#781 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 27 June 2015 - 07:50 pm
Cleaned off mating surfaces and fitted RolfieB's brand new, cast-off, OEM, stator cover gasket.
Now the belly pan can rest easy, no longer being called upon as a secondary oil catch tank.
Problem is, where am I to get my genuine Yamaha kit from now? Cheers bud.
#782 Galilee
Galilee
  • 892 posts
Posted 28 June 2015 - 07:12 pm
put 1645km on the odometer last weekend.
This is the first time i've seen the wear warnings on the outer edge of the tires same time as on the middle.
So, time for a new front tyre, clutch, oil change.
#783 Bjørge
Posted 29 June 2015 - 07:15 am
Fitted replacement black forks and new gators...20150627_093917_zpszexso5vl.jpg
How's that extra windscreen performing ? Self-made ?
#784 schmo9
schmo9
  • 197 posts
Posted 29 June 2015 - 05:33 pm
It's great....it was on the bike when I got it, couldn't even tell you what make it is...
#785 GeneralBozo
GeneralBozo
  • 92 posts
Posted 29 June 2015 - 07:15 pm
Felt sorry for it for two reasons:
1: After around 2000 miles on Scotland trip (I'm a southern fairy so it is quite far away)  :sorry:
2: Moved it out of the way in the garage to allow the prime spot to be taken up by my CBR400 NC29, to get it going again and ready for MOT and summer thrashing :clapping:
#786 Rewop
Rewop
  • 127 posts
Posted 30 June 2015 - 01:33 pm
Just got back from an excellent but very hot ride from Harrogate to Ripon, Masham, Leyburn, Hawes, Grassington, Pateley Bridge and home.  Hardly any traffic, although Hawes a bit busy because its Market Day.  I don't think Wensley Dale/Wharfedale and Nidderdale have ever looked better - Figured that my aching throttle wrist is probably down to the sharpish rearward bend on the standard niner handlebars so will look up the various threads on "Renthals" for advice on a replacement - Cheers all
#787 schmo9
schmo9
  • 197 posts
Posted 30 June 2015 - 02:18 pm
Need to show us the NC :)
#788 chrisr
Posted 30 June 2015 - 02:32 pm
755s, much better, especially with risers.
#789 g650xtdm
g650xtdm
  • 295 posts
Posted 30 June 2015 - 11:04 pm
As awesome as the TDM is, I don't understand what Yamaha was thinking when they decided on putting those strange bars on the bike.  Where's the logic in putting uncomfortable cruiser bars on a sport tourer? :locco:
#790 Retro
Retro
  • 242 posts
Posted 01 July 2015 - 10:03 am
A Throttle Rest for a couple of quid will solve your problem. You can rest your hand on the throttle at an angle to suit and control the throttle by pushing rather than twisting. Love 'em
#791 Phil McLaughlin
Phil McLaughlin
  • 164 posts
Posted 01 July 2015 - 10:14 am
(yesterday really)
Fitted the MRA winglet from my old Tiger 150 screen to the stock screen
black tacked it first to check it and was pleased with pressure relief on neck so drilled it and made permanent
YMMV though :-)
Having said that, I realise the necko speedo is no longer efective as im doing 20 mph more than ususal pretty much everywhere outside a 40 limit.  oops.....
#792 TPB
TPB
  • 3 posts
Posted 02 July 2015 - 03:39 am
did this over the weekend
https://lh3.googleus...6/upload_-1.jpg
#793 Rewop
Rewop
  • 127 posts
Posted 02 July 2015 - 10:22 am
Thanks for this Retro, I see they're only a quid so I'll give it a try.
#794 Graks
Graks
  • 22 posts
Posted 02 July 2015 - 07:03 pm
installed Barkbuster handguards. Seems good so far.
#795 JBX
Posted 03 July 2015 - 06:04 pm
I did not ride the last days because the outside temperature is too high - more than 40° & the the sunshine is unbearable.
I'm planning to relocate in a rainny country...  :hide:
#796 jameslibra
jameslibra
  • 41 posts
Posted 04 July 2015 - 10:23 am
That just looks so right! I love it. I do long distances so wouldnt suit me to well but shes a looker.
On a different note, I found my rear shock snapped at the bottom bush. Having just come back from a week in France its a bit worrying as to when it went.
#797 CharleyFarley
CharleyFarley
  • 159 posts
Posted 04 July 2015 - 11:15 am
On a different note, I found my rear shock snapped at the bottom bush. Having just come back from a week in France its a bit worrying as to when it went.[/quote]
Could have been nasty that...........
Just checked out everything thoroughly on mine, only issue seems to be the front brake callipers....
#798 MattTDM
MattTDM
  • 112 posts
Posted 04 July 2015 - 05:06 pm
Started preparation for my big annual touring (leaving on Saturday for 4 weeks). Will be my be my 5th year doing a 'Europe trip' on this TDM
Greased steering bearings, changed fork oil, ordered braided hoses, removed swingarm to grease bearings and ended up deciding to drop it off to be powder coated. Dropped wheels and new tyres off to be fitted. Beer o'clock now.
Swingarm should be ready to collect Monday so will resume assembly then. Until then I am keeping busy with cleaning and more cleaning (the bike that is!)
Question - how often do you guys changed plugs and air filter? I usually do them once a year on my 'big service' but last year after 6k they both look fine when I pulled them out. Currently done about 7k on them and tempted to leave them as is. I anticipate doing another 6k on this years tour. So would be 13k on that set of plugs/air filter
Edited by MattTDM, 04 July 2015 - 05:17 pm.
#799 Sidarta
Sidarta
  • 845 posts
Posted 04 July 2015 - 06:29 pm
Hi MattTDM!
The service manual states:
1) plugs - verify - clean and adequate distance from the electrodes to 10k, 30k - replace every 20k
2) Air Filter - Check and clean 10k, 30k - replace every 20k
I clean and check items 1 and 2, less often than recommended.
However the substitution is 20 to 20k.
The frequency of inspection and cleaning air filter, is intrinsic where you wheel
(only asphalt, dirt / dust?)
I wish you a pleasant journey. :good:
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#800 Favs
Posted 05 July 2015 - 06:59 am
Treated the SN08 to two new Avon Storm 3D XM
Scrubbed  them in too.
Edited by Favs, 05 July 2015 - 05:23 pm.
