#1221 fixitsan
  • 4,855 posts
Posted 10 January 2016 - 02:47 pm
I found out that a piece of 80mm x 30mm wood about 3 feet long is  perfect to chock up the rear end when You have Givi Wingrack2 fitted....it slips under the rack at both sides and over the tyre.....made removing the shock without a centrestand a doddle
Edited by fixitsan, 10 January 2016 - 03:36 pm.
#1222 sidestand
Posted 10 January 2016 - 03:00 pm
I got myself an Abba stand for Christmas  - both wheels off my Mk2 now ready to get new tyres fitted (PR3's )
Time to get that scottoiler fitted as well methinks - it's only been on the garage shelf for 2 years  :rolleyes:
#1223 fixitsan
  • 4,855 posts
Posted 10 January 2016 - 03:38 pm
The one I took off my FJ is still on the shelf and needs fitting.
It's in my forum description of the bike that it has a Scottoiler fitted, but it actually hasn't.......Such a fraud
They're well worth it though aren't they. When I was a courier I swore it was the best investment I'ld made
#1224 tediumwannabe
tediumwannabe
  • 198 posts
Posted 10 January 2016 - 04:32 pm
Refitted the rear wheel and new tyre PR3 £90 mytyres.co,uk (£10 fitted, balanced, by Stuart @ Adlington Tyre Fitters nr Chorley, Lancs, don't know the guy personally but highly recommended, decent bloke) after cleaning the inner swingarm, shock, axle etc.
Fitted much heavier YZF600 bar end weights (used, £10 fleabay) after tapping out the Renthals with an M16 x 1.5 tap (£6 fleabay again) then cutting off 12mm at each end of the bars, for the shoulder on the YZF jobbies.
I've had problems with excessive hand tingles in both hands in as little as 10mins riding so hope this will solve the issue, if not i'll be looking at head bearings, wheel bearings etc and anything else that may be causing the problem although there's no vibration that I can feel through the bars...............
#1225 chrisr
Posted 10 January 2016 - 06:40 pm
Grip puppies help
#1226 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 11 January 2016 - 10:48 am
Started preparing my standard rear shock for some cake-balancing pre-load adjustment.
Penetrating oil etc.
The rear isn't working well with the beefed up front end and my current weight.
Thought the task through, considering the necessary spring compressors, C-spanners, work benches etc. and thought I'd better see if any soul here has had any success.
So apparently not.
So instead, next w/e, I will be mainly saving my time, knuckles and money (for a new shock instead of tools), by dropping the front end a tad to match the current, cake induced rear end sag and increasing the damping by a click or two.
Hopefully finding a suitable temporary middle ground and buying me some time to shed a few kilos.
IMG_20160110_131834261_HDR_zpsynzstgyw.j
Tipp-Ex mark for my base damping setting.
#1227 PassTheBuck
PassTheBuck
  • 539 posts
Posted 11 January 2016 - 11:54 am
Put the key in and started her up, first turn  after 4 weeks,  love her and hope to win the lotto soon so I dont have to sell
#1228 TDMick
Posted 11 January 2016 - 04:54 pm
Started it.
Ran it, nearly dropped the bloody thing moving it around in the front garden.
Taxed it.
Connected the solar charger to my 850 to see if it will carry the battery.
Need to check the 900 electrics to see what current is being drawn by the alarms, clocks etc., when it's turned off.
Anyone know offhand how much juice a datatool alarm draws?
Edited by TDMick, 11 January 2016 - 04:55 pm.
#1229 tediumwannabe
tediumwannabe
  • 198 posts
Posted 11 January 2016 - 06:41 pm
Grip puppies help
Cheers chrisr, I've had some spongey convex things on for a while but they haven't helped. I'll see how the mods go and if there's no change i'll give these a go too on top of regular grips.
#1230 fixitsan
  • 4,855 posts
Posted 11 January 2016 - 09:08 pm
dropped my rear shock off for refurbishment at Dunfermline Motorcycles.
The guy there has huge experience with everything from road to motorcross bikes and confirmed what i thought about adjusting preload for my weight (16-17stone)  adjusting the preload just sets up your static sag, but the amount of 'bounce' you feel with a spring that is too weak for the rider's weight (mine is on the limit) is too much and means less than great performance.
A new uprated spring will improve it , but they're not cheap. I thought about going for a new shock with correct spring, but just can't afford it right now.
#1231 Matlock
Posted 11 January 2016 - 09:21 pm
Fixed a broken wire feeding the horn. I only found out this evening that it had stopped working when a numpty moved across as I was overtaking them :shocked:.  Nothing malicious, I just think they fancied a change of view from the wagon they had been following for a while. I suspect the mirrors fitted to their car were purely decorative, I had to remonstrate with them through the medium of mime  :rant:
Anyways, the wire had broken at the spade connector at the horn. I fitted a Stebel Magnum some years back and extended the feed. I was clearly a bit over zealous with the crimping tool  :isurrender:
#1232 fixitsan
  • 4,855 posts
Posted 13 January 2016 - 03:51 pm
Picked up the rear shock from Dunfermline and fitted it.....such a difference, and a great service from DM
Details here - http://www.carpe-tdm...showtopic=32655
Going to look at the forks next, at least change the oil...giving the calipers a once over at the same time
#1233 fixitsan
  • 4,855 posts
Posted 14 January 2016 - 09:00 pm
Broke the front end down to refresh fork oil.
Found the Yamaha engine bars are great support points for axle stands.
Fork oil was dirty....flushed them out and draining now....some uneven front pad wear caused by a couple of dirty pistons. Getting a full set of pads all round for the hell of it.
Steering head bearings are good, repacked them with grease
Wheel bearings are good but got few stuck brake disc bobbins to work at.
#1234 fixitsan
  • 4,855 posts
Posted 16 January 2016 - 04:12 pm
Got the forks back together with fresh oil. Serviced all 3 calipers and fitted new pads, stripped the front wheel down to check bearings and give it a clean. Freed up all disc bobbins, and put it all back together again.
Damn the snow because i couldn't road test it !
#1235 sidestand
Posted 16 January 2016 - 04:50 pm
PR3's fitted & Jockoiler fitted - plus a little shakedown trip to Melton Mowbray & back - bloody cold !!
Then I remembered the gritters have been out   :shocked:     So a very cold session washing down. [note to self - get some FS365 in the week]
#1236 JBX
Posted 16 January 2016 - 04:56 pm
Too cold to ride and it's snowing outside...  :sorry:
#1237 Latestarter
Latestarter
  • 676 posts
Posted 16 January 2016 - 06:55 pm
A busy 6 weeks recovering from the knee operation, HID headlight upgrade, Airblade screen, handguards, finished off today with crash bars & centre stand from Rafal at RM-G in Poland and the new Givi E22n panniers. Just waiting on the footplate to come back from powdercoating and I nearly ready for the good weather.
Not sure on the location of the spotlights though, might send a message to leehenty and pick his brains on some of those extended mounts I've seen on other posts?
#1238 Thorshammer
Thorshammer
  • 6 posts
Posted 17 January 2016 - 10:45 am
Fat bar and Rox risers
Edited by Thorshammer, 17 January 2016 - 10:45 am.
#1239 fixitsan
  • 4,855 posts
Posted 17 January 2016 - 07:15 pm
Drove to the Royal Burgh, to collect a couple of disc bolts kindly donated by Steve27. Caught sight of his very immaculate TDM900 which is going to put mine to shame !
Cheers Steve ☺
#1240 Gasman
Gasman
  • 483 posts
Posted 17 January 2016 - 08:39 pm
Like the seat latestarter. Is it one of those polish ones or did you have it done locally?
