Valve Clearance Check
132 replies to this topic
#101 Robk321
Robk321
  • 28 posts
Posted 29 April 2020 - 03:29 pm
Yep that's what I don't want to happen. I do want them done properly. So what is the solution?
Just soak in penetrating fluid or helicoil and drill out if it snaps I suppose
Or just don't bother doing the valves and hope for the best.
I do love the bike though and want to keep it long term
#102 chrisr
Posted 29 April 2020 - 04:05 pm
Dont trust a Yamaha dealer to do it, I was charged a fortune by Putney Yamaha when I took my last bike in to have the valves done, they did as Dapleb says! Many years and miles later Mr Henty did it properly and told me the engine had never been apart! Robbing bastards! My bikes have never been to a dealer since.
Edited by chrisr, 29 April 2020 - 04:07 pm.
#103 dapleb
  • 18,396 posts
Posted 29 April 2020 - 04:20 pm
I searched for "valve clearance coolant" and it came up with a few old threads such as http://www.carpe-tdm...l=&fromsearch=1
I would keep applying penetrating oil and use someone with experience to undo rather than snap it.
No point in not doing it as the problem (of stuck tube) ain't going to fix itself.
Dunno where thee be but when all the lockdown is sorted someone ear ight be able to sort it for ewe.
Lettuce snow how you get on!
#104 Robk321
Robk321
  • 28 posts
Posted 29 April 2020 - 05:17 pm
Yes will do, thanks dapleb.
I'm in Cardiff South Wales
Heard good things about JTs in Bridgend, Yamaha dealer, but a very small family one with only 2 mechanics I think
#105 dablik
Posted 29 April 2020 - 06:12 pm
Rob clean it up with compressed air if you have, if not try a bycyle air pump, soak it with monkey pith for awhile, try a little gentle heat maybe, if needs you can always lift the rocker cover over the pipe ( after removing the radiator) for easier access, if you insist on having a mechanic do the valves strip all the plastics off before hand maybe... if you can follow the tutorial they are'nt difficult to do...i would not let a mechanic near mine, been down that road before "their all in spec sir"
Edited by dablik, 29 April 2020 - 06:12 pm.
#106 Robk321
Robk321
  • 28 posts
Posted 29 April 2020 - 06:39 pm
I know what you mean, I have done plenty myself so far since getting the bike, it's good to learn. Recently greased the rear links which was a pig with the frame sleeve seized. Took me about two weeks of trying.
Just a bit daunted by the valves.
Valve checks are the biggest pain in the ass on bikes imo. As you can't trust dealers to do them properly.
I have let bikes go before now when they were due. At least the tdm is 24k not 12k like loads of others.
Might get a Harley next when I retire as they don't need valve checks I think. I'll do pretty much everything else.
#107 Favs
Posted 29 April 2020 - 07:11 pm
Drybollicks :good:
#108 Studley Ramrod
Posted 29 April 2020 - 07:19 pm
Checking the valve clearances is pretty straightforward once the rocker cover is removed.  Adjusting them, if they need adjusting, can be a bit tricky though.
#109 Robk321
Robk321
  • 28 posts
Posted 29 April 2020 - 07:21 pm
Always wanted one just once... 😂
Edited by Robk321, 29 April 2020 - 07:22 pm.
#110 Alekre
Alekre
  • 31 posts
Posted 29 April 2020 - 09:49 pm
It would be nice to replace rubber gasket also.
#111 dablik
Posted 30 April 2020 - 04:48 pm
Do them Rob, my 1st time was a bit daunting but not really a problem, plenty of help on here.....
#112 Robk321
Robk321
  • 28 posts
Posted 01 May 2020 - 10:38 am
I will get them done somehow. I have decided with the bike on 21k and the manual saying 24-25, I am not going to worry about it until then.
This winter going to get the cold start mechanism working again, at the moment I have to move it manually. Also service the swing arm.
Everything is done then except the valves for many miles.
Edited by Robk321, 01 May 2020 - 10:38 am.
#113 AliG
Posted 01 May 2020 - 11:10 am
Contact Lee Henty on here. He does CSM kits with stainless steel bits to stop seizing. (username: leehenty)
Edited by AliG, 01 May 2020 - 11:11 am.
#114 boltonwill
boltonwill
  • 71 posts
Posted 18 January 2021 - 10:01 pm
hi i am attempting to do the valve clearances today on a 1996 4tx 850  and found that only 2 inlet valves are out of tolerance i need a 175 and a 185 shim where would be best place to get these from and also 1 shim was a 178 that i took out is this right
#115 dablik
Posted 18 January 2021 - 10:10 pm
Yes Will a 178 could be right,previous owner may have had access to original yam shims, you'll get shims on ebay but only in increments of 5..
#116 Dickiebig
Dickiebig
  • 180 posts
Posted 25 January 2021 - 10:44 pm
Got mine from dirtbikestores on eBay. Good price and quick tracked, free delivery.
D.
#117 Malky900
Malky900
  • 8 posts
Posted 18 February 2021 - 08:39 pm
Evening folks...tdm900 2004... I've checked the gap and I've got a quick question... If the gap is always meant to get tighter why do I have some inlet valves slack and will they eventually tighten enough for me to just forget about changing the shims.. I've attached a pic of the gaps... Cheers
#118 Catteeclan
  • 2,575 posts
Posted 19 February 2021 - 06:25 am
I know it's not a huge amount but as you're going to be sorting the tight inlet, I'd sort them all.
#119 Studley Ramrod
Posted 19 February 2021 - 10:10 am
:wifgeni:  Sort 'em all and have peace of mind. :)
Not sure that inlet valves are always meant to get tighter, as they run cooler than the exhaust valves.  Same as when they convert old motors to run on unleaded, they usually only do the exhaust seats as they tend to suffer more from the heat.
#120 dapleb
  • 18,396 posts
Posted 19 February 2021 - 03:17 pm
Gap doesn't always tighten. Agrozzle wid udders...do em all to spec while there.
