Rear shock absorber
139 replies to this topic
#121 madmopedracer
madmopedracer
  • 473 posts
Posted 29 May 2019 - 10:45 pm
+1 for M Shock they set it up for your lardlyness and riding style
#122 the969
the969
  • 28 posts
Posted 30 May 2019 - 10:02 pm
Probably a Hagon shock.  OEM shock springs ar either black or yellow.
... or, like mine, black and yellow....
Screen%20Shot%202019-05-30%20at%2022.41.
mine is less erm soiled but as of now the black section of spring is in a box, hence the lowrider look......  got to decide whether to replace the top spring (ie make the whole shooting match look like it should) or buy a whole new aftermarket unit
(as previously discussed.)
Removing the top section was the only way to lower, courtesy of previous owner......
#123 dablik
  • 10,894 posts
Posted 31 May 2019 - 08:26 am
Make a pogo stick and buy aftermarket :)
#124 James
James
  • 572 posts
Posted 01 June 2019 - 01:20 pm
+ another one for M Shock. I fitted one to my 900 earlier in the year and I’m impressed with the quality of the shock and the service :)
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#125 wicklamulla
Posted 04 June 2019 - 11:09 pm
So the 850 I've picked up on the cheap (£1200, only 11k miles and HPI clear but a bit tatty) had one outstanding feature, in every sense....
It's been brutally lowered, fore and aft. What looks like around a third of the rear spring was handed to me in a box on purchase. It looks like this actually sits above the in situ yellow spring.  The forks have been brought through the yoke accordingly.  It looks preposterous, like a lowrider and the full system - which looks like it may have been a Remus - adds to this impression with the racket which is borderline offensive. All that's missing are the ape hangers (and tassles).....
The really weird part is that it actually handles pretty good, you can sling it around, but the aesthetics are obviously an issue. Is it worth just reinstalling the stuff in the box, or should I look aftermarket? Another option would be to refurb the in situ shock and then put the whole shooting match back together.  I've never had a bike where the rear spring could simply be divided. Apparently this was the standard lowering procedure  :dunno:
hello,  can we see a pic of the low rider please,  interested to see how it looks
#126 the969
the969
  • 28 posts
Posted 04 June 2019 - 11:50 pm
Sure, will get a few pix done and post.
Then I may well reinstate the original top (black) spring as in pic above to compare the way it handles now vs full height.
The Low rider handling is exceptional,  would be even better with some heavier fork oil, stickier rubber  and quality rear damping. As it is, its probably the easiest knee down bike I've ever had and there have been a few. Bizarre really but there you go.
#127 dablik
  • 10,894 posts
Posted 05 June 2019 - 07:57 am
Well oi think the mk2 is an absolute peach on the bends, even at normal height, just cant stand that stupid bloody oil sight glass.
#128 the969
the969
  • 28 posts
Posted 05 June 2019 - 03:12 pm
lowride as requested.
in theory the removal of the black, upper section of spring would limit available travel. But that also depends on spring rate / rider sag which is why it isn't constantly bottoming out. I'm still going to try and restore it to full height for a comparison.
Edited by the969, 05 June 2019 - 03:19 pm.
#129 sigvepigve
sigvepigve
  • 31 posts
Posted 13 June 2019 - 10:32 am
A 2014 R1 shock will fit the 3vd if you mount it upside down, and you make room for the canister by modifying/replacing the oil tank of the bike with a smaller one. And you need to fit the original longest spring from the 3vd shock as well. A lot of work, but it is doable, and works very well once installed.
#130 the969
the969
  • 28 posts
Posted 18 June 2019 - 10:43 pm
Well I've put the shock back from shortarse to standard. Because of this, I also took the precaution of bringing the forks back up to standard position - they'd been lowered about 35mm to match the dropped arse.
Rear suspension now has more travel, obviously, and there's a bit of damping left in the original shock for the moment. However, I probably will drop the front back a tad, like maybe 10/15 mm.
#131 fcb
fcb
  • 4 posts
Posted 21 December 2019 - 02:06 pm
Can anyone tell me what the diameter is of the flange bolt at the top of the rear shock unit please?
Spare parts number - 90105-10402.
I've looked up all the parts suppliers, but cant find any that give the dimension of the bolt.
Thanks.
#132 wicklamulla
Posted 03 January 2020 - 08:52 am
Thanks.
How ya FCB,   this is quite cheap so maybe worth simply buying it. https://www.ebay.co....tm/202780282351
  happy with the result?
#133 the969
the969
  • 28 posts
Posted 09 February 2020 - 01:25 pm
Yup,  thing was by lowering fore and aft in proportion the bike still handled fine, but the relative  lack of suspension travel didn't do anyones arse any favours.
And it looked pretty strange, not really in a good way.
So I returned rear shock to normal, forks to 10mm short of normal and used thicker oil and less of an air gap to boot, just to give it a bit more feel. Having done that I then adjusted the rebound damping as required. And stuck some new tyres on. Bike handles fine, she's a heavy old girl so you have to believe
a bit but that bit is the same for everyone.....
#134 Moj779
Moj779
  • 2 posts
Posted 01 April 2021 - 03:20 pm
Hi,
New to the site. There is a picture on 2nd page of this topic of a silver/yellow TDM with a complete lower fairing belly pan. OP is Pict. Does anyone know where this fairing was purchased?
Andy
#135 Catteeclan
  • 2,572 posts
Posted 01 April 2021 - 06:34 pm
Hi,
Andy
Just been re-reading some of this thread, some good people posting in there.
Can't help with your question sorry. Pict hasn't posted here for quite a while now, hope he's doing well.
#136 dablik
  • 10,894 posts
Posted 01 April 2021 - 07:21 pm
Was a set for sale quite recently on ebay, dunno if they went, i think not but you may be able to find out if you know your way around ebay..
#137 Studley Ramrod
Posted 02 April 2021 - 08:17 am
Hi,
Andy
Skidmarx sell fairing lowers https://www.skidmarx...-fairing-lowers
Oh and hello and welcome.
#138 fixitsan
  • 4,852 posts
Posted 02 April 2021 - 04:43 pm
Thanks.
I think it's 10mm. I've been looking at alternatives. The MT-09 looks like a good bet (based on the dimensions listed int he YSS shock catalogue), except the spring is probably 25% too soft so that would need changing.
Anyway, these are the bush sizes at either end of the shock
TOP (mm): 10x30
BOTTOM (mm): f.30x12
#139 Moj779
Moj779
  • 2 posts
Posted 03 April 2021 - 10:11 pm
Nice one Studley Ramrod  Thats it ok
#140 wicklamulla
Posted 02 June 2021 - 03:25 pm
a Kawasaki Versys 650 shock fit's MK1 (3VD) and MK2 (4TX) TDM 850 with relative ease.
