#801 MattTDM
MattTDM
  • 112 posts
Posted 05 July 2015 - 06:07 pm
Hi MattTDM!
The service manual states:
1) plugs - verify - clean and adequate distance from the electrodes to 10k, 30k - replace every 20k
2) Air Filter - Check and clean 10k, 30k - replace every 20k
I clean and check items 1 and 2, less often than recommended.
However the substitution is 20 to 20k.
The frequency of inspection and cleaning air filter, is intrinsic where you wheel
(only asphalt, dirt / dust?)
I wish you a pleasant journey. :good:
Cheers!
Thanks for that info, generally I think if I am going to spend the time to remove the plugs, I would just replace them, given they are cheap and that the fuel tank needs to come off.
#802 TPB
TPB
  • 3 posts
Posted 05 July 2015 - 07:27 pm
new handlebars and mirrors, took a little ride with my SO
#803 TDMick
Posted 05 July 2015 - 11:30 pm
We're going to need more photos of that!
#804 MAW
MAW
  • 46 posts
Posted 06 July 2015 - 01:01 am
I just got the bike from a friend but since his not in town and I do not have the keys  :rant: I did not advance as much as I could.
I am now in a search process, already found a bent handlebar, worn out grips, speedometer not working and some broken plastics easy fits with the exception  of the speedometer.
The archives shows corrode contacts and problems with the unit in the wheel, what should I look for in the sensor to establish if is bad or not?
Attached File  bent bar.jpg   98.07KB   0 downloads
Attached File  Bits.jpg   89.06KB   0 downloads
Attached File  DF.jpg   179.95KB   0 downloads
Wish you health to enjoy your rides from the sunny lands of Venezuela
#805 Sidarta
Sidarta
  • 845 posts
Posted 06 July 2015 - 01:31 am
Hi MAW!
I believe the sensor, is a more difficult piece to give defects. Most likely a rust / dirt on the wire connections.
You already dismantled the front wheel, to see if the sensor rotor is ok?
See what happened to me this link: http://www.carpe-tdm...=31395&hl=rotor
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#806 Bjørge
Posted 06 July 2015 - 04:32 am
I did not ride the last days because the outside temperature is too high - more than 40° & the the sunshine is unbearable.
I'm planning to relocate in a rainny country...  :hide:
You're welcome ! Today we've got 18° and heavy rain  :badgerrock:
#807 Bjørge
Posted 06 July 2015 - 04:47 am
Ordered a new (er...used) complete R6 braking system, as my master pump has started to feel a little sticky - it doesn't always return fully when engaged. It breaks as usual, but it kinda doesn't return properly.
As I want the best possible brakes this was exactly what was needed for me to start an upgrade...dreaming of the bling-bling blue spots now :pimp:
#808 TPB
TPB
  • 3 posts
Posted 06 July 2015 - 07:58 am
here ya go TDMick
first day at my place, all plastic must die
evening of first day
second day, 18cm out of the frame and the seat
seat reupholstered, took 18cm from the middle, not the back off
welded together for testing
moved the rear taillight into the frame with the original brackets to keep the seat functional and removable
and it started to look like this
then new handlebars and mirrors
then bent some DiBond to cover the butt and washed and voila, ready it is
and as the name implies, real REDNECK ENGINEERING from Estonia :)
#809 ChrisG
Posted 06 July 2015 - 12:28 pm
Washed it!
Well I say washed, I rode it home in the rain so most of the bugs have soaked off :lol: .
#810 big dave
Posted 06 July 2015 - 02:45 pm
taken off the stretched clutch cable awaiting delivery of replacement
taken off pannier mounting brackets
taken off oe silencers
mounted ex coxylad silencers
taken out db busters
started it up
replaced db busters  (ooft, a bit loud it was!)
waiting now for clutch cable before I go out and give it the beans
Edited by big dave, 06 July 2015 - 02:46 pm.
#811 schmo9
schmo9
  • 197 posts
Posted 06 July 2015 - 07:01 pm
Ordered new needle jets....hopefully help sub 3k running!
#812 Wildbill
Wildbill
  • 445 posts
Posted 06 July 2015 - 07:14 pm
Pulled it out the garage and  adjusted the headlight beams in preparation for an MOT.
Its being lent to some one for a few months whilst I attempt to resurrect  their Z1R  that has lain in a damp shed in bits for 30 years.
Don't come preaching to me;you'll get chased down the road wiff a pitchfork.
#813 big dave
Posted 10 July 2015 - 11:53 am
#814 g650xtdm
g650xtdm
  • 295 posts
Posted 11 July 2015 - 12:02 am
Mine hit 40,000 miles as well.  Except mine is a 1993 model :unsure2:
#815 dablik
Posted 11 July 2015 - 07:48 am
Snap or a smidgeon over, must look.
#816 Favs
Posted 11 July 2015 - 05:30 pm
Rode it from Northwich to Farnborough for lunch and some R and R.
#817 Matlock
Posted 11 July 2015 - 09:01 pm
Replaced the headlight bulb which blew on the G2G Saturday rideout. Ivan (GeordieGuy) gave me replacement that day, so I wasn't left lightless, but I replaced that with an Osram Silverstar2 today - big improvement over a standard H7. I've got a new bulb for you next time I see you Ivan  :good: .
And I replaced one of the oil feed pipes on my Lee Henty twin feed Scotoiler which I I must have damaged when I swapped tyres before the G2G and which promptly deposited oil on my back tyre on the Saturday rideout when the crack in it got worse   :shocked: . Thanks to Mr Henty for supplying replacements in double quick time at no cost, you are a star sir  :good:
#818 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 12 July 2015 - 08:07 am
Oh, TPB. You are a naughty boy. Spring for some forks and a decent shock and you have a lickable streetfighter. Cruel and unusual but why not?
Washed mine today, polished the alloy bits, lubed the moving bits and then took it for a fang to dry it off. Ahhhhhh. Deep joy.
Oh. Pulled off the radiator guard for a respray. It's hanging off the plum tree as I post.
Edited by harvey krumpet, 12 July 2015 - 08:10 am.
#819 Splodge
Splodge
  • 63 posts
Posted 14 July 2015 - 10:17 am
New C/S kit fitted, after the usual last minute begging for 36mm socket & rivetting tool !
Must start taking fotos of people holding the stuff I lend them so I have a clue who might have it when I need it myself....
My mums monkey makes many mistakes.
#820 wigwamclan
wigwamclan
  • 200 posts
Posted 14 July 2015 - 10:51 am
Replaced clutch cable, front wheel bearings, serviced the front brake calipers and got a new MOT : ) ....just the needle roller bearing in the rear suspension linkage to box off an she'll be running like a new 'un
