Fast Idle Plunger Repair (TDM 900) [ie Cold Start ]
153 replies to this topic
#81 Moose
    Master Cake Baker
  • 3,312 posts
Posted 11 April 2011 - 06:31 pm
QUOTE(leehenty @ Sat 9th Apr 2011, 07:02 PM) <{POST_SNAPBACK}>
Done mine today, tried both bellows, GA18 and GA19, GA18 with the narrow neck snipped off at the fourth bump is just right. The advantage is that GA18 comes in fours. Stainless allen screws and spring washers to put back. Used aCf50 to lubricate.
Cut off FORTH bump near NARROW end, not the other end or you will ruin the job works a treat.
Mr Henty fitted this boot to mine yesterday and this morning was my 1st proper chance to test it and it is bang on, works absolutely fantasticly, Cheers again Lee
#82 Catteeclan
  • 2,551 posts
Posted 12 April 2011 - 06:05 pm
Aw bugga. I've got the GA19s now.
#83 treadman
treadman
  • 476 posts
Posted 12 September 2011 - 06:03 pm
it might have been mentioned before, the 2 pipes on the fuel idle plunger which one goes on top, the thick one or the thin one
Neil
#84 big dave
Posted 12 September 2011 - 07:50 pm
QUOTE(treadman @ Mon 12th Sep 2011, 07:03 PM) <{POST_SNAPBACK}>
Neil
Do the photo's on page 1 of this thread help at all?
#85 treadman
treadman
  • 476 posts
Posted 12 September 2011 - 08:05 pm
Hi Dave, the pics of the pipes are obscured ,can,t say for certain which goes where, i,m having a few probs and just need t know so i can get on and sort it,don,t know if the mechcanics that fitted the cylinder head , have done it right
Neil
#86 dablik
  • 10,890 posts
Posted 01 March 2012 - 07:01 pm
Done mine today banana.gif i managed to undo the cheesy screws using molegrips on the 1st screw so removed that one,,,the other was a bit more stubborn and for some reason i could'nt get any purchase on the 2nd with molegrips so i used an old screwdriver and my big hammer laugh.gif so did not have to take the radiator hose off at all,,,,,,put a red cable tie on the top cvoolant pipe to the CSM to remind me what went were as well,,,,all cleaned and lubed and screws replaced with stainless Allenheads,,,,,worse part of the job was putting the airbox back on the carbs ranting.gif
#87 hallrob1
hallrob1
  • 1,112 posts
Posted 13 July 2012 - 10:02 am
Is GA25 now the one I'm looking for? - of so I'll have a few spares if anyone's interested.
#88 leehenty
  • 5,314 posts
Posted 14 July 2012 - 02:09 am
QUOTE(hallrob1 @ Fri 13th Jul 2012, 11:02 AM) <{POST_SNAPBACK}>
I've just checked on their website an they've changed their stock numbering system - GA18 are brass nipples now..
http://www.prestwich...uk/hdwraccs.htm
yup looks like GA25 is the one
#89 chrisr
Posted 14 July 2012 - 10:55 pm
03.09 am !??
#90 hallrob1
hallrob1
  • 1,112 posts
Posted 07 August 2012 - 07:44 am
I've two spare rubber bootees (GA29) free to the first two replies - PM me your address and work will even pay the postage!
#91 dmmsta
dmmsta
  • 3,627 posts
Posted 07 August 2012 - 07:46 am
QUOTE(hallrob1 @ Tue 7th Aug 2012, 08:44 AM) <{POST_SNAPBACK}>
I'll take one if you still have spares...
PM'd my details.
#92 hallrob1
hallrob1
  • 1,112 posts
Posted 07 August 2012 - 08:45 am
QUOTE(dmmsta @ Tue 7th Aug 2012, 08:46 AM) <{POST_SNAPBACK}>
PM'd my details.
I've got your details - One on it's way tomorrow.
#93 dmmsta
dmmsta
  • 3,627 posts
Posted 07 August 2012 - 09:52 am
QUOTE(hallrob1 @ Tue 7th Aug 2012, 09:45 AM) <{POST_SNAPBACK}>
Gentleman & scholar...much appreciated !!!
#94 leehenty
  • 5,314 posts
Posted 08 August 2012 - 04:32 pm
QUOTE(chrisr @ Sat 14th Jul 2012, 11:55 PM) <{POST_SNAPBACK}>
03.09 am !??
working nights and it was quiet, although the internet is supposed to be work only and monitored, a sneaky remote over vpn link to my home machine and I'm on carpe biggrin.gif
#95 nav18tor
nav18tor
  • 596 posts
Posted 08 August 2012 - 09:28 pm
QUOTE(leehenty @ Wed 8th Aug 2012, 05:32 PM) <{POST_SNAPBACK}>
So, being new to TDM ownership, I am on a learning curve
Having only had the bike for a couple of weeks, all of which have been warm, I am unsure what to expect from my fast idle thing
Currently, when I start the bike, it starts and ticks over at a stable tickover speed, not a ""fast idle"
Is this as it should be?
He who dies with the most toys wins
No more 2007 in white
In it's place is a big blue FJR1300
Touring Portugal? this is the perfect base
#96 ChrisG
Posted 09 August 2012 - 09:17 am
The fast idle plunger generally sticks in the "fast" or cold engine position (makes sense as that's where it should be when parked), so if you've got a problem you'll know about it as the idle will be something like 2700 rpm
#97 dmmsta
dmmsta
  • 3,627 posts
Posted 09 August 2012 - 01:01 pm
If you're unsure when it's cold give the plunger a push (see LINK #1) - while sat on the bike it should move from right to left
  • Right being Fast Idle
  • Left being Normal Idle
If it's stuck on fast idle but idles at the correct rpm (~ 1200) then it's possible that someone has adjusted the tick-over.
If you start the bike 1st thing in the morning, and push the slider to the left the rev's "should" drop and the bike may stall, as you're essentially turning off fast-idle.
If it is stuck then see LINK #2 on a good fix - it may be worth just stripping it down either way to give it a clean...in which case have a word with Mr Henty and get a set of his CSM bolts to replace the ones that Yamaha made from taffy.
LINK #1
LINK #2
You'll need to register on JBX's site if you haven't already.
Also - Link #1 has decent picture of where the slider is for the purpose of checking.
Edited by dmmsta, 09 August 2012 - 01:02 pm.
#98 nav18tor
nav18tor
  • 596 posts
Posted 09 August 2012 - 07:27 pm
Thanks to both of the last post's authors
I suspect I have nothing to worry about, but will get in there with a coat of ACf-50
Am already signed up to the JBX site, it's a great resource
#99 dmmsta
dmmsta
  • 3,627 posts
Posted 13 August 2012 - 12:23 pm
Received this morning - fitting this evening.
Cheers again!
#100 DenH
DenH
  • 7 posts
Posted 23 February 2013 - 06:28 pm
My fast idle is stuck in the 'fast' position with the pin fully retracted so I will have ago at freeing it as per this thread.
Question is, does the wax-stat get damaged when the pin is seized in the 'in' position like this?  Does the pin punch a hole in the stat or cause it to crack when the expansion is prevented as it heats up?
Also, can the stat be tested when it is removed by dropping it in a jug of hot water, for instance and seeing movement?  Would be nice to know it is OK before reassembly.
Thanks in advance for any advice.
