Pulling The Rotor Orf Question..
89 replies to this topic
#81 leehenty
  • 5,323 posts
Posted 14 December 2010 - 04:06 am
QUOTE(JBX @ Tue 14th Dec 2010, 01:05 AM) <{POST_SNAPBACK}>
I found this drawing of the extractor on the french technical book (3VD), hope it could help !
That's what I've been looking for, a proper drawing. Now that looks like a nice winter project to make. biggrin.gif
Found a 25mm slice of 100mm dia bright steel bar in the scrap yard, stubbed me toe on it actually, so if I tap it the right thread, no nut should be needed.
The bit of metal 'accidentally' fell into the back of the car as I know the bloke down there quite well rolleyes.gif
Edited by leehenty, 14 December 2010 - 10:29 pm.
#82 Studley Ramrod
Posted 14 December 2010 - 06:59 am
Thanks JBX smile.gif Lookin' at the diagram it's easy to see that the weakest part is the nut weld if the puller is used that way around.
Looks like me 18mm nut & bolt is big enough then.
In the welder's defence, I think he assumed I'd want to get a spanner on the nut, hence it not being welded fully and I didn't specify having the hole tapped, wanting to keep costs down.
Edited by Studley Ramrod, 14 December 2010 - 07:01 am.
#83 dapleb
  • 18,388 posts
Posted 14 December 2010 - 07:55 am
QUOTE(Studley Ramrod @ Tue 14th Dec 2010, 06:59 AM) <{POST_SNAPBACK}>
I knew page 5 would bring up some extreme reactions but really!
Nice piccie crazy Frenchman, have quite a few 3VD bookies including the service manuel and aint not never seen that there piccie.
#84 Catteeclan
  • 2,570 posts
Posted 14 December 2010 - 08:23 am
That pic has just reminded me I have a mini (car) flywheel puller in the shed somewhere which is not unlike that.
#85 Studley Ramrod
Posted 14 December 2010 - 11:35 am
Got the puller on the right way round this time, wiv 90mm tripod bolts and a new 18mm nut & bolt !
Turned the bolt until it would turn no more, then flamed the rotor and pinggggggggggggg !
Now then, about those chewy torx screws......................
#86 Matlock
Posted 14 December 2010 - 02:02 pm
#87 dapleb
  • 18,388 posts
Posted 14 December 2010 - 02:13 pm
Bwill-yant.
Nice wan.
So allen had a wee nut on his bottom?
Whats next?
#88 Studley Ramrod
Posted 14 December 2010 - 03:45 pm
Got the balancerers to remove and then it's onto splitting the casings methinks !
Just Phsycoin mesen up ferrit.......Torx Screws, Be Strong ! and having a read of the Manuel for once rolleyes.gif
I don't need to remove the conrods do I ? Then again, may as well check oot the bearings whilst I'm in there eh !
#89 dapleb
  • 18,388 posts
Posted 14 December 2010 - 04:10 pm
The wee torx skews on the balancer shaft ends are made of finest Yam Chutterknee. Mek sure yer talk spit is a good fit.
Cant remember is wods get in the way of the million odd case bolts but ewe'll find oot when ya git there.
#90 leehenty
  • 5,323 posts
Posted 14 December 2010 - 07:01 pm
There you go easy ain't it with the right bits, glad to know the protector worked. Me Dad knows how to put a ball bearing in the end of a bolt to keep it centred. I will ask for a tutorial on it.
Your mkII design sprocket nut should be there soon.
