Cam Chain Tensioner Checks on a 900
88 replies to this topic
#81 dandywarhol
Posted 23 October 2017 - 11:49 am
The automatic spiral one works fine with the modified (latest post 2006) longer tensioner body
#82 Ollyls27
Ollyls27
  • 26 posts
Posted 22 December 2017 - 08:50 am
Hi everyone i have a 2003 tdm900 witg 48k on clock, haven't even been out on it yet only ridden it home.ivr started it up today and got a little rattle on the over run so im think it will be the cam chain tensioner, so my question is do i replace for a new one fowlers want £140 or could i replace with a manual one off ebay? Link below
https://rover.ebay.c...tm/361964489338
#83 Hombre
Hombre
  • 449 posts
Posted 30 August 2019 - 05:16 pm
Replaced the CCT at the same time as doing valve shims.  I put in the later type tensioner.  Went to JBX's site for how to set it and site has disappeared!
2 questions:
Anyone know if JBX down is permanent?
To set the new tensioner do you pull the tag out directly or rotate and pull?
#84 Rallyist
Posted 31 August 2019 - 08:02 am
2 questions:
Link working https://www.tdm-yamaha.heliohost.org/
#85 Hombre
Hombre
  • 449 posts
Posted 31 August 2019 - 10:15 am
Thanks Rallyist.  Works for me too today.  JBX is a good repository of info.
The answer: just a straight pull out.  Did that and it set fine.
#86 EddTheDuck
EddTheDuck
  • 6 posts
Posted 03 January 2023 - 10:25 pm
So I am about to get this done on my 9 at the local Kawasaki dealership for mega bucks! Is it necessary for them to also check the timing hasn't jumped when thye do it or can I get away with just the unit replacement? Cheers for any advice received.
#87 Catteeclan
  • 2,577 posts
Posted 04 January 2023 - 07:10 am
When I did mine I got No 1 cylinder at TDC then changed them. The idea is the cam has less chance of moving as inlet and exhaust lobes are getting a bit of contact.
Once replaced always turn the engine over without plugs by hand before trying to start.
#88 trevini
trevini
  • 1,893 posts
Posted 04 January 2023 - 11:58 am
I vaguely remember doing the same when I did mine, but it was a long time ago back around 2006/7. Wasn’t the tensioner a recall? I’m pretty sure I didn’t pay for mine at the time.
Edit- just checked and it wasn’t. Only recall was for the tps.
Edited by trevini, 04 January 2023 - 12:01 pm.
#89 EddTheDuck
EddTheDuck
  • 6 posts
Posted 04 January 2023 - 09:59 pm
Thanks guys. I'm not totally useless with the spanners and have done various mundane bits myself before like pads, discs, oil changes, brake line replacement and chain and sprockets. However with an engine I am almost a virgin when it comes to stuff inside! I've only ever changed out the oil pump and removed a spinner on my lad's 125 Honda Grom! I'd rather shell out on the CCT job than mess it up!
