#1321 RolfieB
RolfieB
  • 1,069 posts
Posted 13 February 2016 - 09:13 pm
Absolutely nothing.
But my Bird benefitted from an oil & filter, coolant, brake & clutch fluid change.
Fitted bar risers with new preload adapters & new fork springs with fresh oil. Well the r/h leg got fresh oil. The head on the socket cap screw (allen head) seems to be mullered on the l/h leg. So am unable to replace what looks like ATF in that leg.
Not to sure how to proceed with getting this out.
Ideas please.
Hope it's okay putting this in this thread. If not I'm sure it will magically disappear.
Edited by RolfieB, 13 February 2016 - 09:14 pm.
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
#1322 ramo
ramo
  • 1,194 posts
Posted 13 February 2016 - 09:37 pm
Rolfie
post a pic of whats mullered  :good:
#1323 fixitsan
  • 4,855 posts
Posted 13 February 2016 - 10:03 pm
Is it 5 or 6 mm when it isnt knackered ? A bolt extractor with reverse thread might grab it ?
#1324 RolfieB
RolfieB
  • 1,069 posts
Posted 13 February 2016 - 10:07 pm
Will check in the morrow when I have round 2 with it :putemup: . Can't remember off the top of my head if it's 5 or 6mm.
Wondering if I can get a hex head key on it & then my battery powered rattle gun :dunno: .
Failing that I have some extractors but I wont be to good drilling into said bolt. Always seems to go pear shaped.
Edited by RolfieB, 13 February 2016 - 10:09 pm.
Gone to new owner.
Black Mk2a
#1325 fixitsan
  • 4,855 posts
Posted 13 February 2016 - 11:25 pm
I just thought if it was an allen head it might be deep enough to get an extractor in without drilling.....failing that, try tapping the head around, with a sharp chisel on the outer edge of the head , that sometimes works
#1326 fixitsan
  • 4,855 posts
Posted 13 February 2016 - 11:31 pm
Fast forward to 2:20.... maybe you can chip in to the head without damaging the yoke (too much)
#1327 RolfieB
RolfieB
  • 1,069 posts
Posted 14 February 2016 - 08:07 am
Unfortunately the bolt is recessed in the leg, so don't think that's an option.
I suppose if all else fails I can try & drill the head off & remove the damper rod.
Gone to new owner.
Black Mk2a
#1328 sidestand
Posted 14 February 2016 - 09:12 am
Should be the most reliable thing on yer GS now! :good:
:P   -   Thirty thousand miles with nothing changed except oil & tyres .........if we exclude the replacement crash bar, head cover, clutch lever, & switch - but that was my fault  :rolleyes:
#1329 fixitsan
  • 4,855 posts
Posted 14 February 2016 - 09:38 am
A picture would help. You're saying the screw is into the fork leg ?
#1330 jono49
jono49
  • 1,183 posts
Posted 14 February 2016 - 12:19 pm
Yes where the axle bolt goes through....an utter tvat if rounded off.....alway's hit it with a hammer first!!!!!!
#1331 fixitsan
  • 4,855 posts
Posted 14 February 2016 - 02:48 pm
The axle bolt clamp bolt ?
#1332 jono49
jono49
  • 1,183 posts
Posted 14 February 2016 - 04:49 pm
No uphill from there! straight through the bottom of the fork base, it holds the damper rod in!
Edited by jono49, 14 February 2016 - 04:50 pm.
#1333 RolfieB
RolfieB
  • 1,069 posts
Posted 14 February 2016 - 06:15 pm
Correct. I did try to give it a quick tweak to tighten before attempting to remove. Couldn't get a decent photo of the offending bolt.
Rattle gun failed. Tried smacking a torq or larger hex head bit head into it, to no avail. Hole is not big enough to whack a socket onto it.
Wont be able to have round 3 until 26th due to work commitments.
At which point I'll be breaking out the drill.
Gone to new owner.
Black Mk2a
#1334 fixitsan
  • 4,855 posts
Posted 14 February 2016 - 07:15 pm
There's a RH leg on ebay for 30 right now. ..but cant see a left...
If all you're doing is changing the oil can't you take the leg out and invert it
Edited by fixitsan, 14 February 2016 - 07:18 pm.
#1335 jono49
jono49
  • 1,183 posts
Posted 14 February 2016 - 09:13 pm
If it isn't totally chewed up?....another option is use a slightly over sized Torxs bit and hammer it in using an extension, then try your luck? I have had a resonable success rate with this technique :good: But not a 100%
#1336 ramo
ramo
  • 1,194 posts
Posted 15 February 2016 - 07:07 am
 jono don't think the holes big enough for a bar and socket, think I used a long allen key
#1337 fixitsan
  • 4,855 posts
Posted 15 February 2016 - 07:23 am
Any room to go in with a welder ? Have in the past cleaned up a hex key and managed to give it a touch with mig wire.....enough to keep it locked to turn it.
#1338 RolfieB
RolfieB
  • 1,069 posts
Posted 15 February 2016 - 05:12 pm
I had hoped to get a small 1/4 drive socket (I think it was 11 or 12mm) whacked on to it, but the size required is to big to get into it.
I did try with a Torq head bit on a small 1/4 socket & extension bar but had no joy. Resigned myself to drilling head off I think.
Yes I could remove the leg & up end it to drain the oil. But I would still have to address the problem, so may as well just get on with it.
You can just about see the head of the bolt looking through the hole for the axle. Wouldn't think it would be cost effective to get someone to mig weld a hex key onto it.
Charging drill tonight & hopefully as the nights are drawing out a bit I may be able to do it in 1/2 hr stints over the next couple of nights. I will endeavour to take a decent photo so all will become clear.
Once the head is drilled off, hopefully I can unscrew the stud off the damper rod.
Appreciate the input guys.
Gone to new owner.
Black Mk2a
#1339 leehenty
  • 5,325 posts
Posted 15 February 2016 - 09:30 pm
Cleaned, polished and greased my niner ready for the MOT.  :)
#1340 chrisr
Posted 16 February 2016 - 12:33 pm
Wonder if it will pass?
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
