Peugeot 306 Roadwheel Lock Bolt Removal
139 replies to this topic
#61 leehenty
  • 5,323 posts
Posted 20 July 2020 - 09:34 pm
Some french bloke thought how complex can we make it ?
#62 Snowbird
  • 1,465 posts
Posted 21 July 2020 - 05:22 am
French blokes seem to do that a lot.
#63 Norwegian
Norwegian
  • 162 posts
Posted 21 July 2020 - 09:46 am
Reminds me of my old XM. Full gas-hydraulic suspension, absolutely amazing comfort. All connected with miles and miles of hydraulic lines. So why not make them all of steel instead of copper, and wrap them in plastic - that will surely never rust?
And why not press fit a large steel ring onto those really fantastic rear one-piece aluminum dampers, to make absolutely certain there will be no galvanic pitting corrosion eating up the alu hidden behind the steel. And the list goes on and on.
I spent as much on hydraulic oil as I did on diesel on that one. But when it worked ... best car ever. Once, I loaded 7-800 kilos of sand in the rear (for lack of a trailer), and it kneeled completely on the rear axle. Until I started the engine, and it popped right back up again, effortlessly. It floated like a flying carpet over the speedbumps in our lokal road. I was seriously impressed! But then I was hit no less than three times within a year, last one wrecking the right side completely. Gave it up then.
On the bright side,I did get £6000 in all for the various damages, on a £3000 car.
#64 dapleb
  • 18,389 posts
Posted 21 July 2020 - 03:28 pm
I don't think it's overly complex... Just I'm overly simple :0)
Must be missing summat but very difficult to diagnose without being able to see the fault occur.
Next attempt is to remove orig ends where it enters motor and put on replacement cables!!!!
#65 dapleb
  • 18,389 posts
Posted 30 July 2020 - 05:53 pm
Clever.....just need to put mine in longways and hex.
https://youtu.be/Ysd8JkWclmc
#66 Studley Ramrod
Posted 30 July 2020 - 06:34 pm
Ingenious. Some of his videos are real funny.
If you could get some correct size brass hex bar you might be able to tap it and fit a grub screw in there, along with some solder for good measure.  Prolly only take a day. :D
#67 dapleb
  • 18,389 posts
Posted 25 October 2020 - 07:35 pm
Ahem. Window long since fixed...if anyone needs a window regulator changed in a 306, bring it here, I can do burgers in me sleep after all that trial and error and error and error...
Latest fun times......
The rear window wiper started activating when the indicators or foorbrake operated..with the wiper switch in off positon lolziooooo. I couldn't believe it at first but yes Indeed.
I have learnt a neat trick to find the source of problems...the previous "mechanic" didn't like bolts...a huge waste of time. So when a panel has 5 out of the 7 bolts missing you know you are on the right track to finding an existing bodge. In this case a poorly fitted rear wiper motor letting copious amounts of water in and filling the relay.
Nexxxt onto existing problems. The heated rear window not working. I traced this again to a relay that had melted itself into the fuse box panel...ughh. not only relay toast but also relay connector in back of fuse box melted....ewwwwww. The only 50% of bolts in the fuse box panel told me the eeejit had probably also traced this problem but thankfully given up. Still working on this one as the relay socket notttt available.
#68 drewpy
  • 1,788 posts
Posted 25 October 2020 - 07:42 pm
OMG, you don't 'arfe have them.
#69 dapleb
  • 18,389 posts
Posted 25 October 2020 - 07:57 pm
They is old motors Drewps so not a great surprise I guess. Even the ultra reliable slug had a technical issue last week....snapped a spring but kindly waited till 1.5miles from home after doing 400+ miles of mostly motorway....thankfully not snapped into tyre....so some luck.
#70 dablik
  • 10,893 posts
Posted 25 October 2020 - 09:53 pm
Sounds like a relation to my bike daps  :lol:  also had a spring go on the Fiesta, thankfully while it was parked up..
#71 dapleb
  • 18,389 posts
Posted 25 October 2020 - 10:03 pm
Yeah that seems quite common for them to just twang while parked ooop.
#72 Catteeclan
  • 2,571 posts
Posted 26 October 2020 - 06:27 am
I know it's nice to have the right socket for the relay but you could use spade connecters of another socket off a different car.
Edited by Catteeclan, 26 October 2020 - 06:29 am.
#73 Bjørge
  • 1,895 posts
Posted 26 October 2020 - 07:24 am
I always thought british cars were the ones with constant electric gremlins?
(Running for life)
#74 dapleb
  • 18,389 posts
Might have to be summat loike that Catte, doing the scrap rounds trying to find a used socket I can splice in....limited access though as under the dash in drivers footwell.
The socket also twists in to locate it in the fuse box area so without that it would just be flapping around.
Ahaa exactly like this...except less access on HDI Pug. http://www.306gti6.c...d.php?id=146452
#75 Studley Ramrod
Posted 26 October 2020 - 09:33 am
(Running for life)
Italian actually. :)  British cars just rust to nothing in 5 yrs.
Good detective skills Daps, and highly entertaining for us all. :D
#76 ChrisG
Posted 26 October 2020 - 05:13 pm
My mother once had a similar issue on a Volvo, every time she turned the steering wheel the horn would sound :D
#77 dapleb
  • 18,389 posts
Posted 25 June 2021 - 05:14 pm
So the relay problem was fixed when I found someone on the bay who I got loadsa lovely spare parts from and he even cut off the relay back so I could fixy proper. Jobsa carrot.
Since then.... Nothing much interesting has happened with the pug, until yesterday when I turned the enjun oft and took the key oooot. Except someone forgot to tell the pug as it was still running haaa. Erm it did stop eventually and then chucked up an enjun loight. Tried again and same thing. Then it behaved but I decided to pop along to some clever peeps with a posh plug.
The posh plug said "intermittent fault. Fuel pressure regulator. Stop requested but regulator still active"
Hmmm so I guess diesel fool pamp has some regulator on it that is playing up. Haynes also suggests there is a stop solenoid so could be that. Neither sounds loike a great deal of fun. ლ(^o^ლ)
#78 Snowbird
  • 1,465 posts
Posted 25 June 2021 - 05:44 pm
Too lazy to read back but is this an old school xud9 diesel or am I a slightly drunk deluded old git with dodgy memory? (all bits past enjun query are far too true due to local pub having a very nice stout)
If so there is a solenoid on the pump that should cut the fuel when enjun is told to sod orf, normally +12v when ignition on, maybe sticking.
I gotta set of injectors for non turbo version if anyone wants them, XUD9-162.
Solenoid should be fairly cheap.
#79 Studley Ramrod
Posted 25 June 2021 - 06:34 pm
I'd prolly check the solenoid first as the pump can't carry on running if there's no power to it, assuming pump is not mechanical ?
#80 dapleb
  • 18,389 posts
Posted 25 June 2021 - 06:44 pm
Yeah ta. I will check stop solenoid if I can find it. Haynes covers so many enjun models in one book hard to know what's relevent...and then diff pumps on those enjun models. Haynes mentions a manual override stop on the pump....lists where it is dependent on pump type....but not found that yet.
This one is hdi enjun SB. Not sure what enjun code is and ain't got me book. I'm used to DW8 stuff not HDI.
