Prowler
#121
Posted 29 October 2025 - 10:22 am
#122
Posted 30 October 2025 - 03:38 am
I was going to put the forks and wheel back in yesterday but remembered that when I took the brakes off the calipers were reluctant to let go of the discs, so I thought I'd better sort those out first, I expected to have to rebuild the calipers with new seals but after examining them I found they were really gummed up with filth,
I had removed the front braking system all intact so I pumped the brake lever to get each piston to move outward by clamping all but one piston at a time, I used some contact cleaner and got each exposed area of the pistons as clean as I could (no corrosion), afterwards all the pistons were able to be pushed fully back into the caliper by finger pressure, one took a bit more effort than the others so I will rebuild them sometime in the future, but for now they are ok,
I gave the caliper bodies a really good clean as well with some strong soapy water and dried them all off with a hairdryer,
doing the brakes took way longer than expected but it's another job done on the way to being done ![]()
#123
Posted 31 October 2025 - 03:37 am
I took advantage of a dry and windless day to make the exhaust down pipes look better (I polish outside)
due to their design of joined together and narrow spacing between each pipe getting into all areas to polish was a challenge, after starting on the most visible areas it was soon obvious that in reality as far as looks go, these original pipes are past their best, they are 'peppered' with stone chips and to totally remove them would require so much metal removal that they would end up being almost half the thickness of the tubing,
knowing this I accepted to just make them look better, it still took a long time and I know that heat will discolour them again, but initially they'll make the overall look more pleasing when the bike is finished,
maybe in the future I'll be able to purchase some better pipes from a low mileage model, there are currently none available on ebay that are better than mine and the price is too much for my budget, after market ones are available but only as a 2 into 1 system and I want to keep the 2 into 2 set up
before and after
123.jpg 98.51KB
0 downloads
#124
Posted 31 October 2025 - 08:45 am
#125
Posted 02 November 2025 - 05:05 am
I thought the before picture was an after picture....thought that's not bad...then scrolled doon. Noice.
thanks, I know they will go brown again as they are only single walled tube, but hopefully will still look better, for a while anyway ![]()
as I had the forks out already I thought I may as well give them an oil change, the oil seals are still good with no sign of leaks but I don't know when they last had fresh oil,
due to my wrist problem I really need the front end to be very soft to stop shock waves transferring into it and making the ride uncomfortable, they were super bouncy which is good for me but maybe not so good for higher speed handling, I could've bought some 5 weight oil but as I don't have spare money for such things (vet keeps stealing it) I just used what I already have which is half a litre of 5w and a litre of 15w, I mixed my half litre of 5w with half a litre of 15w which should give me something like a 10w, but from previous readings of fork oil weights and people mentioning their differing weights even when they are listed as the 'same' weight I will see how it feels when I eventually get to ride it again, it needed changing though as the stuff that came out looked like thin brown paint,
I also noticed that the top dust seal was quite corroded, luckily I had a new pair in my '''I've absolutely no idea where that part came from''' box that fitted, so I fitted them,
I cleaned up the forks and put them back onto the bike along with the front wheel and brakes, it took a bit of time working out how the routing of cables should go but I think I'm there now,
the downside was that once the forks were back in it was obvious that my previous attempt to allow the cable loom to be pushed back through the frame when the left fork touched it was not as good as I'd hoped, it does move back but it does not do so completely freely, the last inch of turn needs a bit of extra help, not a lot and this may not even be noticeable when riding and full turn isn't often used while riding anyway, I find that full turn is mostly used when moving in or out of parking spots etc.,
if it shows as a problem when the bike sits on its own two wheels again (today) I do have another idea of how the improve it, I'll probably experiment with it regardless ![]()
#126
Posted 03 November 2025 - 03:12 am
I removed the front mounting bolt for the air box and then turned the steering fully to the left, the air box lifted slightly as the loom was pushed back into the frame, while in this position I checked the rubber inlets on the fuel injector bodies and they were good, so I put a small spacer under the front of the air box (8mm) and fitted the bolt back, now the steering moves much more freely, I wish every problem could be sorted in such an easy way,
the footrest hangers were a bit scruffy in places and I contemplated removing them to give them a full polish up, but remembering how condensation builds on my bike surfaces at times over winter I knew that they'd grow a full coating of white fur quite quickly, so I opted to just use autosol and a cloth to tidy them up to an even but dull shine, looking nice and ease of future cleaning is good for me now,
I used new exhaust gaskets and fitted the downpipes back on the bike, however now it is starting to look too nice to want to start the engine and risk ruining it all, best try and sort out those end cans soon !
123.jpg 82.2KB
0 downloads
#127
Posted 08 November 2025 - 12:15 pm
I've been working on my silencers which were a lot more involved than I imagined, they were both a bit tatty but the right hand one had damage from the crash which needed sorting out,
first of all I had no chance of fixing the damaged strap at the front of the silencer, I do have some on other silencers that I could use the straps from but the holes don't line up, that would mean the holes show through the gaps in the strap, so I need to think of something different,
I thought about just cutting some solid strips of stainless to make the strap but then thought about something different, if I change one then I have to change all 4 for looks,
in my 'store' I have a corrosion coated brass container or whatever, I don't remember where it came from but it will do the job, so I marked out and cut 4 equal rings,
once they were cut out I ran them over my deburring wheel to remove the corrosion, then put them aside as I work on the other bits,
next step was to totally disassemble both silencers, then I did some work on the damaged right hand one, the front link pipe area was damaged beyond straightening so I had a choice of cutting out the damage and welding in new metal or make a cover plate, I chose cover plate for simplicity as I doubt the actual damage will cause any difference to the bikes modest power output,
I also noticed that some cracking had occurred where I previously welded the link pipe to the silencer, so I made a cover plate and welded it in place and welded over the cracked area,
all welds were then ground down along with a bit of grinding on the crash damaged lettering to try and smooth that out, I'll never make it perfect as the scrapes are too deep,
after grinding the welds the areas were given a first stage polish,
it was always my intention to shorten these silencers so the next thing I did was to remove the 'FUEL' logo badges and mark a line around the silencer just short of the rivet hole for the logo, I mark an equal length line on the inner tubing and cut away the unwanted areas and smooth off the edges,
when both silencers were cut I could make a start on making the new brass 'straps', it was not as easy as I anticipated as I found the brass quite hard to bend evenly, stainless is quite predictable in the way it bends but brass seems to bend like cardboard, it resists at first and then just lets go at a certain point which creates kinks which are undesirable, so I had to bend it a little at a time until it was sufficiently bent that I could use tape to hold it in place on the outside of the silencer tubing, then I was able to mark where the holes need to be (round tube would be easier),
once I had drilled all the holes I used small bolts to attach it to the silencer tubing and make any adjustments that might be needed before messing up on the rivet process,
when I was happy with everything I wrapped fresh baffle material around the inner tubing, I used tape to hold it in place as it just wanted to fall straight back off again, then I slid the outer sleeve over it and into position, then the front ends could be riveted back together using the brass straps,
then the rear caps could be re-attached and also riveted back in place with the brass straps,
next step was to give both silencers an over all polishing, and when that was complete I taped up around the lettering and gave the TDM lettering a fresh 'brushed' finish,
now they are finished to my acceptable standard I wanted to fit them back on the bike, but the connecting clips on front of the link pipes broke
, now I have to make new ones
brass container of some sort, equal rings cut out and cleaned up
1.jpg 70.63KB
0 downloads
making good the link pipe area
2.jpg 89.66KB
0 downloads
cutting down to size
3.jpg 111.87KB
0 downloads
making brass straps, reassembly, basic polish up
4.jpg 75.38KB
0 downloads
before, after finishing
123.jpg 67.04KB
0 downloads
Edited by laughin in a windstorm, 08 November 2025 - 12:26 pm.
#128
Posted 08 November 2025 - 12:25 pm
#129
Posted 08 November 2025 - 12:36 pm
more and bigger pictures with explanations can be seen on my face book page, I had to start a 'part 2' album and for some reason uploading pictures to it now puts them in the wrong order ![]()
https://www.facebook...99515635&type=3
Thats a nice job with the brass.
thank you, I thought I might try adding a bit of class to my crazy style ![]()
#130
Posted 10 November 2025 - 03:34 am
I fitted the silencers back onto the bike and inserted the baffles, I can't be doing with straight through's anymore as they drown out the natural ringing in my ears,
time to start it up and have a listen, wuhh............wuhh............wuhh.............wuhh, I think I drained the battery while sorting out the indicators, headlights and horns ![]()
#131
Posted 10 November 2025 - 09:54 am
#132
Posted 12 November 2025 - 02:48 am
I sorted my minor bump with a day on charge with my little optimate
, it started up and sounded great, although it was still constrained in my shed so it should be quieter once out in the free world,
there was a smell of burning and a bit of smoke but it soon passed, it was just the assembly grease and instant gasket I used to create seals and to hold the exhaust gaskets in place, I left it running and it got quite hot very quickly but it did drop the revs after a while so I know my 'fast idle' fix has worked, my downpipes have already gone a golden colour but then I knew they would, but it's alive again,
so now with little else to do I decided to give my paintwork a light rub down and polish up, I got the rubbing down done but it got too cold to do any polishing up again so that may happen today ![]()
Edited by laughin in a windstorm, 12 November 2025 - 02:49 am.
#133
Posted 17 November 2025 - 08:56 am
so it's now a battle with the cold for me,
I have managed to finish my paintwork, I rubbed it all down with a 2000 grade wet abrasive paper, my spraying area is not the most ideal for perfection straight from the gun, so it needs a bit of help to remove slight imperfections that can stick to the wet clear coat, things like dust, small hairs and magpies etc., also I usually rub down the surface so no underlying colours or graphics can be felt, but with this one I had to put on six coats of the orange to get it to be one shade as it is a bit translucent, this makes it quite a thick layer and if I rub down enough to lose their raised edges there is a risk of removing all of the clear coat, so to be able to lose the raised edges I would have to spray more coats of the clear on and to be honest I can't be bothered
all I am after is just a smooth feel and with the very slight raise to the stripes,
once it has been rubbed enough with the abrasive I can use a compound polish to start bringing up the shine again, it is quite a long process but very therapeutic in a mind numbing sort of way,
once that is done all that's left is a good wax to remove the final swirl marks
tank in process of rubbing down (if you look close you can see dark untouched by the abrasive areas beside the stripes)
rest of panels rubbed down
1.jpg 80.4KB
0 downloads
tank and mudguard nearing end of bringing back the shine
2.jpg 71.66KB
0 downloads
all parts finished, fender extender fitted and seat panels reassembled
3.jpg 101.71KB
0 downloads
Edited by laughin in a windstorm, 17 November 2025 - 08:58 am.
#134
Posted 26 November 2025 - 03:38 am
still struggling with cold temperatures but I have made a start on my last item which is the handlebars, I just need some time where my joints are free to move and my mind to engage, but not necessarily together ![]()
#135
Posted 02 December 2025 - 08:02 am
Well done, a lot of effort so far, dont know how you find time between the cooking, cleaning, washing and hoovering ![]()
Sorted and on the Road Mick
#136
Posted 02 December 2025 - 08:36 am
thanks, it's quite easy when you're a God............................................................................................................................................unfortunately I'm not one, but the dogs lick everything clean ![]()
#137
Posted 03 December 2025 - 09:35 am
so this is most likely the last item to make, my handlebars, and they are probably the most involved,
I have high rise renthal's on at the moment and they are very close to what I need, but I have literally almost no side movement in my wrist which means that to be comfortable I need to lean back to allow my arm to straighten which in turn rotates my wrist, so to sit comfortably I need just 10mm of more 'pullback',
so the only way I can be sure they are right for me is to make my own, I did try bending a set of renthal's once but they don't bend predictably, they tend to create a curve along a straight length which is not good for switch gear and throttle tubes
to start with I need to know the basic dimensions, this isn't too hard as the existing bars are close, I don't have anything in the way of tube benders so my bends will be 'sharp'
I draw an accurate image onto a sheet of coated mdf, and then I cut some scraps of wood that will be used to contain the tube I will be using,
I start with the bottom part and screw the wood on with angles cut to give guide lines when cutting the tube, I bought some 22mm stainless steel tube for this purpose,
when the wood is in place I put the tube into the gap and cut the angles with a cutting disc in a grinder, I use masking tape to hold it still and stop it from spinning when the disc hits it,
next I cut and fit wood to the outline of the 'raise' parts and fit a length of tube into each side with 'square' cut ends at the lower parts, I cut the angles at the highest part but leave the lower part for now,
next I cut and fit the wood for the longest parts that will have the switch gear etc. on, now I use a piece of tube slightly longer than needed (just in case) and cut the angle,
now the raise sections and the switch sections meet nicely so I chamfer the joining edges to ensure weld penetrates fully into the thickness of the tube (2mm),
to weld them without distortion I clamp the pieces down by screwing another piece of wood over the tube, the tube is slightly thicker than the wood frame,
I then weld the visible joins,
with the first parts held solidly together I can work on the 'pullback', I need 100mm pullback at the widest part of the bars, so I measure the length needed for the controls plus a bit to give my overall desired length and cut off the excess,
with the raise part of the bars still clamped down I can force the ends up and set them at 100mm from the base, I use a piece of wood under each end to keep them from moving,
now I cut the angles on the lowest parts to meet the centre piece,
with all parts cut they are removed and all joining areas are chamfered, then they are all fitted back into the frame and clamped in place by the screwing down of pieces of wood, all measurements are now checked to see they are still correct
now the centre bar can be welded to the other two sections, once they hold firm they are removed from the holding frame and I temporarily try them on the bike to ensure they are what I want, then if happy with them (I was) they can have all the welds completed,
now it's time to start grinding down the welds, this takes a lot of time and care as it's easy to go too far with a grinder, not the end of the world as you can refill the area with weld but it takes time time time,
once the grinding has been done to a pleasing standard I finish off by leveling with abrasive papers, some by means of drill attachments and some by hand,
I made the mistake of buying unpolished tube which has a lot of machining lines in it, and it takes ages to smooth them out, I couldn't afford polished at the time as the Vet keeps taking our money
finally I got to a stage where polishing can begin and so it did, a lot more time and patience and I'm pleased with the result, as before I could've gone further with the polishing to give absolute perfection, but what is the point when they are going to be exposed to impacts from everyday (sunny) use,
my son made me a pair of stainless bar end weights and I welded a captive nut into each end of the bars to hold them and ground the welds to suit, I polished the end weights but left the machining lines in them as I think they look quite neat,
the drawing, the building of the frame and tube cutting, creating the pullback
1.jpg 57.97KB
0 downloads
solidifying the bars, removed and welded up, grinding begun, grinding complete
2.jpg 87.31KB
0 downloads
captive nut welded in, bar weight fitted to check alignment, all polished to my acceptance
3.jpg 139.14KB
0 downloads
as ever there are a lot more pictures in my face book album with more understandable explanations if you need them,
the bike is near completion now and I hope by sharing this project it may have given some an idea of how to do things themselves who may not know how to, or indeed give a spark of influence to enable someone to come up with a better way of doing something, all ideas can be modified as much as objects can.
we are all we are, we are TDM ![]()
Edited by laughin in a windstorm, 03 December 2025 - 09:41 am.
#138
Posted 03 December 2025 - 05:00 pm
#139
Posted 04 December 2025 - 11:10 am
thank you ![]()
I have fitted the bars and they seem comfy for me, only getting out on the road will tell for sure though,
the switch gear is a little loose due to the polishing but I will get around that with a slice of thin rubber on the inside of one part of each clamp, they are meant to have little tangs in them to locate in holes to stop them moving but as I always change bars I always cut them off
sneak preview of fitted bars
2.jpg 116.66KB
0 downloads
my riding companion
1.jpg 53.46KB
0 downloads
#140
Posted 07 December 2025 - 07:44 am
I managed to get the fuel tank changed yesterday but that wasn't just a straightforward job, getting the fuel pump out requires bending of a piece of plastic that turns out to be what the float arm sits on, there is no way it will come out without force which carries a lot of anxiety, especially as a new pump is listed at nearly £1000
(super gluing a broken item that sits in petrol is not an option),
the hole in the tank that the fuel pump fits into has a turned under edge to it to give extra strength but the under edge is 'unfinished' and is sharp on the fingers, this means it 'cuts' into the piece of plastic that needs to be bent to get it out, which in turn makes it harder to remove because it tries to shave the plastic,
to help with possible removing in the future I have sanded the under edge of the hole smooth so the piece of plastic will slide past it with a bit less force, possibly
I didn't totally finish reassembly yesterday just in case there is a fuel leak, but talking to my son he says he fitted a brand new seal when he had it so hopefully it will be ok, he was also the one who advised me the pump has to be given some force to get it out, when I originally painted it for myself 20+ years ago I left the pump in the tank and masked over it,
if the weather is ok'ish today I should finish it, I have to say though that I am pleased with how it's turning out ![]()
