HELP ME ! please...
128 replies to this topic
#121 JMT
JMT
  • 74 posts
Posted 18 August 2008 - 01:50 pm
QUOTE(TonyDevil @ Mon 18th Aug 2008, 02:09 PM) <{POST_SNAPBACK}>
causes in order of likeliness
1) leaky petrol tap
to fix it take the tap off, and remove the 2 screws, pop down to your local plumbing supplies shop and replace the o-ring, assembly is the reverse of disassembly
2) perished fuel lines
replace the lot, cost is less that a tenner, 1meter/3.3feet should be enough, 2lines from tank to tap, 1 from tap to pump and 1 from pump to carbs
3) carb float bowl gaskets leaking
if you've had your carbs apart chances are these havent sealed or need replacing
worst case.....
4) petrol tank ....rusty/cracked etc
ah, cheers Tony.
When I got my MkII, it had been stood forabout 10 months, and had a nice stain as described. i'll investigate it at some point, i think it'll be either 1) or 2) thats causing it as i've not had the carbs apart (I don't think the previous owner had either) and I've had the tank off to change the thermostat, no rust or damage on there.
1996 Mk II TDM 850, Yellow/Silver. Givi Wingrack 2, E460 Top box, E21 Panniers. Polisport Hand Guards. Akrapovic 2-1 with Carbon Can. Scottoiler with Dual Injector. Oxford Heated Grips. Colour Coded Rear Hugger. Renntec Engine Bars. Fenda Extenda.
#122 TonyDevil
Posted 18 August 2008 - 02:17 pm
#123 mechinha
mechinha
  • 42 posts
  • TDM model: 1995
Posted 20 November 2008 - 03:42 pm
oh sh#%t the nightmare is back...
well i've done everything i could possibel do.. i've also bought an original exhaust system and fit in, but the "devil" thing worked well for about 2 thousand kilometers and now she did the some stuff again..
i do believe that altought i love the bike i'm going to sell it or put her in a realy nice big fire..
i'm so desesperated, i've no longer eat, drink or...well at least that thing i still make it... blush.gif
men this stuff is realy weird, i guess i have to exorcise the bike ranting.gif
#124 dapleb
  • 18,386 posts
Posted 20 November 2008 - 04:32 pm
What did you do to get it working again for 2k kms?
#125 Studley Ramrod
Posted 20 November 2008 - 04:55 pm
It might be your fuel pump ! There is a vacuum pipe from the fuel pump that goes to the inlet on the No1 Cylinder (the one thats on the same side you use to get onto your bike) If there is a tiny hole in the pump diaphragm or if the pump casings aren't tightly closed, petrol will leak along the pipe and rest at the lowest point. So what happens is you get a load of neat fuel dumping itself into the cylinder which then either fouls the plug, or makes it too hot resulting in a knackered plug.
It's a bit tricky removing the vacuum pipe from the intake but it can be done. If you can get it off and also remove it from the clip you can then lower the pipe and see if any fuel is there. It's also worth having a smell ! In my case the pump casing screws were pretty loose, not had a problem since I tightened them. I was going through a plug a month !
DON'T GIVE UP YET, IT'LL BE WORTH IT ONCE IT'S RUNNING OK....... BELIEVE ME !
Edited by Studley Ramrod, 20 November 2008 - 04:56 pm.
#126 mechinha
mechinha
  • 42 posts
  • TDM model: 1995
Posted 21 November 2008 - 02:17 pm
QUOTE(Studley Ramrod @ Thu 20th Nov 2008, 04:55 PM) <{POST_SNAPBACK}>
thanks for your concern mate. my bike it's just like yours. the colour, the beauty... well i believe that worth a go to try the pump fuel. i' ll keep on touch. oh by the way my bike sometimes smell a lot (gas) could it be that tube? even with the fuel shot off..
#127 dapleb
  • 18,386 posts
Posted 21 November 2008 - 02:38 pm
What did you do to make it run ok for 2k kms?
#128 mechinha
mechinha
  • 42 posts
  • TDM model: 1995
Posted 21 November 2008 - 04:13 pm
QUOTE(dapleb @ Fri 21st Nov 2008, 02:38 PM) <{POST_SNAPBACK}>
hi sorry i forgot to anwser you tongue.gif .. well we did a very fine carb tune, needles set, verified the float height levels, replaced the air filter and the iten that i was thinhking the most important replaced the exhaust system (silencers incl.) i'm tired and upset. i 've spent enough money with this pile of screws that could buy me a new one..
jesus this is frustating..
#129 Studley Ramrod
Posted 21 November 2008 - 09:57 pm
QUOTE(mechinha @ Fri 21st Nov 2008, 02:17 PM) <{POST_SNAPBACK}>
Yes, mine used to stink of petrol. And yes it will still leak into the vacuum pipe when the tap is off.
The fuel pump is in 2 halves, the top half is where the fuel from the tank goes to and it then goes out to the tap.The bottom half is used for the vacuum pressure. The two halves are separated by the thin black rubber diaphragm and if it has a hole in it the fuel leaks from the top into the bottom part. This can also happen if the two halves aren't tightened enough.
I can post some photos if that'll help you.
