Very Stuck Swingarm Bolt _ Drz400
113 replies to this topic
#81 dapleb
  • 18,399 posts
Posted 27 August 2023 - 08:09 pm
Stink oi found carb prob...
Pilot jet was "loose".
It just fell out instead of unscrewing (no force applied).
Cock badgers!!!!
Weirdly it was still in tut hole even though it looks like its been flapping around in there for a while.
Any suggestions? ಠ⁠︵⁠ಠ
It should look loike this (squiggly bit still deeply embedded in carb):
#82 steve27bha
  • 797 posts
Posted 27 August 2023 - 09:20 pm
I await Mr Henty's advice on removal technique.
I've an idea, but it seems a bit fraught with danger.
#83 dapleb
  • 18,399 posts
Posted 27 August 2023 - 09:39 pm
I think all attempts will have a good dose of that steve!!
R'kid is trying to convince me it can be done with watch makers reamers but I'm not so keen!!
I reckon these are the correct dimensions.
#84 Snowbird
  • 1,487 posts
Posted 27 August 2023 - 10:43 pm
Can you twat a torx screwdriver up it's rectum and undo with that, the brass should be soft enough to get a grip.
Easyout types will likely expand the brass and make it tighter.
#85 Catteeclan
  • 2,577 posts
Posted 28 August 2023 - 07:39 am
As snowbird, easy out with finger's only.
Bond/glue something into it.
#86 dapleb
  • 18,399 posts
Posted 28 August 2023 - 09:27 am
My Brian obviously did some thunkin while I did some snooing. Woke up and thought...how did it break there....only thing could be torque (def not) or vibration....ahhh vibration....loose...i couldnt be THAT lucky...so I got a suitably sized watchmakers reemer and.....
Tadaaaa.....the remains were not screwed in tightly and easily reversed out! Phewwwwwwww
So has been loose for a long while I suspect.
Thanks for suggestions chapsssss
#87 dablik
Posted 28 August 2023 - 10:13 am
Jolly thumpin daps, coulda been a nightmare..
#88 dapleb
  • 18,399 posts
Posted 28 August 2023 - 12:41 pm
All components dismantled now and individually bagged.
Have use of tiny ultrasonic so gonna do all the small bits and oubt too big (only carb body hopefully) will go in hot water for a soak.
#89 dapleb
  • 18,399 posts
Posted 28 August 2023 - 06:05 pm
Little buzzer buzzing the bits good. Just having initial tests with warm water while waiting for carb goo to arrive for cleaner and already shifting plenty of crud that carb cleaner spray missed.
Think with a bit of wriggling oil be able to buzz carb body too section by section.
#90 steve27bha
  • 797 posts
Posted 28 August 2023 - 09:46 pm
Stick it in the dishwasher on high?
#91 dablik
Posted 29 August 2023 - 07:44 am
Put it in a big yoghurt pot or some such with water/cleaner and put that in the buzzer, also with water.
#92 dapleb
  • 18,399 posts
Posted 29 August 2023 - 12:20 pm
I replaced it on Saturday as the pump failed in the old one....give it a lille time to settle in before adding boike parts. ʘ⁠‿⁠ʘ
Mmm yoghurt
#93 dapleb
  • 18,399 posts
Posted 03 September 2023 - 12:38 pm
This tiny ultrasonic doohickey is ace. I ran it with just water and it did a great job. The water started looking clear at the end of the process. Then i got special carb cleaner and a whole load more crud came out.
Carbs now beautifully clean and waiting for new pilot jet before rebuild....
#94 dablik
Posted 04 September 2023 - 07:57 am
Woopwoop  :good:
#95 dapleb
  • 18,399 posts
Posted 17 September 2023 - 03:27 pm
Nearly dare... just gotta plug hair box on boike...next time I see it!!
Attached File  IMG_20230917_155517_697.jpg   168.25KB   0 downloads
..and replace throttle cables...and put carb bacon.
And rebuild boike..but nearly dare. ¯⁠\⁠(⁠°⁠_⁠o⁠)⁠/⁠¯
#96 Favs
Posted 17 September 2023 - 06:21 pm
Nice clean up :good:
#97 Studley Ramrod
  • 19,373 posts
Posted 18 September 2023 - 06:40 am
:badgerrock:
Looks like new :)
#98 dablik
Posted 18 September 2023 - 10:07 am
Ooh lickety lick daps  :good:
#99 dapleb
  • 18,399 posts
Posted 18 September 2023 - 12:16 pm
That lille ultrasonic thing really worked well. Very surprised. All bits had multiple baths. I used just warm water to start which did great. Then added some specific for carbs goo to the bath and that shifted even more crud.
Oil let ewe know if it works when fitted.... Prolly 2025..ish
#100 dablik
Posted 19 September 2023 - 08:07 am
You'll have time to sparkle all the parts you've got by 2025  :)
