Edited by wicklamulla, 22 December 2006 - 02:34 pm.
Vario Screen Winglet
#61
Posted 22 December 2006 - 02:34 pm
#62
Posted 27 December 2006 - 04:09 pm
#63
Posted 27 December 2006 - 07:06 pm
#64
Posted 27 December 2006 - 11:06 pm
just got me oxford grips today for 29.99 at Heil Gerike and hopefully (weather dependant) will be fitting those tomorrow.
#65
Posted 27 December 2006 - 11:31 pm
#66
Posted 28 December 2006 - 08:52 am
No problem with the two adrresses.
Yours arrived as well Danceswithmopeds.
That's just three cheques left floating in the ether.
Edited by Andy K, 28 December 2006 - 08:56 am.
#67
Posted 28 December 2006 - 10:28 am
Oops, and one of them is mine
Will try to getit in the post later on today!!
Fluteplayer
(\__/)
(")0(")
This is Bunny. Copy and paste Bunny into your signature to help her gain world domination
#68
Posted 28 December 2006 - 12:00 pm
But not surprisingly no check, no wing.
Edited by Andy K, 28 December 2006 - 12:00 pm.
#69
Posted 28 December 2006 - 12:20 pm
Cheque is now in the post!!!
Sorry, completely forgot, wiv all the Xmas cheer
Fluteplayer
(\__/)
(")0(")
#70
Posted 30 December 2006 - 09:03 am
Well padded package, proudly carrying a Carpe label - excellent stuff!
Here again are the fitting instructions for anyone who's lost them.
The German notes with the winglet don't seem to add much - my rough translation (Feel free to correct) goes like:
1 Place the winglet centrally and fix e.g. with adhesive tape.
2 Since the hinge mounts are angled, care must be taken to offset the position of the holes. It is advised to use the outer edges of the mounts to set the positions. In that way the offsets can be kept in line. See sketch below.
3 Check: the distance between the marked mounting points on either side should be 40 mm.
4 When drilling the holes, a wood bit (with central point) should be used. Drill the screen with little pressure.
Will scan notes and diagram - see later posting
Edited by Pict, 30 December 2006 - 10:39 am.
#71
Posted 30 December 2006 - 09:29 am
Cheers Pict
Do any one want a second hand brain (not good for much)! I had planned to include a copy of the instructions with each one. Durrr.
I will stick them in with the rest.
On that point do not worry if you have not received yours yet I posted Pict's first to check the postage, the rest will go out soon.
If anyone else wants one I have a couple of extras to hand, so don't be shy.
#72
Posted 30 December 2006 - 09:52 am
ie The view is of one side from above or below (Confused me at first)
Winglet002.jpg 55.1KB
35 downloads
Edited by Pict, 30 December 2006 - 10:45 am.
#73
Posted 30 December 2006 - 10:51 am
I can not advise to strongly that you use as little pressure as possible and make sure that you have a sacrificial piece of wood pressed firmly to the back of the screen to prevent cracking as the drill bit emerges.
You may find you get a cleaner hole if you start off with a small pilot hole then drill the proper size only part way through before turning the screen over an finishing off from the other side.
#74
Posted 30 December 2006 - 04:28 pm
I did wonder when i read that post
#75
Posted 02 January 2007 - 04:11 pm
I finally staggered down to the Post Office
- Pict Posted 02/01/07
- Wick Posted 02/01/07
- TDMTim Posted 02/01/07
- amarko5 Posted 02/01/07
- Danceswithmopeds Posted 02/01/07
- Kpnuts Posted 02/01/07
- Lerk Posted 02/01/07
- Techy-V Posted 04/01/07
- BwfcDave1 Posted 04/01/07
Edited by Andy K, 17 January 2007 - 09:01 am.
#76
Posted 02 January 2007 - 06:19 pm
- Pict Posted
- Wick Posted
- TDMTim Posted
- amarko5 Posted
- Kpnuts Posted
- Lerk Posted
- Fluteplayer
- Techy-V
- BwfcDave1
he he he tanks alot Andy, yer sooooooooo polite and modest about it all, if twas me i'd be bitching like a ho and moaning about all the cello tape i was using !!!! tanks again, much appreciated.
#77
Posted 03 January 2007 - 09:05 pm
- Pict Posted
- Wick Posted
- TDMTim Posted
- amarko5 Posted
- Kpnuts Posted
- Lerk Posted
- Fluteplayer
- Techy-V
- BwfcDave1
Much apreciated.. screen arrived today. Thankyou very much for your hard work. Do they give out CARPE medals to those who serve well???
thanks again.. Now to review the best of screen combinations again.
#78
Posted 03 January 2007 - 09:07 pm
#79
Posted 03 January 2007 - 09:17 pm
me too thanks Andy very well packaged and fast service
#80
Posted 03 January 2007 - 09:19 pm
Ach - ye're just menthol!
