Time To Crack On!
294 replies to this topic
#81 Studley Ramrod
Posted 03 December 2017 - 04:11 pm
Well, they might set the carbs up but it'd prolly cost you a day's labour (£500)  Might as well have a go at doing them yourself first.
#82 Talltom87
Talltom87
  • 381 posts
Posted 03 December 2017 - 04:15 pm
Yeah. I might as well! Haha thanks.
#83 Talltom87
Talltom87
  • 381 posts
Posted 04 December 2017 - 07:27 pm
Still getting all the paint off the frame, taking its toll on my arms! Haha Ive resorted to paint stripper for the bits I cant get the wire wheel to.
Should of saved a few pennies to get it blasted! Haha never mind. Engines starting to look nice, cleaned half today when I got sick of the frame!
Engine so far
#84 Bjørge
  • 1,894 posts
Posted 05 December 2017 - 06:54 am
What are you planning for the engine ?
#85 Talltom87
Talltom87
  • 381 posts
Posted 05 December 2017 - 07:41 am
I dont know yet, if I can find a clear coat for engines, I might strip and clean it! Otherwise I think itll be easier to get a aluminium coat on it.
#86 dandywarhol
Posted 05 December 2017 - 10:57 am
Bike shops used to use Ford Silver Fox rattle can paint
#87 Talltom87
Talltom87
  • 381 posts
Posted 05 December 2017 - 11:23 am
Ill search the web for some of that then! Thank you.
#88 Talltom87
Talltom87
  • 381 posts
Posted 05 December 2017 - 04:00 pm
Ive cleaned up the swing arm, shock (does need painting but, darent separate it) and found a suitable bolt for the bottom shock bush. Now, Im going to start painting and rebuilding. Fingers crossed.
#89 Talltom87
Talltom87
  • 381 posts
Posted 06 December 2017 - 07:00 pm
Most of the welding is done. All, of I dont need another bracket for the number plate holder.
Ps, I’ve no idea why it’s upside down...
#90 Talltom87
Talltom87
  • 381 posts
Posted 08 December 2017 - 09:19 pm
It's a work in progress and will be evolving some more.  Was going the way of a rat bike but I went a bit "mad max" with it.
dlE5R6v.jpg?1
Frame is now black with some spot lights on the engine bars
tcdu79H.jpg?1
I feel the lights are too small for the cowl and so I need to fettle a bracket to get the 850 lights on and see what happens, they're pretty heavy compared to these so need a more substantial mounting.
The bike had many years of hard commuting so it's a little cosmetically challenged and wont be as nice as those above, but it turns heads, although maybe not for the right reasons ;)
I can’t modify my headlights, so I was wondering where you got these lamps from with the screen and also, how did you mount the speedo etc?
#91 Nog
Nog
  • 527 posts
Posted 11 December 2017 - 10:24 am
The lamps are simply ebay - search for Dominator lights and you'll get a big selection come up.
They come in chrome or black etc and are usually the standard size of a large headlight so fit nicely within 'normal' fork headlamp brackets.
I made a bracket that is simply a folded/twisted length of steel - you can just see it going up from the headlamp brackets and both the screen and speedo mounts off it.
The screen is off a Tiger 800 that I had a few years back.  I had a touring screen and this was the stock screen that I had spare.  I cut it down to a height I liked and it sort of worked.
I think the lights look a little small for the screen/screen to big for the lights, but I have a pair of 850 lights that will probably look better and I may try and weld up a bracket to use them in the future, but I'm ok with these at the moment.
Only trouble with the Dominator lights is they usually come with 35W bulbs in, but I replaced them with LED's bulbs and fitted the engine bar lights to get a better output.
#92 Talltom87
Talltom87
  • 381 posts
Posted 15 December 2017 - 10:59 pm
Thank you nog! Ill have to scan about then!
Ive finally had chance to start painting, the swing arm is waiting for a bit of flatting and last clear coat. Looking good so far, picture when finished! Then moving on to the frame.
#93 Talltom87
Talltom87
  • 381 posts
Posted 21 December 2017 - 07:56 pm
Frame is painted! Not the right colour, but it looks great! Love it. Just the engine to paint now, then it goes back together.
Whats the best glue for fairings etc? Q bond? I want to move the head lamp and need to make some tabs for it. And if that doesnt work, itll be different lights altogether, like nogs.
#94 madmopedracer
madmopedracer
  • 473 posts
Posted 21 December 2017 - 08:47 pm
mix acetone and abs plastic from scrappy car mirror shells ets and it makes a good filler bonder with acetone to melt the edges and plasterers fibba tape to strengthen  google it its much better than out the can fillers etc which just sit on top of the fairing it actually bond it
#95 Talltom87
Talltom87
  • 381 posts
Posted 21 December 2017 - 11:40 pm
Thanks, Ill have a scan in the morning!
#96 Talltom87
Talltom87
  • 381 posts
Posted 23 December 2017 - 07:09 pm
Has anyone ever changed the plugs on the wiring loom? Im just wondering what Id need? How many 6 pin connectors, 9 pin etc.
#97 Talltom87
Talltom87
  • 381 posts
Posted 03 January 2018 - 05:37 pm
Cleaned the engine and painted it today. Checked the valve clearances and compression. All looking great! Just need to put it back together and start making brackets for headlights and clocks!
#98 dablik
  • 10,892 posts
Posted 03 January 2018 - 06:04 pm
Good job Tom, engine looks lovley painted up :good:
#99 Swarf
Swarf
  • 314 posts
Posted 03 January 2018 - 06:44 pm
Ooh that's clean, nice job!!
#100 drewpy
  • 1,788 posts
Posted 03 January 2018 - 10:09 pm
silver lady :)
