Anyone got an option on these PLEASE.
regards,
Mick
hi mick.
I just fitted XTZ12 handguards two days ago.
Ibought all the bits from
http://www.cyclepart...com/default.asp in Texas for $68 US landed here in Queensland at my door.
I used aftermarket barend weights which were predrilled and tapped for an M6 bolt.
I put a rubber washer in between the barend and the handguard to stop rotation and used 20mm sections of compression spring with an outside diameter of 8mm and wire thickness of 1mm to bush between the M6 bolt and the M8 sized hole in the handguards outer alloy spigot.
all fitted and feels solid.
roll on winter .
cheers
fung
try this
http://www.trx850.co...d...6&mode=view
Edited by fung, 18 March 2012 - 04:43 am.
