Mk1 Spluttering In 2000Rpm Range
137 replies to this topic
#121 Studley Ramrod
Posted 16 June 2017 - 06:08 pm
NRP Carbs sell them.  http://www.nrp-carbs...product_id=2061
#122 Victor
Victor
  • 30 posts
Posted 24 June 2017 - 06:33 pm
Are NRP reliable? Over a week since i paid and no answer? Tried to email a few days ago, no answer. Order still says processing if i log in.
#123 Studley Ramrod
Posted 24 June 2017 - 08:46 pm
Yes, they've always been reliable.
#124 Sidarta
Sidarta
  • 845 posts
Posted 25 June 2017 - 01:53 am
I Think i have found the problem!  :drinks:
After a few comments on the youtube video i thought that i needed to double check my choke plungers. This is what i saw. The other one is much better but i also suspect the rubber gaskets from litetek, they are to chubby so they want to pop out.
So now im going to order new choke plungers!  :good:
Hi Victor
Good to know that you have encountered the problem.
Cheers!
Att
Sidarta
TDM850 ano 2001
 Honda XLX 250 1988
Honda CB350 1972 e 1973
#125 Victor
Victor
  • 30 posts
Posted 04 July 2017 - 03:05 pm
Alright! New plungers fitted, and the popping/backfire where reduced. So I went out for a test ride, and now we have a new problem.
When i accelerate, the bike wont pull so hard that im used to. Its sound like its running to fat. If you just cruise you wont feel it, maximum throttle it feels weak and rough.
My local repair shop want around 500 EUR for the job. Thats about 1/4 of the whole bike. The guy at the shop said that i should put all the original part back to the carburettors and start from there. So I am now thinking of putting the original main jet back and resetting the float height to original. The problem is i wont remeber the float height, its now 15mm (factory pro method). But des anyone know if that is leaner och richer than original?
#126 Studley Ramrod
Posted 04 July 2017 - 03:40 pm
I would put the original sized main jets in there and reset the fuel level.
Probably better to measure the fuel level as there is a reference to the measurements required in the Haynes manual.  If you remove the carbs to set the fuel levels, remember to tilt the carbs at the same angle they would be when fitted to the bike before you take the measurements.
Have you fitted Factory Pro needles ?  If so, are they stepped ?  If they are, you might struggle with them.  They're really designed to work with a tuned engine.
#127 mh1848
mh1848
  • 507 posts
Posted 04 July 2017 - 10:10 pm
3 turns out didnt solve anything, cant even tell if it got worse och better.
Im starting to wonder if the float height is to lean (15mm)? Because even if the bike is hot it will rev upp a lot, over 3000-4000 rpm if i pull out the choke maximum.
Here is a new video from today.
I hope its okay to post in your thread.
you mention  a couple of times float height - but 15mm is more like the Mk2 than the Mk1 which is 7.4-8.4mmAttached File  carb fuel height.jpg   60.24KB   0 downloads
or are you  measuring the floats with the bowls off?
#128 dapleb
  • 18,385 posts
Posted 05 July 2017 - 04:47 am
For fuel level, there I!s often no casting on the carb as Heinz suggests.
For float height, make sure you are basing measUre off the correct float-----they are different! 15mm dont ring a bell either.
#129 Studley Ramrod
Posted 05 July 2017 - 08:38 am
Think it's only the mk2a carbs that don't have a casting mark.  Seem to remember that 14mm was the float height.
#130 Victor
Victor
  • 30 posts
Posted 05 July 2017 - 12:41 pm
Okey!
Now I have tried to read the fuel height by the Haynes book.
From what i understand the carburettors height is! Left 7.8mm Right 7.1 mm.
So the right one is slightly low, but not a disaster! Will double check with the engine runnin a little bit, just to make sure the bowls are full.
The Picture in the Haynes manual is not so accurate but it must be the line that crosses the round things in the bottom?
Next thing will be to try lower the main jet back to original.
Edited by Victor, 05 July 2017 - 12:41 pm.
#131 dapleb
  • 18,385 posts
Posted 05 July 2017 - 01:38 pm
I think there were diff markings even on mk1. And the marking that was on em did not match with Heinz pic or suggested heights. Remember was chatting about this with Dandy 10 odd years ago. he might remember more.
Set mine by float height. 13mm from rectangle float.
#132 Victor
Victor
  • 30 posts
Posted 05 July 2017 - 02:00 pm
Hold your horses!
I found something! When I started the bike to fill the bowls the right carburettors needle wasn´t lifting when I pulled the throttle. I was probably to eager to try the bike when the choke plungers where installed that I din´t care about the diaphragms
to be in 100% right position (also changed needle clip position).
Now some food and then test ride!
#133 dapleb
  • 18,385 posts
Posted 05 July 2017 - 02:56 pm
I have my horse. go have your cake. :-)
#134 Studley Ramrod
Posted 05 July 2017 - 03:37 pm
Ah right, wasn't aware of that Daps. :good:
Hold your horses!
Could also be because the carbs need balancing, if it's not the diaphragm.
#135 Victor
Victor
  • 30 posts
Posted 05 July 2017 - 05:05 pm
Thank you for all the help! Its now running better than ever.  :lol:   :good:  :clapping:  :pimp:
The problem was!
First: worn choke plunger + that they didn´t fit perfect with the rubber gaskets. = the popping. New choke plungers, back with original rubber gaskets. = solved the popping.
Then I created a new problem by myself by not fitting the diaphragm on the right carburettor, so the bike was basicly running on one carburettor and just idle om the other.
Edited by Victor, 05 July 2017 - 05:06 pm.
#136 Studley Ramrod
Posted 05 July 2017 - 06:57 pm
:badgerrock:  Liking the celebratory donuts. :)
Congratulations on persevering with them, they can really test the patience. :lol:
#137 dapleb
  • 18,385 posts
Posted 05 July 2017 - 09:42 pm
Well done. And saved 500 euros.... More cake funds.
#138 Bjørge
  • 1,894 posts
Posted 06 July 2017 - 06:41 am
Congratulations !  :tup:
