#1441 steve27bha
  • 797 posts
Posted 03 March 2016 - 09:34 pm
I've finished the annual service and used the 50,000Km / 30.000 mile schedule with some added items:-
New tyres (Michelin Pilot Road 4 replacing Pirelli Angel GTs. Nowt wrong with the GTs but last time they were significantly cheaper than the PR3 of the time but not so this time around, and I'd really rated the PR3s on my VFR800. However the front only comes in the PR4 GT version for our 18" wheel)
A change of fork oil (three years or so after fitting Hyperpro springs and oil). A tool from the back of the drawer came in handy on the fork yoke clamp bolts. The top ones cannot be accessed by sockets without removing the fairing and my allen keys seemed a bit chocolate-y. This Teng socket/bit swivel holder got the 6mm bit in easily; I just had to guess the torque to do up the bolts.
Full strip and grease of the rear suspension linkage (no problem removing the frame bearing collar after last year's strip). My EazyRiser lift made access easy.
Attached File  029 - 1000.JPG   173.64KB   9 downloads
Full clean of the exhaust (including buying a proper socket to remove the lambda sensor after really struggling last time with an open end spanner)
Fit Yamaha belly pan (bought from Latestarter of this parish) after repaint and addition of my red pinstripes.
All being well the bike and I shall get a shake-down tomorrow on our first run of the year.
Edited by steve27bha, 03 March 2016 - 09:39 pm.
#1442 Latestarter
Latestarter
  • 676 posts
Posted 03 March 2016 - 11:42 pm
Looking good and loving those stripes :good:
#1443 tone
tone
  • 185 posts
Posted 04 March 2016 - 01:01 am
Great work chief, top work.
Love the bike lift ! looks like something I may need to invest in.
Tone 👌
#1444 fixitsan
  • 4,855 posts
Posted 04 March 2016 - 07:05 am
Busy day, Steve, looking good
#1445 leehenty
  • 5,325 posts
Posted 04 March 2016 - 08:15 am
I like that easy rizer lift very flash,  :wub:
#1446 Rallyist
Posted 04 March 2016 - 09:27 am
Looks like you might have a late birthday pressie
#1447 arthurbikemad
arthurbikemad
  • 573 posts
Posted 04 March 2016 - 11:19 am
Good job!! Like the lift, abba sky lift is another option :)
#1448 dablik
Posted 04 March 2016 - 12:25 pm
Nice job Steve have exactly all this to do in a couple of weeks weather allowing, exhausts of for polishing though  :um:
Edit..Are the Lambda sensors really so problematic with a spanner or will that tool save me lots of swearing !
Edited by dablik, 04 March 2016 - 12:30 pm.
#1449 ramo
ramo
  • 1,194 posts
Posted 04 March 2016 - 04:12 pm
fitted new chain and sprockets :good:
#1450 ProudViking
ProudViking
Posted 04 March 2016 - 05:26 pm
Fitted new temporary grips, new adjustable levers and finally got the Pro-Bolt colour coded fairing screws fitted!
#1451 Denystan69
Denystan69
  • 91 posts
Posted 04 March 2016 - 06:41 pm
On Wednesday, assisted by the wind, I decided to lay my bike on the grass at the side of the road and see if my handguards would do their job, they did! So did the hip and shoulder pads, boots and helmet!!
She's now in the shop for new bars (Rethal 758s) and offside front indicator.
So no major damage to me, the bike or my bank account (as I was about I change the bars anyway!).
#1452 steve27bha
  • 797 posts
Posted 04 March 2016 - 10:14 pm
As you can see I have a workshop so the weather is not a problem. I took several days to do the work, making sure all was well and cleaning where possible. I used Autosol on the pipes having had them polished three years ago when I got the bike.
Last time I barely got the lambda sensor off with an open end spanner before the flats rounded off. This socket made it easy with a breaker bar and careful alignment of the socket to the flats. I would have struggled to keep everything in line with just a ratchet handle since the heat really tightens up the joint. The breaker meant I could lean on the bar rather than jerk the handle. I was going to get a 3/8" item since I use that size socketry whenever possible, but reviews reported that they twist and open up so I got the 1/2" item and recommend that with a 2' bar.
Edited by steve27bha, 04 March 2016 - 10:26 pm.
#1453 dablik
Posted 04 March 2016 - 10:25 pm
Okey dokey thanks, done all the other jobs plenty of times but never taken the exhausts off, not sure if i will yet..
#1454 chrisr
Posted 05 March 2016 - 07:30 am
you could just leave it in but unplug it Cliff. (Mr. H has a tool for removing  snapped header studs by the way - should you need it!)
Edited by chrisr, 05 March 2016 - 07:33 am.
#1455 dablik
Posted 05 March 2016 - 09:17 am
Cheers Chris have to have a look at doing that instead, wont be no snapped header bolts i reckon, got proper Henty stuff on them 18 months ago  :)
#1456 Favs
Posted 05 March 2016 - 12:37 pm
Installed the fan cooled LED headlight bulb. A whole lot whiter than the Phillips Xtreme which I had. Beam is not as focused as H7 incandescent, if the back of the shed is to be believed.
Lost a wellnut & screw somewhere behind the fairing (again) - ordered new.
Road test in near future will determine the actual performance of light - photos of this may follow.
#1457 chrisr
Posted 05 March 2016 - 01:44 pm
Ah the continuing mystery of the disappearing well nut, will we ever solve it?
#1458 Kelpie
Kelpie
  • 944 posts
Posted 05 March 2016 - 04:10 pm
Fitted my tank cover. The bar risers mean the matching tank bag is far too close to the bars so rethink needed there. I like my riser cos my arms aren't very long! Very peed off to discover a kidney panel has mysteriously broken off a part of the lug. Have no idea how or when but at least it still does up.
Attached File  image.jpeg   149.69KB   0 downloads
Attached File  image.jpeg   150.35KB   0 downloads
Attached File  image.jpg   116.31KB   0 downloads
Eee, why are my pics sidey ways?
#1459 Favs
Posted 05 March 2016 - 04:17 pm
I cracked a kidney panel lug - used super glue to fix a stainless washer to it  :good:
#1460 Kelpie
Kelpie
  • 944 posts
Posted 05 March 2016 - 04:26 pm
Cheers Favs, been there and done that with my last bike (now belongs to hubby, BSM) which came to me with the same problem. Ironically, I've just bought Proud Vikings panels for BSM's bike. I might steal them one dark night!
10 user(s) are reading this topic
0 members, 10 guests, 0 anonymous users
