug.
#74
Posted 15 April 2010 - 07:30 pm
#75
Posted 25 April 2010 - 07:17 am
Fusebox
Pump fitted
You can see the extra relay on the left in this photo
More photos here
http://www.flickr.co...s/47339542@N08/
Edited by hammerman, 25 April 2010 - 07:28 am.
#76
Posted 08 September 2010 - 03:35 pm
2 dopey q's.....
Which side does the filter that is attched to one of the pipes go (before pump or after)
Has a connector with black and black/blue wires. I'll put a battery on it later to test it works, but when it comes to the actual fitting, are these the same colours that other have come across on theirs? If so, which is the live and which is the earth?
#77
Posted 08 September 2010 - 04:53 pm
Black/blue=Live
Black= ? have a guess
ermmmm, did you read the first post, only you might have missed a bit if ya did
#78
Posted 08 September 2010 - 07:27 pm
.....'course I read it.....sort of.....
like most things, I 'sort of' speed read it.....or....looked at the pictures!!
Cheers mate
#79
Posted 16 October 2010 - 04:01 pm
Cheers mate
pete
maybe you could give me a hand fit 2 of em shud be easy but i hate elctrical shite !!!!
my bikes include
yamaha xt600 tenere 3aj 1989
yamaha xtz750 supertenere 1991
yamaha tdm850 1991 hillclimb bike heavily modified
honda cb400t 1978 dream mint condition 12k miles from new
yamaha trx850 streetfighter project
keep it off the tarmac and in the green
#80
Posted 20 June 2011 - 10:00 pm
thanks for the help!
