I Admit Defeat With My 3Vd
110 replies to this topic
#61 dapleb
  • 18,382 posts
Posted 16 March 2023 - 09:00 pm
Was there a windy thing in one of the box of bits you gave me dabbers?
If it does turn out to be a generator issue and fixitsan can't find his, have a hunt around the knowledgebase on here.  Someone (probably MarkyMark, Celtic Biker or Matlock) found somewhere that would rewind them when they failed on high mileage 900's
I think that was robin seem to rember he stopped a long time ago, though there are a few places that will do'em.
#62 Rallyist
Posted 17 March 2023 - 10:24 am
New here https://www.electrex...000_XV1100.html
#63 hallrob1
hallrob1
  • 1,112 posts
Posted 17 March 2023 - 10:27 am
I'm not sure it was me, I did have it replaced on my old niner but that was quite a while ago - I've checked and cant find any mails
This place is still going and advertising in the press (inc the VJMC)
https://www.rexs-speedshop.com/
#64 dapleb
  • 18,382 posts
Posted 17 March 2023 - 10:32 am
Not you wobin. This was an udder juan who had a stator rewinding gig....did a lot of stuff for bentley boys.
#65 hallrob1
hallrob1
  • 1,112 posts
Posted 17 March 2023 - 10:43 am
Ah - I thought you meant a member of my name.
Now you mention it he does sound familiar.
#66 dablik
  • 10,892 posts
Posted 17 March 2023 - 02:42 pm
Crikey daps, that was aaaaaageeeees ago  :) cant remember, i'll have a look in me box, that's the only place it would be if i have it, just in from the Brecons so i'll have a look inabit.
#67 Grendel
Grendel
  • 232 posts
Posted 17 March 2023 - 04:33 pm
WEMOTO have the Electrex one with new gaskit for just over £108 delivered so makes more sense to buy new since other option was getting it rebuilt but was £150 upward.
Must admit its the only part of electrics that hasn't been replaced so better be the problem :rotflmmfao:
Edited by Grendel, 17 March 2023 - 04:40 pm.
#68 fixitsan
  • 4,850 posts
Posted 17 March 2023 - 05:12 pm
All symptoms point to it now, low revs = low voltage = electronic ignition won't operate.
Same fault my 900 had when I got it, except it was intermittent at first.
#69 dablik
  • 10,892 posts
Posted 20 March 2023 - 10:06 am
Nope cant find it, could be amongst all your collection now daps.
#70 dapleb
  • 18,382 posts
Posted 20 March 2023 - 10:09 am
Ages ago indeed dabs..a year!!
Havent had time (even down to one job) to dig through stuff. I know I have a few but dunno if ok or not. Sounds like op gonna get new juan anyways maybe?
#71 dablik
  • 10,892 posts
Posted 21 March 2023 - 09:02 am
Well if you come across it sometime, it's not got the 3 wire connected but the wires may well be with it, took it abroad on the 9r in case i needed a quick swap. If i should come across it i'll let you know, save you a search.
#72 Grendel
Grendel
  • 232 posts
Posted 11 June 2023 - 11:24 am
Generator finally fitted and seems to be charging and not going below 12v with headlights and indicators on start up.
BUT ITS STILL FUCKED!
Starts rough with misfire on one cyclinder then clears  then after 10-20 min goes back to misfire. :rant:
Seems one step forward 10 back with this fecking bike :rant:
ONLY thing electrical NOT changed is the ECU now. :rant:
List so far:
Full carbs rebuild twice.
New fuel pump.
New regulator/rectifier.
New ignition coil
New battery
New plugs.
Valve clearance checked and adjusted.
New shims
New Stator/Charger
New fuses
#73 fixitsan
  • 4,850 posts
Posted 11 June 2023 - 09:44 pm
Have you opened every electrical connector, checked for any corrosion, and sprayed with a contact cleaner before remaking ?
#74 Grendel
Grendel
  • 232 posts
Posted 12 June 2023 - 04:57 am
Yep done that made no difference.
Going to fit another CDI unit in the hope thats the cause :isurrender:
Edited by Grendel, 12 June 2023 - 04:58 am.
#75 Rallyist
Posted 12 June 2023 - 08:05 am
I had an intermittent misfire on my old 900 tried everything it turned out to be a tiny broken spring inside the plug cap  :good:
Edited by Rallyist, 12 June 2023 - 08:06 am.
#76 fixitsan
  • 4,850 posts
Posted 12 June 2023 - 09:31 pm
It's a good shout
#77 Grendel
Grendel
  • 232 posts
Posted 24 June 2023 - 01:24 pm
Fitted CDI unit from dablik :unsure2:
So far no misfire and its charging properly :yahoo:
Haven't given it a good run yet since MOT ran out in March so maiden voyage will be to MOT station. :wacko:
THEN hopefully now EVERTHING has been changed i'll finally have a reliable bike i can start to enjoy for first time in 3 years  :rotflmmfao:
Edited by Grendel, 24 June 2023 - 01:26 pm.
#78 Snowbird
Posted 24 June 2023 - 01:26 pm
Hopefully you've finally found the gremlin. :good:
#79 Grendel
Grendel
  • 232 posts
Posted 24 June 2023 - 01:44 pm
If not, I’m filing for PTSD caused by this bloody bike. :blink: :wacko:
Edited by Grendel, 24 June 2023 - 01:44 pm.
#80 Grendel
Grendel
  • 232 posts
Posted 29 June 2023 - 10:16 am
Passed MOT and Finally seems to be running properly on the short run to garage :good:
Although strongly advised to replace rear shock since has virtually no dampening left. Also need to move regulator and gear leave since seems I set it too low and had fun getting toes under to change up. :rolleyes:
