I Admit Defeat With My 3Vd
110 replies to this topic
#81 Snowbird
  • 1,460 posts
Posted 29 June 2023 - 11:23 am
Nice one :good:
Now go and have a beer! :drinks:
#82 Grendel
Grendel
  • 232 posts
Posted 29 June 2023 - 03:26 pm
Nice one :good:
:drinks:Definitely
#83 leehenty
  • 5,321 posts
Posted 29 June 2023 - 04:03 pm
Well done you fixed it
#84 ramo
ramo
  • 1,189 posts
Posted 29 June 2023 - 04:53 pm
Well done that man :good:
#85 dablik
  • 10,893 posts
Posted 02 July 2023 - 04:28 pm
Woopwoop  :good:
#86 drewpy
  • 1,788 posts
Posted 02 July 2023 - 05:02 pm
glad you've found it.
It's always the last thing you change  ;)
I had a fault on my FZ engine change, turned out a faulty wire from pickup, even though it ohm'd out ok.
that took me 6 months to find
#87 Snowbird
  • 1,460 posts
Posted 02 July 2023 - 06:10 pm
To be fair why would you change anything else when you've found the problem? :lol:
#88 drewpy
  • 1,788 posts
Posted 03 July 2023 - 10:33 am
I know, like the thing you lost then found was always the last place you looked
#89 Grendel
Grendel
  • 232 posts
Posted 07 July 2023 - 08:51 am
Thanks for all the advice folks.
Out of curiosity what cheap monoshocks do folk recommend since apparently the original one cant be rebuilt :huh:
#90 Studley Ramrod
Posted 07 July 2023 - 10:17 am
Probably Hagon, not sure if Wilbers, M-Shock or others are more expensive though.
#91 curlylegend
curlylegend
  • 331 posts
Posted 07 July 2023 - 12:21 pm
I put a YSS on mine. Pretty pleased with it.
#92 dablik
  • 10,893 posts
Posted 08 July 2023 - 10:13 am
I would price up M shock and Hagon, not heard many complaints about YSS, Wilbers will be more expensive me thinks.
#93 Grendel
Grendel
  • 232 posts
Posted 10 July 2023 - 02:59 pm
:rant: :rant: :rant: :rant:
AANNDD! Its Fecked again!!!
Haven’t even taken it out for proper test run yet. Seems the main fuse has got a bit hot over the years and warped the connection, so you get random on and off depending on if you knock it and its too distorted now that the new fuse won’t make contact. So i guess cut wires and put in separate blade fuse connector with bullet clips since my soldering is crap?? .
Then to add more insult the fecking thermostat housing has just started to leak. Can i use something like radweld???
:isurrender: :isurrender: :isurrender: :isurrender:
Edited by Grendel, 10 July 2023 - 03:14 pm.
#94 dapleb
  • 18,386 posts
Posted 10 July 2023 - 03:23 pm
:rant: :rant: :rant Can i use something like radweld???
No.
Its most likely the silly design lid leaking. Either make a clamp ferret or try sealing the gap atwix lid and body.
#95 fixitsan
  • 4,850 posts
Posted 10 July 2023 - 03:46 pm
Thermostat housing is just probably the rubber sealing ring.
The housings can distort sometimes but if it's not excessive a new sealing ring sorts it
You can always just remove the thermostat to keep the pressure down on the inlet side, but it's a slower warmup and introduces a risk of overcooling in winter.
Edited by fixitsan, 10 July 2023 - 03:46 pm.
#96 Grendel
Grendel
  • 232 posts
Posted 11 July 2023 - 01:30 pm
Have ordered new sealing ring and thermostat since may as well change the lot.
Also couple of inline blade fuse holders to hopefully bypass the dodgy fuse issue.
#97 MickC
MickC
  • 432 posts
  • TDM model: 1995
Posted 11 July 2023 - 04:32 pm
Been  abit of a long journey but you stuck with it well done :badgerrock:
#98 fixitsan
  • 4,850 posts
Posted 11 July 2023 - 10:57 pm
+1, it's going to run on for years after this refurbishment. :good:
#99 Favs
Posted 12 July 2023 - 07:54 am
Epic tale of endurance  :good: :clapping:
#100 Studley Ramrod
Posted 14 July 2023 - 04:14 pm
  :wifgeni:
