Stolen Again ! Found Again !
147 replies to this topic
#121 Studley Ramrod
Posted 02 October 2010 - 08:05 am
I'm still researching my security options and browsing assorted painful deterrents smile.gif I'm not gonna post up what they'll be though fer obvious reasons.
Been looking at bolt croppers, for £100 you can buy a set that'll cut straight though 13mm High tensile and 19mm steel ! This is what I'm up against.
So, a combination of wood, metal, noise, lighting, nails, glass, razor blades and a sprinkling of novelty sprung-loaded chav-traps should do for starters.
I still think the best way to go is to prevent the thief from seeing the security one has in place, this way, they can't do a reccy and return tooled up at a later time.
#122 idlebloke
idlebloke
  • 554 posts
Posted 02 October 2010 - 08:09 am
Can you not squeeze a shed in Ian??
Or even better 'something' brick built? Woouldn't cost much if you know a decent brickie....
#123 Saga Lout
Posted 02 October 2010 - 08:15 am
Wish I could think of something original to say but many others have beaten me to it. Until our tosser politicians start standing up to the do-gooders and start imposing serious punishment for wrong-doers then things will only deteriorate more. I'm not the greatest fan of many things Muslim but its funny how this sort of thing doesn't happen in places like Saudi?
Once again, really sorry SR and hope you stick around and get back on two wheels soon
#124 Bobajob
Bobajob
  • 506 posts
Posted 02 October 2010 - 09:45 am
High level 500 watt mounted PIR operated floodlight
Stebbel Magnum or similar linked to movement of the bike in some fashion
CCTV camera pointed at the subject.
Create one almighty Motherf*%*"n racket, enough to waken the whole neighbourhood.
1997 TDM850 MKII - Yamaha/Krauser panniers, Nexxus,cut down screen No Screen!, Osram nightbreakers, PR2s, Interphone F4. Missing her already and on the hunt for a newbie!
#125 SelinaXC
SelinaXC
  • 264 posts
Posted 02 October 2010 - 10:36 am
Get some french windows put in and keep her in the house. Not that the TDM won't come through a normal door, the 9er does in winter, but it is too much of a pain for a daily exercise.
Tiger 800XC in black & WR400F rider, cohabiting with two TeDiuMs, a Mk1 and a Mk3.
#126 Guest_Catteeclan_*
Guest_Catteeclan_*
Posted 02 October 2010 - 02:54 pm
These can't be easy to get off.
http://www.webbikewo...isc-lock-alarm/
#127 stu
stu
  • 2,060 posts
Posted 02 October 2010 - 04:21 pm
QUOTE(Studley Ramrod @ Sat 2nd Oct 2010, 09:05 AM) <{POST_SNAPBACK}>
Have you look at the Almax chain link I posted?
#128 SelinaXC
SelinaXC
  • 264 posts
Posted 02 October 2010 - 04:29 pm
QUOTE(Catteeclan @ Sat 2nd Oct 2010, 03:54 PM) <{POST_SNAPBACK}>
Got one of these and its very sturdy, nicely finished, confidence inspiring bit of kit and appears difficult to remove for someone who's not a nefarious thieving git, fairly loud and so far the batteries haven't failed after around 18mths, though I think they advise changing around 9months. Use this as one of a number of security devices without going so over the top can't be arsed to unlock her. Essentially cheap alarm, Xena on the front disk, chain and lock front wheel to the TDM and a hefty motorax lock through one of the rear sprocket holes locking the back end too.
Need to get a reliable ground anchor really tho.
#129 dablik
  • 10,893 posts
Posted 02 October 2010 - 04:34 pm
With stu on the almax chains,,, its a hefty bit of kit and some interesting stuff on their website,,,, just wish it was on Bigred and not littlered,, i use in conjunction with a ground anchor,,, they are a bit expensive,, but i guess there worth it.
#130 muddy
Posted 02 October 2010 - 04:39 pm
I've got two of these. They might be alright if kept dry--I wouldn't know. If left out in all weather, they quickly corrode and the alarm won't work. Batteries don't last either and the alarm makes all sorts of annoying noises when this happens. I only use one as an alarm for when I'm travelling. I keep that under my seat.
#131 Bobajob
Bobajob
  • 506 posts
Posted 02 October 2010 - 10:44 pm
This link (if it's true) goes to show that there are scum who will go to a lot of bother to nick your bike just for the hell of it.
Linky
No profit, no malice, no revenge, no f*ck"n idea! The detritus of our nation.
#132 Guest_leehenty_*
Guest_leehenty_*
Posted 02 October 2010 - 10:52 pm
Ian,
Sending yer a new oil pressure switch as a donation, 'cos the barstuds burnt the other one.
That is of course if you are getting another 850.
Hangings too good for them.
As to the trip wire with the shotgun er blank,they are quite good we use them for the Pikey's round here.
Lee H
Edited by leehenty, 02 October 2010 - 10:55 pm.
#133 idlebloke
idlebloke
  • 554 posts
Posted 03 October 2010 - 08:30 am
QUOTE(Bobajob @ Sat 2nd Oct 2010, 11:44 PM) <{POST_SNAPBACK}>
Linky
I like what this bloke has done!! I assume he must have got names first and then did the Facebook tracking. Be great to have advance warning of who is 'at 'it in yer own area!!
#134 Studley Ramrod
Posted 03 October 2010 - 10:26 am
Cheers Bob, very interesting. I've got a name or 3, if anyone wants to search facebook ?
I noticed the chavs used pneumatic bolt croppers so a chain aint gonna stop 'em. Not a problem as I've found summat a lot stronger smile.gif
When you think that all the chavs have to do is read the details about the chain and then they know they need a pneumatic device to break it.
Even though MCN and others couldn't break it with bolt croppers it doesn't give me any confidence in the chain.
Edited by Studley Ramrod, 03 October 2010 - 10:30 am.
#135 Fernihough
Fernihough
  • 588 posts
Posted 03 October 2010 - 06:11 pm
Studley,
I have been thinking a lot about you and your misfortune. I have felt like discussing it with my friends and colleagues because I can't get my head around what happened to you. Two successful attempts to steal you bike in a month. On both occasions it is found within walking distance of your house. The bastards didn't really use it apparently. My conclusion is that the intention is to piss you off rather than steal you bike. It looks too personal.
Before buying a new bike and fitting lethal devices, don't you think that you seriously need to review your neighbourhood or go an make peace with whoever is pissed off with you?
I am fortunate enough to live in an area where you can wake up in the night and think "I'll wait for tomorrow morning to go and check if the garage door is locked". But without expecting the safety level of people on the 50s (when cars were not fitted with anything else but a push button to start) I can't believe that you have to accept it as the norm that you must baricade yourself. If you secure the bike, will they burn it in your garden next? There must be some things you can do with your local police or even with your neighbours?
I don't know if this helps but I sincerely wish you to find some solution which will not increase your justified bitterness...even if you have to move!
Ferni
PS: this is my 500th post. I waited to post it over the past few days because I was reflecting on my contribution to the forum. This post will confirm that I sometime come accross with a different angle. I don't know if this means that I do not belong but I take the risk to bore a few of you because I enjoy this forum too much rolleyes.gif
Darwin theory in action - Natural evolution from 4 legs to 2, from 4 wheels to 2
Yam DTR125 / Yam TTR250 / Blue TDM900 2005
Fender extension; Right miror extension; Tutoro oiler; Frank Thomas leather Bullit Retro Jacket with Knox back protector for normal time and textile jacket with forcefield 4 for long trips, monolock plate with E45 GIVI top case, Michelin PR2
#136 Daveb
Daveb
  • 1,907 posts
Posted 03 October 2010 - 06:27 pm
I think MCN have removed the link dry.gif I did have a look at it earlier
2007 Triumph Tiger 955i
#137 Studley Ramrod
Posted 03 October 2010 - 07:03 pm
QUOTE(Fernihough @ Sun 3rd Oct 2010, 07:11 PM) <{POST_SNAPBACK}>
Studley,
Ferni
FFS ! Cheers for that !
#138 aircooled68
Posted 03 October 2010 - 08:39 pm
Studley them pic's are heartbreaking..... really gutted for you fella sad.gif
Think you done as much as you could(chains/locks)there just F kin gobshi*es
if ya need anything just let us know... or if you get a name and you need a lift
Edited by aircooled68, 03 October 2010 - 08:41 pm.
#139 catsbum
Posted 15 October 2010 - 06:18 pm
In thinking with Studley and the removal of his bike I have now completed my security measures.
Locked Steel Shed
Alarmed Disc Lock
Talking movement alarm
Oxford High Security Chain
High Security floor bolted anchor
All finished and fitted this evening.
Yamaha Immobilisor
If the feckers get past all that I will give them my helmet n gloves and wish them a safe journey.
Any news on your insurance Studders?
#140 ChrisG
Posted 15 October 2010 - 06:22 pm
I reckon one of these on the garage roof should do it. As an added bonus it should stop the cats crapping on my lawn
