Winter Project
405 replies to this topic
#121 Coxylaad
Coxylaad
  • 517 posts
Posted 13 December 2018 - 09:12 am
I might get some heat on it. the ally will heat up way quicker that the steel. Will just have to make sure I stay away from the bearings.
being lazy here, what size rawl bolt is used?
What a stupid design. I might just chop through it on the inside and and let it float like every other linkage I have seen.
#122 dablik
  • 10,893 posts
Posted 13 December 2018 - 09:26 am
Another link with some size info of the rawl bolt, but i think you need to buy a particular type as not all of the same size fit.
One more link, he used a counter sunk screw for his, last link honest :D
Might not actually be as bad as some others coxy with a bit of luck.
Edited by dablik, 13 December 2018 - 09:28 am.
#123 Coxylaad
Coxylaad
  • 517 posts
Posted 13 December 2018 - 08:54 pm
Sorted. Applied some heat, hit it with a hammer, it came straight out! So fast I didn't get to take any pictures.
I've also knocked out those spacers in the frame for the front engine mounts. They were corroding away and although they would still work I didn't like the look of them. I'll turn some more on my lathe
#124 dandywarhol
Posted 14 December 2018 - 10:03 am
There is something critical with those engine mounts with regard to setting/torquing up to avoid vibration from memory
#125 Coxylaad
Coxylaad
  • 517 posts
Posted 14 December 2018 - 10:06 am
i'll find out soon enough!
#126 Coxylaad
Coxylaad
  • 517 posts
Posted 17 December 2018 - 08:50 pm
I have just checked my valve clearances.
I am going to contact TTS who installed the cams and did all the engine work because either they are specifying different clearances or this is going to get expensive!
this is what I measured:
E1 007, E2 007, E3 007, E4 008
I1 008, I2 008, I3 008, I4 007, I5 008, I6 007
way way WAY less that the factory specification of  0.15  to 0.20 mm on the inlet and 0.23 to 0.28 mm on the exhaust
so either this is by design or I need to replace every shim on the head
edit, oh my god what a windalicka. I bought myself a new set of feeler gauges and was looking at the imperial measurement...that's embarrassing  :good:
so. according to all the information from Kent I can glean from the web they are within spec.
Edited by Coxylaad, 17 December 2018 - 10:08 pm.
#127 Bjørge
  • 1,894 posts
Posted 18 December 2018 - 07:02 am
By god, when are you gonna scrap those imperial units......? :-)
#128 PICARD
  • 1,786 posts
Posted 18 December 2018 - 07:31 am
^  +1..................will we still be allowed the metric system post Brxxxxxit??
#129 dablik
  • 10,893 posts
Posted 18 December 2018 - 08:52 am
:lol: glad you spotted that...
#130 Studley Ramrod
Posted 18 December 2018 - 10:34 am
:lol:  We all get the odd brain fart on here. :D
#131 fixitsan
  • 4,850 posts
Posted 18 December 2018 - 10:55 am
Probably when 1 minute of latitude stops being worth 1 nautical mile, and 1 degree stops being worth 60nm :)
#132 Bjørge
  • 1,894 posts
Posted 18 December 2018 - 12:40 pm
Now, THAT is a poor argument! No reason why one should stick to sloppy units like nautical mile, even if it is somewhat related to earth size. Why not kms at sea? Nevertheless, let sea be sea without stopping you from entering the enlightened world.....(have no emojis at hand)
#133 fixitsan
  • 4,850 posts
Posted 18 December 2018 - 01:15 pm
Sverdrup and Nansen seemed to manage just fine on the old units. I suggest that you man up. :)
#134 curlylegend
curlylegend
  • 331 posts
Posted 18 December 2018 - 02:42 pm
I heard that was the cause of one of the Space Shuttle crashes.  One supplying firm using (American) Imperial measurements and another using  Metric......?
#135 Rallyist
Posted 18 December 2018 - 03:27 pm
The problem with people that advocate the usage of the Metric system is the can't count past ten so can't cope with statements like "I will take a dozen please" and other things in this vein  :hide:
#136 Hombre
Hombre
  • 449 posts
Posted 18 December 2018 - 05:35 pm
English = dozen.  Spanish = docena.  French = douzaine.  German = dutzend.  Norwegian = dusin. Chinese = 打.
English = inch.  Spanish = pulgada.  French = pouce.  German = zoll.  Norwegian = tommers.  Chinese = 英寸
"In 1783 the British inventor James Watt, who was having difficulties in communicating with German scientists, called for the creation of a global decimal measurement system, proposing a system which used the density of water to link length and mass..." Wiki.
So, not only are British measures universal but the metric system is British too. :oldgit:
The Greeks did introduce the Helene though, which is the unit of feminine beauty required to launch 1 ship. :yeyeye:
#137 Bjørge
  • 1,894 posts
Posted 18 December 2018 - 06:33 pm
Well, I'm kinda lucky as I very rarely have to cope with other than metric units. It's mainly when communicating with you guys and most often MPG vs l/100km fuel consumption. Then I frequently meet the US Gallon vs IMP Gallon problem, and because the yankees regularily don't remember that other definitions of gallon exist (you're outnumbered, of course, but I suspect that's not the entire reason) this is a real PITA.
Norwegian also use a few odd measures, like "Favn" (2 meters high, 2 meters wide and length of 0.6 meters = 2.4m3) of wood (fuel) and....and.....and....no, I don't think there are any more  :P
...but of course, we have the ÆØÅ letters.... :lol:
#138 Studley Ramrod
Posted 18 December 2018 - 06:42 pm
Do you have thee most important measurement on the planet Bjorge, the pint ?
#139 Bjørge
  • 1,894 posts
Posted 18 December 2018 - 06:54 pm
Nope, we're doing "halvliter", that's half a liter - 1.05668821 pints !
meaning we get 5.66% more drunk than you  :good:
#140 Hombre
Hombre
  • 449 posts
Posted 18 December 2018 - 08:19 pm
No you don't. Half a litre is 0.879877 of a pint in the UK.
You only get more drunk than Americans. :munching_out:
