6039 replies to this topic
#101 Bjørge
Posted 23 July 2014 - 07:45 am
Pleased it by replacing knackered rear wheel / sprocket bearings on its friend the '96 CB500 so that they can again go for rides in the hot Norwegian summer  :good:
#102 Studley Ramrod
Posted 23 July 2014 - 11:04 am
Went for a cycle ride, which pleased my not yet bought TDM, as I saved some money towards buying it, probably. :)
#103 leehenty
  • 5,325 posts
Posted 23 July 2014 - 05:14 pm
cleaned mine ready for a run friday.
#104 TDMick
Posted 23 July 2014 - 06:16 pm
Commuted to work.
Any miles are good miles. :)
#105 sidestand
Posted 23 July 2014 - 06:23 pm
Dragged it out of the garage to put the Bagster tank cover on it
Contemplated fitting a Jockoiler, but realised I need a T piece & haven't got time to order one - so I'll take the Tutoro oiler I bought for Boy's bike over to France & fit that one while I'm over there
#106 hallrob1
hallrob1
  • 1,112 posts
Posted 23 July 2014 - 07:47 pm
topped up the coolant expansion tank after it overheated, boiled the coolant and spat some of its guts out of the overflow when stuck in traffic at 30 degrees, why o why does the fan come on so late on these bikes :dunno:
Sounds like the Radiator Cap - I hope they've gone down in price since I got mine
#107 arthurbikemad
arthurbikemad
  • 573 posts
Posted 23 July 2014 - 09:53 pm
Went to Loomies (local cafe) was HOT HOT HOT, loads of crazy super bikers in full leathers sweating like hell, not my idea of fun.  Eat too many chips and burgers :S
#108 Favs
Posted 24 July 2014 - 02:37 pm
Had a bimble about, saw an '08 900 out with his mate in Yarm.
Ended up going for Cod & Chips in Whitby via a lot of this......
http://vid773.photob...zps210af9ab.mp4
:good:
#109 arthurbikemad
arthurbikemad
  • 573 posts
Posted 24 July 2014 - 08:10 pm
Fitted my tyre pressure monitors from Garmin they work with my new 590LM sat nav, not as good as I had hoped and only read in BAR but hay, I don't drink or smoke so wanted to piss some cash up the TDM ;) who knows they may save me from a slow let down, not that I have ever needed a warning light to know I have a flat tyre! Anyway, tiz done.
36deg C here today, they only way to get cool and be cool was take a long slow ride on the TDM.
#110 dogard
dogard
  • 19 posts
Posted 24 July 2014 - 09:06 pm
went down to see a couple of mates in newcastle, 320miles in blazing sunshine and great roads A68. bike ran like a dream. does life get any better. global warming gets my vote.
#111 Staffy
Staffy
  • 223 posts
Posted 25 July 2014 - 12:50 pm
Today I ordered some SW Motech crash bars for the 9er.  A few days and they'll be on my doorstep  :good:
#112 g650xtdm
g650xtdm
  • 295 posts
Posted 25 July 2014 - 10:20 pm
Yesterday and today was my valve check adventure . . .
All the body parts are off being painted.  I had planned to take the forks off yesterday and change the fork oil, new front wheel bearings, and new headstock bearings.  But I also wanted to re-paint the radiator support, so I figured I would check the valves since I have no idea if it had been done previously (37K miles).  I was pretty much halfway there with the radiator support off, right?  I'm guessing it hadn't been checked and two intake valves were tight.  I was able to swap one shim over but needed the other so the job waited until today.  I had left the gears on and the chain on the gears, but apparently it slipped at some point because now it was a tooth or two off and the engine had moved from TDC at some point.  It got to the point that I had both cams out and I got it back to TDC  - but unsure which cylinder was at TDC.  50-50 chance I guess!  It seems I was lucky as it fired up fine.  Took the opportunity to take a hose to the radiator fins as they were clogged with bugs and then replaced the coolant and synched the carbs.
Oh yeah, I still need to do the forks and bearings . . .
#113 arthurbikemad
arthurbikemad
  • 573 posts
Posted 26 July 2014 - 09:04 am
Well kind of today, tried out new Scala rider G9 with sat nav, all those years with no nav audio as I thought why bother just look, much safer way to nav around town ;) maybe I can keep more of an eye on the road and the ever increasing number of nutters on the way to work!
Quick pic:-
And a pic of my eBay LED strip and LED reflectors, I have one at the top too, I wired a couple of diodes and a resistor to the stop and tail circuits so they run STOP/TAIL rather than just a tail light, looks cool at night and with my top box LED's too can see me for miles haha
#114 arthurbikemad
arthurbikemad
  • 573 posts
Posted 26 July 2014 - 09:49 am
Wanted to check my wheel bal after adding the big TPMS from Garmin, they clock in at 10g so wanted to see if it put the wheel out by much (ok ok so I know it would be 10g), anyway nothing really to see on the static test so left it as is.. happy days :)
TPMS = Tyre pressure monitoring system from Garmin, shown here on my 90deg valve.
#115 Bjørge
Posted 26 July 2014 - 02:12 pm
Finally got to do the valve shims - 93,000kms = +9,000  :rolleyes:
All of them out by -0.25 to +0.10, only 1 could be reused. Ordered 9 shims on ebay, going for a vacation  on tuesday & hope parts are in the mailbox when I get back.
One question, though: Will I notice any difference whatsoever, other than the good feeling of being a concious owner & appreciating the fact that cams & everything looked really fine? 2 inlet valves were at <0.05mm gaps, would maybe start leaking at operating temperature ?
#116 Reaper07
Reaper07
  • 31 posts
Posted 26 July 2014 - 03:29 pm
Treated the TDM with 2 new Avon Storm 3D tyres and gotta say I love them stick to the road like no other.
#117 arthurbikemad
arthurbikemad
  • 573 posts
Posted 29 July 2014 - 11:39 am
Gave the TDM a wash today, quick check over ready for a ride to the BSB at Thruxton.
#118 Favs
Posted 31 July 2014 - 10:54 am
Shattered, nay smithereened, by backing into a wall, one of the Wingrack indicator lenses.........................atop a drain, where some of the bits disappeared.....................Grrrrr.....looking for my sackcloth shirt.
Edited by Favs, 31 July 2014 - 10:55 am.
#119 Kalts
Kalts
  • 104 posts
Posted 31 July 2014 - 07:04 pm
Went for a ride to small, remote MOT station, mostly because the guy in my favorite local one is on vacation and to air out rain suit. Got massive amounts of almost tropical like rain, went through thunderstorm.
Time well spent, MOT done and got to see some old Russian iron the MOT guy has restored and rides, I did not know he is active biker. Rain suit aired? out.. at least it's not dusty anymore because of no use. Autumn is upon us :(
#120 dablik
Posted 31 July 2014 - 07:57 pm
New throttle cables arrived pm so fitted them and tested with a run up to Daves...fiddly bliddy job though..was noticed by mr supersonic ear to be a tad lumpy at low revs.
