* * * - - 2 votes
Midsummer Misfire.....help Needed : (
154 replies to this topic
#61 wigwamclan
wigwamclan
  • 200 posts
Posted 03 August 2016 - 08:07 pm
I'll do it now :)
#62 wigwamclan
wigwamclan
  • 200 posts
Posted 05 August 2016 - 11:35 am
so, I fitted the new air filter, shorted the disconnected wires for 30 seconds, left the battery disconnected over night an' tried it this morning.......no change : (
#63 Studley Ramrod
Posted 05 August 2016 - 02:35 pm
So is it running rough at low revs and fine at mid to high revs ?
#64 wigwamclan
wigwamclan
  • 200 posts
Posted 05 August 2016 - 03:54 pm
it'll start, tick over an' pick up ok......if I try hand hold the rpm at around 2500 there's a li'l bit of hunting but if I open the tap full, instead of it pulling like a train which is what it used to do, it bogs down i.e. it very slowly picks up to around 3500-4000 at which point it picks up like a good 'un.
When i give it full beans, If I back off a touch as it starts to bog down it'll pick up ok also if i don't give it full beans it pulls smooth....there's noticable hesitation (feels a bit like a flat spot) at around the 4000 mark..it's not right but it's usable.
The real issue is when I try to pull out from behind someone to over take quickly, an' there's a truck coming the other way an' nothing happens : (
#65 wigwamclan
wigwamclan
  • 200 posts
Posted 05 August 2016 - 05:12 pm
Attached File  IMAG0097.jpg   108.32KB   0 downloads
Just pulled the plugs
#66 Studley Ramrod
Posted 05 August 2016 - 05:23 pm
Wonder if it could be a sticking CSM or a blocked air filter ?  Looks like it's running rich.
#67 wigwamclan
wigwamclan
  • 200 posts
Posted 05 August 2016 - 05:27 pm
Air filter's brand new this morning....what's the CSM?
#68 Studley Ramrod
Posted 05 August 2016 - 06:34 pm
The cold start mechanism.
#69 Catteeclan
  • 2,567 posts
Posted 05 August 2016 - 06:54 pm
Does the manual call this a cold start mec?
All it does is hold the revs up, mixture is controlled by the ecu.
#70 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 05 August 2016 - 06:56 pm
TPS or ECU+fueling or timing.
The clue is in the engines reluctance to pull through on a wide open throttle - very un-TDM and then there is the good behaviour at the bottom and top end of the range to take into account.
Also, I'd add
Given that it was "running normally", then on later inspection you found any number of glaringly bad faults in the wiring, battery and HT circuits that would have otherwise knobbled any other self respecting 900, do you think that there may be some other detail that you are overlooking or choosing to ignore?
I'm not a 900 owner, so I'll shaddup now.
Edited by TYREDNGRUMPEE, 05 August 2016 - 07:49 pm.
#71 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 05 August 2016 - 08:27 pm
Thinks.
40k?
Do you know for sure that the valve clearances have been checked properly?
100 bucks on TIGHT valve clearances.  :pimp: - hence the sudden unexpected, but now regular, warm engine foibles.
Edited by TYREDNGRUMPEE, 05 August 2016 - 08:38 pm.
#72 Studley Ramrod
Posted 06 August 2016 - 07:01 am
What d'ya call a deer with no eyes ?  No idea.
I was kinda equating the CSM with the choke mech on a carbed bike tbh.
#73 wigwamclan
wigwamclan
  • 200 posts
Posted 06 August 2016 - 11:11 am
Thinks.
40k?
There's a bunch of receipts for work done, including ones for shims, plus it makes quite a bit of rattle noise so my guess would be that it's been done :dunno:
#74 wigwamclan
wigwamclan
  • 200 posts
Posted 07 August 2016 - 12:43 pm
just had the plugs out and tried the coils with the OBD but I got no spark on either plug.......am I doing something wrong?
#75 Studley Ramrod
Posted 07 August 2016 - 12:44 pm
Are you earthing the plug ?
#76 wigwamclan
wigwamclan
  • 200 posts
Posted 07 August 2016 - 12:46 pm
Tried earthing it to the exhaust and the engine mount bolts too..... No sparking on either :)
#77 Studley Ramrod
Posted 07 August 2016 - 12:51 pm
Hmmm, should get a spark if it's earthed properly. Is it possible to get the wires to the coil crossed ?  What's an OBD ?
#78 wigwamclan
wigwamclan
  • 200 posts
Posted 07 August 2016 - 01:15 pm
Sorted it...... I was just flicking the start switch instead of holding it on... Sparks look weak tho
#79 wigwamclan
wigwamclan
  • 200 posts
Posted 07 August 2016 - 02:55 pm
On Board Diagnostics : )
#80 wigwamclan
wigwamclan
  • 200 posts
Posted 07 August 2016 - 07:14 pm
found a discrepancy in the temp sensors.....both coolant temp and air intake temp are reading way above what actual temps are!
Any ideas why?
BTW, when I unplug the sensors they both give a OBD reading of -22......is this normal?
Edited by wigwamclan, 07 August 2016 - 07:17 pm.
