Fast Idle Plunger Repair (TDM 900) [ie Cold Start ]
153 replies to this topic
#61 SteveK
SteveK
  • 664 posts
Posted 29 March 2011 - 03:31 pm
QUOTE(leehenty @ Tue 29th Mar 2011, 04:26 PM) <{POST_SNAPBACK}>
Sizes ... The bore of the banjo that fits over the nose that's what we need to know.
With the casting lines carefully removed from the housing neck, 9mm bore, 6mm long. wall thickness ~ 2mm. I have 4 more of the small bore brass tubes in stock if required.
Steve
Edit, Care must be taken when orienting the banjo so as not to foul the throttle cables.
Edited by SteveK, 29 March 2011 - 03:32 pm.
#62 aircooled68
Posted 29 March 2011 - 04:17 pm
Is that brass bit the end of a lokring???
#63 SteveK
SteveK
  • 664 posts
Posted 29 March 2011 - 04:19 pm
QUOTE(aircooled68 @ Tue 29th Mar 2011, 05:17 PM) <{POST_SNAPBACK}>
Close. its the plain section of an Enots fitting.
#64 fredtucker
fredtucker
  • 102 posts
Posted 29 March 2011 - 07:11 pm
I don't understand why Yamaha made such a crude mechanism for mixture control. Surely as this is a fuel injected engine with various electronic sensors sending signals to the management computer, than a sensor controlled enrichment system for cold running/fast idle would be more reliable. I'm sure BMW have been using them for some time.
#65 Catteeclan
  • 2,577 posts
Posted 29 March 2011 - 07:23 pm
I was thinking of putting a gaiter over the end but that looks just the job. good.gif
#66 wicklamulla
Posted 29 March 2011 - 09:38 pm
looks a good mod.
#67 dablik
Posted 29 March 2011 - 10:32 pm
#68 Nog
Nog
  • 527 posts
Posted 30 March 2011 - 07:37 am
QUOTE(Catteeclan @ Tue 29th Mar 2011, 08:23 PM) <{POST_SNAPBACK}>
I was thinking exactly the same, the lube tube is a brilliant idea, but with the addition of a gaiter as well would stop the gunk getting in in the first place good.gif
#69 SteveK
SteveK
  • 664 posts
Posted 30 March 2011 - 07:45 am
QUOTE(fruitcake @ Wed 30th Mar 2011, 08:37 AM) <{POST_SNAPBACK}>
Something like this from a model power boat supplier,
http://www.prestwich...ellows4off1.jpg
Steve
Edited by SteveK, 30 March 2011 - 07:45 am.
#70 Chris B
Chris B
  • 828 posts
Posted 30 March 2011 - 12:20 pm
Just twat it with a mallet when it sticks, it always free mine up tongue.gif
02 TDM 900, Silver. 85k miles
#71 Catteeclan
  • 2,577 posts
Posted 31 March 2011 - 08:46 am
QUOTE(SteveK @ Wed 30th Mar 2011, 08:45 AM) <{POST_SNAPBACK}>
Steve
Could well do the job although there'll be some stretching on the body end. No a prob if it's good rubber.
I was looking at one off a car hand brake cable but it's pretty much the same as your pictured.
#72 leehenty
  • 5,326 posts
Posted 05 April 2011 - 10:58 pm
found the right bellows for this.
http://www.prestwich...uk/hdwraccs.htm
The bit we want is GA19, has 9mm wide mouth to go over the housing.
I have two of these so when I've done the job I'll post pics.
#73 dmmsta
dmmsta
  • 3,627 posts
Posted 06 April 2011 - 08:28 am
Mr Henty, would these do the trick based on SteveK's info on the bolts?
I've not real idea about threads, and pitch, and all that...
M5 x 16
M5 x 30
I'd quite happily make the purchase, and then send spares out to those that need them too...my way of giving back to Carpe.
#74 leehenty
  • 5,326 posts
Posted 06 April 2011 - 01:33 pm
QUOTE(dmmsta @ Wed 6th Apr 2011, 09:28 AM) <{POST_SNAPBACK}>
M5 x 16
M5 x 30
Er yes they would do the trick no problem. Can I advise using M5 stainless spring washers under the heads to stop them coming loose, this is a vibration area after all.
I do hold all these sizes in stock of course.
Edited by leehenty, 06 April 2011 - 01:38 pm.
#75 dmmsta
dmmsta
  • 3,627 posts
Posted 06 April 2011 - 02:41 pm
QUOTE(leehenty @ Wed 6th Apr 2011, 02:33 PM) <{POST_SNAPBACK}>
Kinda thought you probably would, but didn't want to take the michael so to speak... blush.gif
Could I possibly request a set (2 of each type I believe)...
Let me know cost & I'll PP you the money.
#76 SteveK
SteveK
  • 664 posts
Posted 06 April 2011 - 06:37 pm
QUOTE(leehenty @ Tue 5th Apr 2011, 11:58 PM) <{POST_SNAPBACK}>
Just a thought, do you know that the compressed length of the bellows is sufficient for the amount of travel of the plunger. Would'nt want the bellows restricting full movement. This is something I did not measure so no idea of the range.
Steve K
#77 Catteeclan
  • 2,577 posts
Posted 06 April 2011 - 07:49 pm
Good find, now ordering.
#78 leehenty
  • 5,326 posts
Posted 09 April 2011 - 06:02 pm
Done mine today, tried both bellows, GA18 and GA19, GA18 with the narrow neck snipped off at the fourth bump is just right. The advantage is that GA18 comes in fours. Stainless allen screws and spring washers to put back. Used aCf50 to lubricate.
Cut off FORTH bump near NARROW end, not the other end or you will ruin the job works a treat.
Edited by leehenty, 09 April 2011 - 07:22 pm.
#79 TonyDevil
Posted 09 April 2011 - 06:05 pm
anyone think this worthy of be moved to the knowledge base?
#80 dmmsta
dmmsta
  • 3,627 posts
Posted 11 April 2011 - 06:47 am
QUOTE(TonyDevil @ Sat 9th Apr 2011, 07:05 PM) <{POST_SNAPBACK}>
With all the problems us 9ers have with the CSM I give that idea the good.gif
