Mk1 TDM850 Electric Fuel Pump Install
132 replies to this topic
#81 landshark
landshark
  • 17 posts
Posted 24 June 2011 - 04:40 pm
Anyone?! Even a toss out of left field would be great. I have no idea what's causing this.
thanks
Joel
#82 Studley Ramrod
Posted 24 June 2011 - 04:58 pm
QUOTE(landshark @ Mon 20th Jun 2011, 11:00 PM) <{POST_SNAPBACK}>
I've been running this mod for about a year now and 2x in that year, for no apparent reason, the negative lead from the pump to the battery went POOF! The lead went from stranded to solid copper and is very brittle. Not to mention the wire insulation is melted. Wire too small a gauge? Or something else you think?
thanks for the help!
Hi Joel,
have you read the posts in this topic ? The second post mentions having to fit a relay as his was blowing fuses. I'm assuming you haven't fitted a relay as you haven't mentioned fitting one. I'm also assuming you installed an R6 pump using the same method for wiring it in as the method shown in the first post. The original pump wiring should be suitable for the job intended.
#83 landshark
landshark
  • 17 posts
Posted 06 July 2011 - 02:12 pm
QUOTE(Studley Ramrod @ Fri 24th Jun 2011, 11:58 AM) <{POST_SNAPBACK}>
Hi Joel,
Hi,
yeah, I fitted the relay from the start and picked up the switched leg so the pump switches on/off using the Run/Off switch on the right handlebar. I thought I followed the schematic from this thread exactly.
The weird thing is it seems to run great. Then, for no reason the ground wire from the pump to the battery will completely melt. It actually happened again this AM. I filled up the bike, switched it on, and poof. Up in smoke.
I'm considering going back to a vacuum pump. Has anyone found a current Mikuni (or other vacuum) pump that is a direct replacement?
Thanks for checking in on this thread.
Joel
#84 Studley Ramrod
Posted 06 July 2011 - 05:22 pm
The pump for a mk1 is an endangered species these days unfortunately. I'm not 100% sure but I think a mechanical pump for a mk2 can be made to fit.
Yooo Hooo Dappers ! ????
#85 landshark
landshark
  • 17 posts
Posted 07 July 2011 - 10:36 pm
Luckily I did just find a MK 1 pump on fleabay. It should be at the house in a day or so. For $30 I think it's worth a shot.
It's possible the r6 pump I have is in some way faulty. I'll update when I get the new-old vacuum pump in and working.
#86 dapleb
  • 18,388 posts
Posted 08 July 2011 - 05:29 am
Owww I missed this. Can't help with the electricalfrying stuff but can confirm a mkII mech pump fits just needed to change some poipe bore. Prefer the mechanical simple idea than adding more electrical components. Rectum your new pump will be fine Sharky. I have SR's spare pamp somewhere ear and my old mkwanwan.
#87 Joostvdw
Joostvdw
  • 9 posts
  • TDM model: 1995
Posted 20 March 2012 - 05:41 pm
Just a few pointers as I too finished this mod today;
- Don't use a FZR1000 pump, it'll work, but for some reason it's a higher pressure than normal, a VF750 pump works a treat.
- CHECK YOUR FLOAT LEVELS! Use the pump to fill up the bowls, preferably on the bench where you have all the access you need.
- 15mm (about where there is a "bend" in the bowl cover) below the mikuni line seems to work fine for me.
- There is a sweet spot when adjusting the float level, bending it too little makes raises float level, but bending it too much raises it as well!
- About 4.4mm including the plastic bit the bendable tab is located in (it'll make sense when you open it up) works for me.
- Open up the fuel drain bolts more than 1 complete turn or it'll give false readings.
Some of this may be common sense or obvious, but it wasn't to me, so I thought I'd share my findings smile.gif
After you've done all this it should run like a dream, mine sure does after lowering the fuel level 16mm.... blink.gif It even does powerwheelies now wink.gif
#88 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 23 March 2012 - 06:13 pm
hi i'm about to embark on a the fuel pump mod to my 850 mk1. how can i check to see if the pump i bought works before i fit it. i've feed power through it and there is no noise or vibration. does there have to be fuel in the lines to get it pumping in the 1st palce. i know the power is getting through because i tested it with my electric screwdriver thats got a bulb in it.. oh the fuel pump is off a r6 98 to 02 model
#89 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 23 March 2012 - 07:32 pm
QUOTE(openroad @ Fri 23rd Mar 2012, 08:13 PM) <{POST_SNAPBACK}>
well not inpressed i connected it up with fuel lines attached and still nothing. so i've sent an email to the ebay seller stating a full refund
#90 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 27 March 2012 - 09:27 am
QUOTE(openroad @ Fri 23rd Mar 2012, 08:32 PM) <{POST_SNAPBACK}>
right sent 1st pump back and now had sencond pump delivered. AND GUESS WHAT thats one is knackard to. do people check before they post thes up on ebay. so on the hunt again for an other. will any other pumps work from other bikes.
#91 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 27 March 2012 - 10:23 am
QUOTE(openroad @ Tue 27th Mar 2012, 10:27 AM) <{POST_SNAPBACK}>
i'm sick of being messed around will this one work. i know it's not a yam oem part but it is for a 99-02 r6 i can pick this up 2morrow from hereford.
http://www.ebay.co.u...984.m1438.l2649
#92 Studley Ramrod
Posted 27 March 2012 - 10:45 am
iirc any pump off an R6 is ok so long as it's off a carb'd bike.
Are you sure you've got the right wires connected ? Seems odd that you've bought 2 non-working wans in a row. unsure.gif
#93 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 27 March 2012 - 01:08 pm
QUOTE(Studley Ramrod @ Tue 27th Mar 2012, 11:45 AM) <{POST_SNAPBACK}>
yer i followed the instructions on here. i checked the pump off the battery too. the 1st one i had, had current but would not pump and the second had nothing. got my refund for the 1st and now i got to send the second one back. to get a refund
quick question the pump should work with out any fuel lines connected. i should hear the clicking noise. right?
#94 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 28 March 2012 - 03:40 pm
QUOTE(openroad @ Tue 27th Mar 2012, 02:08 PM) <{POST_SNAPBACK}>
what the hell am i doing wrong. i've got the pump conected to the red and black wire that goes to the relay block on the left hand side of the bike i've put a 10amp fuse between the red and black wire and the pump. put the black wire to the negative side of battery there is a current flowing but the pump is not making a sound. WHY WHY WHY WHY IT'S A BRAND NEW PUMP
#95 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 28 March 2012 - 04:13 pm
scrap the above post i had put the fuel lines the wrong way round so it was thinking there was fuel and didn't need to pump. this could also be the problem with the 1st pump i bought.
ANYWAY note to people that are going to do this. conect the fuel line the right way round the pump must have a sensor in it that tells it to stop pumping when the fuel backs up to it.
nexts thing is i got to adjust the the float in the right carb because it is overflowing.
#96 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 28 March 2012 - 06:09 pm
ding dong the bloody thing is done. and wow there is a difference. was a bit boggy at low revs to start but gave it a bit of thrash and seams to have cleared it. think i'' have to put an inline filter because i there was some crap from in the carbs
#97 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 29 March 2012 - 12:44 pm
QUOTE(openroad @ Wed 28th Mar 2012, 07:09 PM) <{POST_SNAPBACK}>
fuel pump working well and i've adjust the floats a bit to stop it from leaking but the bike is idle-ing a bit high and i can't turn it down on the idel nob anymore. is there too much fuel getting through. it's a bit boggy and juddery around 2500rpm but once you pass 3000 it fine. do the fuel levels need adjusting and carbs balancing again.
#98 Studley Ramrod
Posted 29 March 2012 - 12:58 pm
Well, if there was too much fuel getting into the carbs then they would be flooding. Can you hear the pump pressure up when you turn the ignition on ? And does the pump stop when it's pressured up ?
Can't help much with the leccy pump as I've never fitted one. Might be better asking in the all about TDM section instead of the KB. smile.gif
#99 openroad
openroad
  • 175 posts
  • TDM model: 1994
Posted 29 March 2012 - 01:15 pm
QUOTE(Studley Ramrod @ Thu 29th Mar 2012, 01:58 PM) <{POST_SNAPBACK}>
yer the pupm is working well fills up and stops when full. if there was any residue of wd40 in the fuel bowls after i cleaned them would that cause a high idle.
#100 Margus
Margus
  • 133 posts
Posted 31 March 2012 - 01:49 pm
That little droplet on WD40 would'nt do that.
Edited by Margus, 31 March 2012 - 01:49 pm.
Work on my bike hasn't ended jet!
