Day Of Fettling
188 replies to this topic
#81 JollyGiant
Posted 02 November 2009 - 08:49 pm
QUOTE(Moose @ Mon 2nd Nov 2009, 08:30 PM) <{POST_SNAPBACK}>
Ready for it..........................
Oil + filter
Plugages
Carb Balance
Valve Clearances
Brake Fluid and bleed (i got bleed kit)
General bearing check
oi fink tis aboot all fella
ave ya got vacuum guages for carbies?
Yarp and I also ave brake bleeding kit complete wiv air inserting tool just right for that home made spongy feeling good.gif
#82 TDMTAM
Posted 02 November 2009 - 08:51 pm
Oil + filter
Cake
Plugages
Cake
Carb Balance
Cake
Valve Clearances
Cake
Cake
Oh & some cake
#83 Moose
    Master Cake Baker
  • 3,312 posts
Posted 02 November 2009 - 08:54 pm
QUOTE(TDMTAM @ Mon 2nd Nov 2009, 08:51 PM) <{POST_SNAPBACK}>
Mmmmmmmmm CAKE!!!!!!!
#84 Moose
    Master Cake Baker
  • 3,312 posts
Posted 03 November 2009 - 09:20 pm
just a thought, do i need any gaskets when doing the stuff we is doing?
If so what i need and where i get it from?
#85 Kaustic
Kaustic
  • 204 posts
Posted 03 November 2009 - 10:40 pm
Just found out that my new Renthal handlebars are not due at the warehouse until at least the 8th, so thats out the window for this weekend . ranting.gif
TDM Mk2a
Mods (so far) : Heavy duty chain & sprockets, Braided metal hose (front), DL650 handguards, Hyperpro progressive fork springs, Ohlins rear shock & Oxford Heated grips
Wish list : Home made panniers & frames, LED side light, crash bar, centre stand, oversize foot for sidestand.
#86 JollyGiant
Posted 04 November 2009 - 12:23 am
QUOTE(Moose @ Tue 3rd Nov 2009, 09:20 PM) <{POST_SNAPBACK}>
You might need a rocker cover gasket, from dealer or wemoto.
Are you comming on sat Kaustic??
#87 Guest_trevini_*
Guest_trevini_*
Posted 04 November 2009 - 06:22 am
QUOTE(Jolly Giant @ Mon 2nd Nov 2009, 08:49 PM) <{POST_SNAPBACK}>
#88 Guest_Catteeclan_*
Guest_Catteeclan_*
Posted 04 November 2009 - 08:36 am
The rocker cover gasket is rubber so hope to use that again. The o ring on the water pipe might be a prob as alot of crap builds between itself and the head damaging the o ring when removing.
I'll bring the instant gasket as a get out of jail.
#89 Kaustic
Kaustic
  • 204 posts
Posted 04 November 2009 - 10:28 am
QUOTE(Jolly Giant @ Wed 4th Nov 2009, 12:23 AM) <{POST_SNAPBACK}>
Yep, I'll be there. Well, if I can't get the handlebars in time I still have one or two things I could do with a second opinion on (& I have a Darwin symbol to stick on the top box to annoy the god botherers with tongue.gif ). Also I have got all the ingrediants for cake- ing
k
TDM Mk2a
#90 Studley Ramrod
Posted 04 November 2009 - 11:18 am
You might need a temp. fuel supply, unless your gonna swivel the tank out the way. And possibly a drain plug gasket/copper washer.
#91 TDMTAM
Posted 04 November 2009 - 11:34 am
QUOTE(Kaustic @ Wed 4th Nov 2009, 10:28 AM) <{POST_SNAPBACK}>
k
Tam
#92 Moose
    Master Cake Baker
  • 3,312 posts
Posted 04 November 2009 - 03:58 pm
QUOTE(Studley Ramrod @ Wed 4th Nov 2009, 11:18 AM) <{POST_SNAPBACK}>
Got new drain plug and copper washer, been trying to ring local Yam dealer all day but they've been engaged, must be all the TDM1000 enquiries rotflmmfao.gif
Yep, I'll be there. Well, if I can't get the handlebars in time I still have one or two things I could do with a second opinion on (& I have a Darwin symbol to stick on the top box to annoy the god botherers with tongue.gif ). Also I have got all the ingrediants for cake- ingk
This sounds like we might have bit of a cake off brewing
Edited by Moose, 04 November 2009 - 03:59 pm.
#93 Landy
Landy
  • 1,387 posts
Posted 04 November 2009 - 04:16 pm
How long do you think you are going to be about chaps?
I may come along but it's me burp-day on Friday drinks.gif so I will not be up and about much before lunch time on Sat at the earliest. Once I am vertical I am only half and hour from Thetford though and I do have a mini fuel tank for when your are balancing.
#94 Moose
    Master Cake Baker
  • 3,312 posts
Posted 04 November 2009 - 04:28 pm
QUOTE(Landy @ Wed 4th Nov 2009, 04:16 PM) <{POST_SNAPBACK}>
Should be there most of the day i'd have thought fella unless JG wants rid early so he can hoard all the cake rotflmmfao.gif
But gotta do shims when its cold anyway so should be there.
I'll PM ya me number so ya can see the progress before ya get geared up fella
#95 Studley Ramrod
Posted 04 November 2009 - 04:50 pm
If your struggling to calculate the shims using yer heeds, you could use the valve shim calculator on JBX's site.
I tried it out yesterday and it's reeeeeealy good !
http://jbx9.free.fr/....php?page=VALVE
#96 dapleb
  • 18,378 posts
Posted 04 November 2009 - 05:26 pm
I sent em the EXACT calculator SR. The crazy Frenchmans one assumes you only have '5' increment shims available.
#97 JollyGiant
Posted 04 November 2009 - 05:28 pm
Got the shim calculator thingy ta!
Corse you can come over Landy as can anybody who wants to come (But might run out of mugs and cakes!!) I reckon we'll be playing most of the day??
Might even do my clearances if there's time!!
#98 Moose
    Master Cake Baker
  • 3,312 posts
Posted 04 November 2009 - 06:39 pm
QUOTE(Jolly Giant @ Wed 4th Nov 2009, 05:28 PM) <{POST_SNAPBACK}>
I don't think there's much chance of running outta cake fella
Shall bring a mug (Insert quip here)
#99 Studley Ramrod
Posted 04 November 2009 - 07:49 pm
QUOTE(dapleb @ Wed 4th Nov 2009, 05:26 PM) <{POST_SNAPBACK}>
It does indeed Dappers, pity about that. I noticed also that the parts fiche only lists the shims in 5 increments. dunno.gif
#100 JollyGiant
Posted 04 November 2009 - 08:04 pm
QUOTE(Moose @ Wed 4th Nov 2009, 06:39 PM) <{POST_SNAPBACK}>
Shall bring a mug (Insert quip "Just bring your face thats a ugly mug if I've ever seen one" here)
