Carcoon Or Similar
151 replies to this topic
#101 ChrisG
Posted 04 October 2022 - 12:49 pm
Have you thought of replacing the car you're currently storing there with something more suitable?
https://www.boattrad...cher-x-8434126/
Summat weird going on the link there, these 2 are supposedly both the same link but open different pages for me.
Edited by ChrisG, 04 October 2022 - 01:37 pm.
#102 dapleb
  • 18,399 posts
Posted 04 October 2022 - 01:06 pm
Me wanty
#103 dapleb
  • 18,399 posts
Posted 07 October 2022 - 05:28 pm
Out 88%
In 58%
Got a new 3000w inverter for work van...so the 1500w old un is a bit fried but hopefully fixable.
I tested work van set up on dehumodifrier and it worked fine.
The tent isn't rapidly reaching outside humidity so have hope that occasional dehumidifrying will help.
#104 Snowbird
  • 1,487 posts
Posted 07 October 2022 - 05:39 pm
What have you got in there that needs looking after?  (sorry too lazy to read back, and a bit drunk...) You may be better off with a solar panel connected to a pc case fan and a bit of ducting and lashings of acf50 with the extra ventilation.
On my boat I have a small solar panel inside the glass hatch connected to a pc fan inside a mushroom vent and it's always dry inside when I get there and that is on something with it's arse sitting in a cold river, ventilation may be the key for low power options, in a naturally damp building it will likely take more moisture out than it brings in.
#105 dapleb
  • 18,399 posts
Posted 07 October 2022 - 06:09 pm
Designed for mushrooms SB so very good at staying damp. There are air snorkels through roof, if left open it makes very little difference maybe take off 5% if sunny and add 15% when not! When the industrial fans worked that link up to the snorkels the suction on that would lower humidity by 20% in 30mins on a dry day.
Larry the bampton rat had a good idea put his camper van already loaded with solar panels up to lock up wall and drilled through to his lock up. ◉‿◉
#106 leehenty
  • 5,326 posts
Posted 07 October 2022 - 06:34 pm
Heat up acf 50 in hot water put it in an air spray gun, bag the discs etc and off you go. Buying ACF50 in 1 gallon cans is the cheapest way.
Edited by leehenty, 07 October 2022 - 06:42 pm.
#107 Studley Ramrod
  • 19,373 posts
Posted 15 October 2022 - 03:47 am
Out 88%
In 58%
:good:
#108 dapleb
  • 18,399 posts
Posted 15 October 2022 - 07:22 am
:good:
The van test was only a brief test. I retested for longer (4mins) and the dehumidifier runs initially but then comes up with an error. I retested with diff dehumidifier and it came up with an error. Hoping that this is because new van inverter is not pure sine wave. If that's not the problem then I'm sunk before even starting a solar project.
Out 90
In 65
#109 Studley Ramrod
  • 19,373 posts
Posted 21 October 2022 - 04:30 pm
65 is ok yeah ? :unsure2:
#110 dapleb
  • 18,399 posts
Posted 21 October 2022 - 05:19 pm
Not too bad but slowly working its way ooop.
Electrical dept have fixed me old van inverter so can hopefully do some testing. They are also not convinced that a solar panel and a coupla leisure batteries will get me much dehumidifryin.
#111 fixitsan
  • 4,856 posts
Posted 22 October 2022 - 06:53 pm
Out 90
In 65
If you're handy with a soldering iron it's easy to build a square to sinewave convertor, with 3 resistors and 3 capacitors. The only catch is the cost of the correctly rated power resistors and capacitors can be pretty high it's probably not worth it unless you buy secondhand components, but 'quality issues'
#112 dapleb
  • 18,399 posts
Posted 23 October 2022 - 01:02 pm
The old inverter that is now fixed is pure sine wave so that should be ok..at least for test.
Elec dept have lots of crapassitors and things though so I will pass on info ta. Might mean I can then utilise the van as a generator every now and then. ◉‿◉
#113 dablik
Posted 23 October 2022 - 02:22 pm
daps oi think you better sweet talk Tish for bike space in the kitchen  :)
#114 dapleb
  • 18,399 posts
Posted 23 October 2022 - 02:27 pm
She wouldn't mind at all. We already discussed hanging a hodaka off a beam in there. (‿)
#115 dablik
Posted 23 October 2022 - 04:46 pm
:lol: problem solve then, in part  :good:
#116 dapleb
  • 18,399 posts
Posted 29 October 2022 - 04:50 am
Out 95
In 73
Leisure battery on the way.
#117 dapleb
  • 18,399 posts
Posted 02 November 2022 - 10:02 pm
New leisure battery arrived. Ran dehumidifier for 36mins before running out of juice and lowered hum from 73% to 61%. So there is some hope here.
#118 ChrisG
Posted 03 November 2022 - 09:50 am
Can you rig a solar panel or wind turbine on the roof to top it up, and some kind of switch to run the dehumidifier when the battery is between certain voltages?
#119 Snowbird
  • 1,487 posts
Posted 03 November 2022 - 10:55 am
Voltage sensing relays are freely available, I have one on my boat I can run a spare fridge (beer) when engines are running or shore power plugged in but not killing batteries when off grid and not running, I think I set it to about 13.6V on and 13.0V off, switches up to 140A if memory serves me right, they make a very cheap split charging setup for campers and the like.
#120 dapleb
  • 18,399 posts
Posted 03 November 2022 - 03:39 pm
Yeah summat loike dat cwis. Leafing inverter permanently on will drain battery a bit bit hopefully not too much.
Do you have a linky dink please SB?
