TDM850 engine modifications
71 replies to this topic
#61 tdm850rider
Posted 17 January 2007 - 11:27 pm
For those of us in the States who were screwed out of any TDM from 1994 on...... ranting.gif
Can it be done on a Mk1? Lots of life left in my Mk1 but I want to look towards the future.
#62 wicklamulla
Posted 18 January 2007 - 01:20 am
QUOTE(tdm850rider @ Wed 17th Jan 2007, 11:12 PM) <{POST_SNAPBACK}>
yes Tom it can be done to yer MKI, even XTZ 750's can have it done apparently.
#63 rick900
rick900
  • 1 posts
Posted 08 February 2007 - 07:20 pm
QUOTE(wicklamulla @ Thu 18th Jan 2007, 03:05 AM) <{POST_SNAPBACK}>
Hi Guys,
Rick here, yep a 750 plus the 900 barrels give 850cc approx.
It was nice to see all my work put to good use.
I was going to increase the comp ratio some more, as it ran on cheap petrol with no pinking, and i had just put some V2 cams in.
I am only visiting as a nostalgia trip , as the final development work never got done as some thieving scum nicked the bike last May.
I couldn't go through all the work again, so got a KTM 950 which is very.nice, but I would still swop it for my nicked bike, it was so nicely made for me.
Will keep poppping in now and again
#64 Johnfrmcal
Johnfrmcal
  • 18 posts
Posted 09 February 2007 - 10:07 pm
QUOTE(rick900 @ Thu 8th Feb 2007, 11:05 AM) <{POST_SNAPBACK}>
Hi Guys,
So were all the details and measurements ever posted up anywhere? I want to start collecting the parts for one of my bikes. As was mentioned earlier, we don't have any options in the US but to keep our old ones running. I've ridden the WeeStrom, the Tiger, the Gran Canyon, Multistrada, etc...all the adventure bikes available to us, and even though many of them are more "modern" and have more conveniences, none of them are as fun to me as my TDM...
#65 wicklamulla
Posted 10 February 2007 - 02:16 am
i wonder why it will give 850cc approx and not 900cc ???? shorter stroke or ???
#66 dapleb
  • 18,388 posts
Posted 10 February 2007 - 09:11 am
QUOTE(wicklamulla @ Sat 10th Feb 2007, 02:01 AM) <{POST_SNAPBACK}>
shorter stroke
Yes
#67 wicklamulla
Posted 19 February 2007 - 09:46 pm
QUOTE(rick900 @ Thu 8th Feb 2007, 07:05 PM) <{POST_SNAPBACK}>
Hi Guys,
Rick didya ever get either of those XTZ's back ?? got any pics of yer former beauties fer us to ogle ??? regards WiCkY
#68 jht
Posted 19 February 2007 - 10:51 pm
Attached File  yamaha_trx_850_eric_img01.jpg   59.51KB   44 downloads
Edited by jht, 19 February 2007 - 10:53 pm.
#69 wicklamulla
Posted 20 February 2007 - 09:49 am
OMG thats beautiful !!!!!!!!!!! wonder if it burns oil..........
#70 anda3243
anda3243
  • 89 posts
Posted 28 May 2011 - 09:44 am
QUOTE(Emmett @ Wed 29th Nov 2006, 11:33 PM) <{POST_SNAPBACK}>
So.....................................................my '98 model burns some oil, more oil than petrol, well not quite, but enough to pish me right off. I also wouldn't mind a bit more power, without sacrificing reliability. The general consensus is that the steel liners matched with ally pistons cause the excessive oil consumption, and we all know theres no substitute for cubes, soooooo, I (with the assistance of a Yamaha mechanic friend, that is a friend who is a Yamaha mechanic and not a Yamaha mechanics friend) am in the process of putting TDM900 pistons and barrels onto my 850.
So far the engine is out, the head and barrels are off and the con rods are out. The 900 barrels are definitely a straight fit, but the900 has lower compression, so to offset that I (we) have decided to skim 0.4ml off the head. Which according to Jimmys(my mechanic friend) calculations should raise compression to about 10.8-1. The only other complication is the con rod small end eye needs to be 1mm larger diameter, which could be reamed out, but I have 900 con rods which will go straight in, so I'm gonna use them.
The compression issue has been raised before on a TRX owners site, and rick, who did the conversion, decided to skim the top of the pistons and the bottom of the barrels to remove the concave surface of the piston, and increase the compression. We have decided to skim the head, as it is easier than skimming the bottom of the barrels, the liners protrude so machining around them could be costly. I also have a spare head, so if it doesn't work out, I can undo anything and use ricks method.
So far I havent machined or skimmed anything, but all the bits are apart and the measurements are done, so if anyone knows of any reason these two things shouldn't be together, let them speak now, or forever hold their peace(or piece, I'm not sure)
I will keep you updated, but the whole job should be finished by next week..................I hope.
Sorry, you have to sign into the TRX forum to view it, but it's well worth a read, so sign up.
So you used the 900 barrels with the 850 cylinder head and 850 crankcase/gearbox? What camchain tensioners/sliders did you use?
#71 dandywarhol
Posted 28 May 2011 - 12:53 pm
QUOTE(anda3243 @ Sat 28th May 2011, 10:44 AM) <{POST_SNAPBACK}>
Emmett's rarely on the site these days - he used the 900 tensioner and guides from memory.
#72 anda3243
anda3243
  • 89 posts
Posted 29 May 2011 - 08:32 pm
QUOTE(dandywarhol @ Sat 28th May 2011, 02:53 PM) <{POST_SNAPBACK}>
ok, thanks
