Time To Crack On!
294 replies to this topic
#61 Nog
Nog
  • 527 posts
Posted 28 November 2017 - 10:09 am
Item circled, in red. Im missing one in one of the forks. I just remembered since the last rebuild I did. I had to get them built up so I could ride it home from work. I reckon its something important, else why would it be there? Searched high and low, cant find them. Anyone got one knocking about? Haha
Not sure if the 850 forks are vastly different to the 9er but that looks like the "oil lock piece".
#62 Studley Ramrod
Posted 28 November 2017 - 10:34 am
Fowlups call it a Spindle, Taper   https://www.fowlersp...ew/3VD-23173-00  available on back order or one on ebay
https://www.ebay.co....00/182915734532
Heinz manuel calls it a Damper rod seat.
#63 dapleb
  • 18,382 posts
Posted 28 November 2017 - 10:37 am
Interesting eBay pics 8&9 show a plastic bit!! Cant remember ever seeing that bit!
#64 Studley Ramrod
Posted 28 November 2017 - 10:42 am
Hmmm, so it does.
#65 Talltom87
Talltom87
  • 381 posts
Posted 28 November 2017 - 10:57 am
Thank you, Ive just been searching the part number, theres one left in cmsnl. None in wemoto. I keep forgetting about Fowlers and cmc.
#66 Bjørge
  • 1,894 posts
Posted 28 November 2017 - 01:29 pm
Me neither ....
#67 dablik
  • 10,892 posts
Posted 28 November 2017 - 03:58 pm
Did you pull them apart okay Tom after ya weetabix, or did you have to devise a cunning plan !!
#68 Talltom87
Talltom87
  • 381 posts
Posted 28 November 2017 - 06:25 pm
How did you know I had weetabix!? Haha
I did them a few month back, one side came apart really easy. It was the side with the collar in. The other side I had to use an air gun and a long thin bar, modified to press against the bottom part inside to stop it spinning. Was a bugger I tell ya. But, like I said, they had to be put back together and will have to do them again soon. When o have the new collar and seals etc.
The engine was quite easy after I got all the bolts out. And covered in excess oil left in the tank! Haha
#69 dablik
  • 10,892 posts
Posted 29 November 2017 - 08:57 am
I mean actually seperating the stantion from the lower cos the bushes can ride up and jam making life a bit awkward, i guess you did'nt have that problem by the sound of it.
#70 Talltom87
Talltom87
  • 381 posts
Posted 29 November 2017 - 09:09 am
I just used the stanction as a slide hammer, with the body in the vice. Wasnt too strenuous, but it took some pulling.
#71 dandywarhol
Posted 29 November 2017 - 12:38 pm
A gentle hand action does the job - don't yank to fast or you'll ride up the bush in no time, we all remember our first time.........................  :pimp:
#72 dablik
  • 10,892 posts
Posted 29 November 2017 - 05:50 pm
Think i'll take em into work in that case, i know a few Stroke nurses :)
#73 Studley Ramrod
Posted 29 November 2017 - 07:01 pm
If ya do, we need pics. :)
#74 dablik
  • 10,892 posts
Posted 30 November 2017 - 09:06 am
Be careful wot you wish for,  might get one of Matron ;)
#75 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 30 November 2017 - 03:30 pm
You know you want itAttached File  matron.gif   26.86KB   1 downloads
#76 Talltom87
Talltom87
  • 381 posts
Posted 01 December 2017 - 07:27 pm
Today I ordered some paint for the frame, led indicators and relay. I went to B&Q and brought myself a cord drill and grinder for £35 for the pair. They didnt have the drill bits or grinder bits I needed, neither did Aldi special buys, so Ill be after some tomorrow when I have the car. Hope to post some more updates tomorrow!!
#77 Talltom87
Talltom87
  • 381 posts
Posted 02 December 2017 - 05:29 pm
Bought the bits for the grinder I needed today, from jtf. Unfortunately, they didnt last very long before the wire brush parts started to fall apart and penetrate my clothes! Haha Ive cleaned all the paint off the outside of the frame, just the inside and the steering head to do, oh and engine. Looks really nice without paint!
#78 Studley Ramrod
Posted 02 December 2017 - 05:40 pm
Don't use the wire brush on the engine matey, small shards of steel wire will stick in the alloy and then go rusty after you've painted it and been out for a ride in the rain.  Proper brass wire wheels are what you need, just be sure they're not the brass coated steel wire wheels.  Or you can just hand sand it down with wet n dry.
#79 Talltom87
Talltom87
  • 381 posts
Posted 02 December 2017 - 06:06 pm
Good job I havent used it on there yet, thanks sir! I need a new bottom shocker bolt, I had to grind it off. Even though I only greased it last year! Haha
#80 Talltom87
Talltom87
  • 381 posts
Posted 03 December 2017 - 04:07 pm
So, today I played football so havent had chance to work on the bugger. I finish work at 2 all next week, so Ill be working on it everyday at home or at work when I need to weld parts on (youll see!).
Ive been thinking about the end date, hopefully end of January, should I go and get it dynod or trust reading the factory pro carb set up that studley has mentioned a few times, and leave it?
How much would a tune up on the dyno be? Ish?
