1991 Tdm 850 Mk1 Project By Margus
177 replies to this topic
#81 Margus
Margus
  • 133 posts
Posted 24 January 2012 - 09:04 pm
More and more parts are geting back to their original position:
I also finally got my front sprocket off useing a pneumatic tool:
Now I have to figure out how to rethread the shaft.
Work on my bike hasn't ended jet!
#82 haffi
haffi
  • 75 posts
Posted 25 January 2012 - 03:42 pm
HEY !! youīve had the exactly the same problem as I have... Thank you for solving the first one for me (with the sprocket),,, Iīll guess I'll try the same with mine. Iīm very interested in what you will do with the shaft. Keep on posting ! hehe this is like being in school tongue.gif
#83 Studley Ramrod
Posted 25 January 2012 - 07:36 pm
If your changing the sprocket, don't use a JT sprocket. They don't fit the splines very well.
#84 Margus
Margus
  • 133 posts
Posted 25 January 2012 - 08:37 pm
QUOTE(Studley Ramrod @ Wed 25th Jan 2012, 09:36 PM) <{POST_SNAPBACK}>
Thanks for the tip!
#85 wicklamulla
Posted 25 January 2012 - 10:23 pm
Margus why did you have to grind the sprocket nut off ??
#86 3vd
Posted 26 January 2012 - 08:18 am
QUOTE(wicklamulla @ Wed 25th Jan 2012, 10:23 PM) <{POST_SNAPBACK}>
It was welded on. I'm waiting to see how the new one can be secured without welding.....
#87 dapleb
  • 18,385 posts
Posted 26 January 2012 - 08:23 am
QUOTE(haffi @ Wed 25th Jan 2012, 03:42 PM) <{POST_SNAPBACK}>
Quiet at the back.
QUOTE(Studley Ramrod @ Wed 25th Jan 2012, 07:36 PM) <{POST_SNAPBACK}>
wifgeni.gif AFAM is very very close if snot the same as OEM. If you donut want to repeat this grind off then oid also suggest licktight 638hawaii'5'O
#88 Matlock
Posted 26 January 2012 - 10:01 am
I used Renthal sprockets on my XTZ750, seemed a very good fit, but still used Loctite 638 too.
#89 Margus
Margus
  • 133 posts
Posted 26 January 2012 - 08:14 pm
Gear sensor is ready
How my TDM looks like right now:
Inside throttle housing:
By the way, I have an homemade exhaust on it right now and I started my TDM today- oh thease mighy sounds wub.gif
I hope to upload a video tonight.
Edited by Margus, 30 January 2012 - 06:23 pm.
#90 Margus
Margus
  • 133 posts
Posted 26 January 2012 - 09:29 pm
#91 eerik
eerik
  • 26 posts
Posted 26 January 2012 - 10:09 pm
Cover your paint with automotive clear coat, usually just paint are soluble with petrol. Try it you see it...
Its not necessary to use heat resistant paint, engine will not heat more than 60-70c And almost any quality paint will withstand to that temperature
And its common then you tune your carbs removing a fuel tank or just drop your bike usually you will get fuel spills on engine and it will screw all your paintwork! I made that mistake did not checked before!
I like your gear gauge on rpm gauge.
And its pretty much impossible to re-thread correctly your output shaft on engine, not much space to work on. I would put new sprocket and weld sprocket nut back. You will forget about problem for 2-3 year at least. for that time I bet that you will buy newer TDM wink.gif or overhaul your engine, then will be a time to work on your output shaft
And also forgot to tell that replace your output shaft seal then you will weld sprocket back, so you dont have to worry after, that oil will disappear from that place
Edited by eerik, 27 January 2012 - 08:21 am.
#92 MadAd
MadAd
  • 137 posts
Posted 26 January 2012 - 11:01 pm
What a rebuild!!
Go with the GREEN, it looks a similar shade to my MG do an image search for "MG biomorphic green" and you will see what I mean!!
Hope you manage to get the output shaft thread sorted out!!
Makes me think I should be working on my MK1 road bike!!
Hillclimbing....
....It's an up hill struggle!!
MK1 TDM850 road bike, FZR1000 Genesis front wheel, 600 bandit rear wheel with a 160/60/17!! Half worn BT016's!!
MK1 TDM850 race bike, MK2 forks, FZR400RR swingarm and linkage R6 shock, 900 barrels, 11.5:1 Wiseco pistons n stuff
#93 Margus
Margus
  • 133 posts
Posted 30 January 2012 - 06:22 pm
As I'm away from home in collage, my brother helped me a little bit with my TDM as fiting tyre on my freshly painted rear rim and attaching it to swingarm.
He couldn't fit front wheel because I've lost my wheel spindle biggrin.gif Have to find it when I get back home.
Before I left I cleaned my front brake capipers and fited them to forks
Edited by Margus, 30 January 2012 - 06:22 pm.
#94 Margus
Margus
  • 133 posts
Posted 30 January 2012 - 08:32 pm
Loong waited video:
http://www.youtube.c...31cFAAAAAAAAAAA
Make sure to use good speakers to watch this video.
These "bangs" were made by using a kill switch
And if you are watching this video, press LIKE and leave a comment or add it to your favourites tongue.gif
Edited by Margus, 01 February 2012 - 08:11 pm.
#95 Margus
Margus
  • 133 posts
Posted 06 February 2012 - 11:19 am
I got home for the weekend, but didn't had much time to spend on TDM. I looked for my front wheel spindle everywhere, but could'nt find it- looks like I have to use lathe to make a new one. I also practiced a bit TIG welding:
Internals on my new exhaust:
Wrapped bronse mesh around the stainless steel mesh:
Added rock wool and something more:
Sorry don't have more pics
#96 Studley Ramrod
Posted 06 February 2012 - 01:34 pm
Engine sounds healthy and responsive smile.gif Exhaust sounds great ! cool.gif
Thanks for posting up the piccys !
#97 Margus
Margus
  • 133 posts
Posted 06 February 2012 - 09:33 pm
I have an idea on how to "rethread" my output shaft. If I have time, I will use 3D program to show you guys my idea.
#98 haffi
haffi
  • 75 posts
Posted 08 February 2012 - 01:52 pm
QUOTE(Margus @ Mon 6th Feb 2012, 11:33 PM) <{POST_SNAPBACK}>
#99 Margus
Margus
  • 133 posts
Posted 10 February 2012 - 09:25 pm
I did some basic 3D moddeling to show you guys how I'm going to repair my output shaft.
Threaded part of the output shaft must be grinded down to about 15mm. I think I'm going to grind a bit more actually, so that the wall of the bushing could be thicker. To grind the end of the shaft, I will start the engin and put in the 5'th gear, raise the rpm to about 2500 and use pneumatic grinder to grind the shaft. This ensures that shaft will be eavenly grinded and won't become oval.
This bushing will be made useing lathe. It will have M20x1,5 threading on the outside. Inside diameter has to be exactly the same as output shaft's end's diameter. And the bushing will be welded to the shaft.
When I begin the work I will make a lot more pictures and maybe eaven a new thread, which hopefully will get to KnowledgeBase section.
#100 vwtoby
vwtoby
  • 33 posts
Posted 10 February 2012 - 09:27 pm
nice build thread mate!!! keep it up
