Very Stuck Swingarm Bolt _ Drz400
113 replies to this topic
#61 dapleb
  • 18,399 posts
Posted 29 July 2023 - 09:40 pm
Thought I'd best just check Dave over since last MOT/use was 2018!!
Installed new battery, did pre flight checks and he fired right up!! Rode around in circles on tut yard...musta been windy on the yard as me eyes started watering. 乁⁠(⁠ ⁠⁠_⁠⁠ ⁠)⁠ㄏ
Anyyyways. Other than fuel pish from carb overflow, all ok. Soft wrap on carb didnt fixy, guess need a rebuild kit as there used to be 100s of cheap drz mankini carbs on ebay (as lots swapped for fcrs)...not any more.
Looking forward to finding time for fix n pootle.
#62 dablik
Posted 30 July 2023 - 08:44 am
Where's the time go daps, managed a couple of hours yesterday, between work/weather and hols, specially weather, 1st time out in a month, sure Dave will enjoy it  :good:
#63 dapleb
  • 18,399 posts
Posted 31 July 2023 - 07:02 pm
Good skills dabbers. Aint done any boiking this year.
Bagsied the last genuine mankini carb rebuild kit from Holland of all places. Might get it done by next year.
#64 dablik
Posted 01 August 2023 - 03:30 pm
Yep, reckon you have enough on yer plate right now, Dave will still love you.
#65 dapleb
  • 18,399 posts
Posted 08 August 2023 - 12:21 pm
Carb rebuild kit ear....not in the same county as the carbs though. ರ⁠_⁠ರ
Having a read ooop on carb cleaning. In the absence of an ultrasonic cleaner oi may try hot/boiling water.
Tishabelle has aviation engineering grade cleaning equipment at work.... but not sure my old skanky carbs would be welcome. ʘ⁠‿⁠ʘ
I seem to be the last durzzz and TDM carpedian standing with my mates spongey, Pa Larkin and wicky gone.
#66 leehenty
  • 5,326 posts
Posted 09 August 2023 - 08:30 pm
Dappers I have a big heated ultrasonic tank I got from Wicky, and the right solution for carbs. Youre welcome to either pop up and use it or put them in a box and post them. Ill do them and return.
#67 dapleb
  • 18,399 posts
Posted 09 August 2023 - 09:08 pm
Thanks LH. I may well take ya up on that. Might take a few weeks ish to gerrum off and dismantle. ♪⁠┌⁠|⁠∵⁠|⁠┘⁠♪
#68 Studley Ramrod
  • 19,373 posts
Posted 14 August 2023 - 05:17 am
:giveusahug:
#69 dapleb
  • 18,399 posts
Posted 14 August 2023 - 12:19 pm
Apw is custodian of pa's durrrz, jist not sure if he still has tDm
#70 dapleb
  • 18,399 posts
Posted 21 August 2023 - 07:50 pm
Carb off. Very stuck boat foal screws. JIS #2 wouldnt get em. Hot water and centre punch did.
There is a solenoid type thing stuck on the side of the carbs.... wondering if that might not like being dunked in ultrasonic?
Some time to dismantle now required.
#71 Catteeclan
  • 2,577 posts
Posted 22 August 2023 - 06:09 am
Prob best take it off to be on the safe side.
#72 dapleb
  • 18,399 posts
Posted 22 August 2023 - 05:55 pm
Thanks catte...i was trying to avoid more marshmallow screws but reckon ewe is right.
#73 Catteeclan
  • 2,577 posts
Posted 23 August 2023 - 05:34 am
I had a drz some years ago but can't remember a leccy lump on the side. Doesn't take me to long to forget things :lol:
I'm guessing throttle position switch?
#74 Studley Ramrod
  • 19,373 posts
Posted 23 August 2023 - 12:03 pm
Good skills Daps :)
#75 dapleb
  • 18,399 posts
Posted 23 August 2023 - 06:31 pm
TPS on dare too Catte.
I managed to undo the solenoid location screw...also arse biscuits toight!!!
It dont come ooot all the way. Is located in boat foal, so guess some electrickery fool cut off magic!!??
Ahh its a solenoid that limits vacuum and hence dampens throttle response... sounds loike that can go in the bin!
Attached File  Screenshot_20230823-192554.png   847.69KB   0 downloads
#76 Catteeclan
  • 2,577 posts
Posted 24 August 2023 - 05:57 am
Over complicated crap, don't remember that on mine. At least that'll come off with the float bowl.
Thinking about it I'm pretty sure mine had a flat side on it.
#77 Studley Ramrod
  • 19,373 posts
Posted 24 August 2023 - 12:33 pm
I agrozzle :D  Deffo worth a try chief :good:
#78 dapleb
  • 18,399 posts
Posted 24 August 2023 - 08:08 pm
Thanks chaps. FCRs the way to go i think. Used to be able to pick up a nearly new Mikuni fur £35/40 as everyone had taken them off from new and fitted FCRs... now even mikuni juans are £100+!!!! FCRs must be helluva lot more now.
Think oil trial none solenoid. Had a read and just need to block up some 'oles is all.
Have asked LH if it can visit him for a bath when nekked!
#79 Catteeclan
  • 2,577 posts
Posted 25 August 2023 - 06:02 am
Those solenoids are normally just push fit on O rings so after all this time will be tight.
#80 dapleb
  • 18,399 posts
Posted 25 August 2023 - 12:20 pm
Yeah. I didn't try to hard as wasnt sure what it was or where it went. Its just sat on a casting below the boat foal and has a grrt big nut on t'other side which should release it all and then has a poipe (also destination bin) that goes to top of carb to dia fra. Diaphrg. Rubber sheet thing. Allows air (which it gets from a separate air box poipe (yup bin)) into top to reduce vacuum in first three gears.
