* * * - - 2 votes
Midsummer Misfire.....help Needed : (
154 replies to this topic
#101 Studley Ramrod
Posted 14 August 2016 - 05:12 am
Have you read this Wiggers ?  http://www.carpe-tdm...?showtopic=2135
You might need the TPS replacing.
#102 wigwamclan
wigwamclan
  • 200 posts
Posted 14 August 2016 - 06:10 am
I think it'd been done as there's a recall letter with the maintenance docs but the numbers have all but rubbed off the TPS so it's hard to say for sure.
#103 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 14 August 2016 - 09:18 am
I just need to double check it with another meter to be sure it's not a foible of my meter
Doesn't that suggest that all your other meter related investigations would otherwise be invalid too?
I have a bullet in my toolbox.
I'll lend it to you.
You need to bite it.
http://www.carpe-tdm...ic=2135&p=19403
This is why I also suggested that you see if you could arrange a "swap out" with someone.
Time better spent fixing the motorcycle IMO rather than investigating multimeters and pointing at paperwork.
Edited by TYREDNGRUMPEE, 14 August 2016 - 09:36 am.
#104 wigwamclan
wigwamclan
  • 200 posts
Posted 14 August 2016 - 02:26 pm
You could be right but I don't have the option to try another so I think it'd be prudent to verify the meter is ok today before paying out £100+ just to find my TPS was OK all along... That is unless your paying ;)
#105 wigwamclan
wigwamclan
  • 200 posts
Posted 15 August 2016 - 02:57 pm
Can someone tell me what an 'Ignitor unit' is?....it's suggested in the manual as a possible fault
#106 fixitsan
  • 4,850 posts
Posted 15 August 2016 - 03:38 pm
You dont have an ignitor on a 2004 model, but a combined ignitor/injection unit....actually an ECU....
It lives behind the left hand upper fairing....worth reseating the multiway plug connected to it
#107 wigwamclan
wigwamclan
  • 200 posts
Posted 15 August 2016 - 05:59 pm
From bad to worse...think I've just blown my fuel injection relay whilst trying to check it! :istupid:
#108 fixitsan
  • 4,850 posts
Posted 15 August 2016 - 07:28 pm
Relays are pretty sturdy, maybe you only blew the FI fuse ?
#109 wigwamclan
wigwamclan
  • 200 posts
Posted 16 August 2016 - 01:47 pm
Done
just checked the TPS with another two meters an' it checks out good :um:
#110 wigwamclan
wigwamclan
  • 200 posts
Posted 16 August 2016 - 02:28 pm
I refit the relay and the bike starts and runs so that's a bonus yet when I checked it for continuity it failed the first test.......my head's getting a bit battered by it all :unsure2:
#111 fixitsan
  • 4,850 posts
Posted 16 August 2016 - 03:35 pm
Sounds like a faulty connector/spade on the relay, if not internally
Edited by fixitsan, 16 August 2016 - 03:51 pm.
#112 wigwamclan
wigwamclan
  • 200 posts
Posted 16 August 2016 - 07:04 pm
has anyone got a picture of a stater and it's wiring?
#113 dablik
  • 10,893 posts
Posted 16 August 2016 - 07:41 pm
Any good
#114 dablik
  • 10,893 posts
Posted 16 August 2016 - 07:46 pm
Or is it the Stator you need a pic of.....
http://www.emphu.eu/...1410-00-00.html
#115 wigwamclan
wigwamclan
  • 200 posts
Posted 17 August 2016 - 08:11 am
Perfect :)
#116 wigwamclan
wigwamclan
  • 200 posts
Posted 17 August 2016 - 02:35 pm
So, I just metered the stater from the plug to the Regulator / Rectifier and got 0.4 ohms on all three but the book says 0.18 to 0.28ohms...question is could the difference between the book spec' and the actual readings be caused by taking the reading from the plug and not the stater itself?
I also did the spark gap test which should be min' 6mm but was easy 20 or 30mm which would seem ok but the spark was pink instead of blue....is that normal?
#117 dablik
  • 10,893 posts
Posted 17 August 2016 - 03:02 pm
Here you go Wiggers, might help, dunno bout the spark plugs though..
#118 fixitsan
  • 4,850 posts
Posted 17 August 2016 - 11:23 pm
Measuring such a small resistance with anything other than a high performance meter is nigh on impossible.
Best test for a stator is with the engine running, set meter to read AC volts and check for a minimum 15v between every 2 of the three stator output wires, at idle
#119 wigwamclan
wigwamclan
  • 200 posts
Posted 18 August 2016 - 11:34 am
Right, checked the output voltage on the stater and got 20V for all three so appears to be no problems there but when I was looking at the cable routing pic in the workshop manual ('02 version as there's no '03 cable routing diagram in the '03 supplement) I noticed it showed a fourth relay under the tank (fuel injection system relay) that my bike ('03) doesn't have.
I'd already seen that the '03 supplement to the '02 manual showed a different, bigger connector for the starting circuit cut off relay when I tested it.
Question is have they incorporated both relays into the one unit?.........I ask 'cos when I did the check on this relay it failed the first test. I connected the battery as per the '03 supplement but got no continuity when I tested the circuit, yet the bike fires up no problem, to add to this, when I activate Diag tests 36 an' 37 I can hear the injection solenoids?
#120 JBX
Posted 18 August 2016 - 12:57 pm
Yes
