* * * * * 2 votes
Reviving A -99 Tdm 850
154 replies to this topic
#141 anda3243
anda3243
  • 89 posts
Posted 08 August 2013 - 09:54 am
Purchased a airfilter box from Ebay. 25 eur for the complete box.
#142 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 08 August 2013 - 06:38 pm
Good point, The airbox mod can be causing problems. I will try to find an used airbox lid with the snorkel intact. I have already ordered 155 and 160 size main jets, but I will try changing the airbox lid first.
Stick with the new lid snorkel if you feel that the problem persists or becomes worse.
Try to find what else needs to be changed in order that the engine runs well with a standard airbox.
You'll have a better baseline setting to work from.
#143 anda3243
anda3243
  • 89 posts
Posted 18 April 2014 - 09:18 pm
So, nothing has been done to the bike since august last year. The new airbox lid is still not attached. But will be.
I am starting to suspect that the emulsion tubes are worn. Will try to check them tomorow.
Does anyone know about the markings on the needles? Not the same marking on both side needles. Is it normal?
Right side needle marking: 6CLI
Left side needle marking: 6DJP
Has anyone had problems with worn throtle bodies? Has anyone replaced the throtle bodies?
#144 Studley Ramrod
Posted 19 April 2014 - 08:10 am
According to the HAYNES, the needles you have are correct and in the correct location.
#145 anda3243
anda3243
  • 89 posts
Posted 20 April 2014 - 08:07 am
Thank you. Thats interesting. I thought that the needles on both sides should be the same. I need to get hold of a Hynes manual.
I took apart the carbs, but cannot find a way to remove the emulsion tubes. Is it possible to remove thoses on a -98 model? It is nothing like for the mk1. http://www.carpe-tdm...?showtopic=4806
I will try to find a way to check if they are oval without removing them.
#146 Studley Ramrod
Posted 20 April 2014 - 09:06 am
Yeah, the later mk2a carbs are totally different to the other carbs.
I think it may be possible but, you'd need to press out the old ones and then press in the new ones and there's no tutorial on how to do this.
kedo.de sell the emulsion tubes so it must be possible.
#147 anda3243
anda3243
  • 89 posts
Posted 20 April 2014 - 11:25 am
Now I have measured the ovality of the emulsion tubes. With a fairly primiteve method I have determined that there is a ovality of 0,15 to 0,2 mm on both carburettors. I measured aprox 2,5 and 2,7 mm diameter. 2,7 being in the direction of flow of the carb, 2,5 mm 90 degrees to that.
For me 0,15 and 0,2 mm sounds quite much. Have any of you any preferences.
The needles on the other hand look good.
I have also figured out how to press out the tubes. I will brobably do a rebuild with new tubes, throtle bodies, gaskets, orings and so later this summer. This must be done before trying to adjust anything.
#148 wicklamulla
Posted 21 June 2021 - 10:39 am
How is it going now Anda?
#149 chrisbee
chrisbee
  • 412 posts
Posted 22 February 2022 - 06:50 pm
Just read this entire post WOW
I wish i had the time, the tools, and the know-how to anything like this.
Well done Anda 👍👍
#150 Coxylaad
Coxylaad
  • 517 posts
Posted 23 February 2022 - 01:45 pm
Are those brackets hidden behind the fairings?
They look well strong enough for the job, if a little industrial (no disrepect intended)
If I were to go down that route I would have made brackets out of steel tube in a trellis type fashion, if you know what i mean.
love the project, keep up the good work, you are inspiring me to get back into the garage!
#151 dandywarhol
Posted 26 February 2022 - 11:19 am
What's withe the blue flowers Laaaad? This you showing yer snowflake generation gender fluid side?  :pimp:
#152 Studley Ramrod
Posted 27 February 2022 - 03:00 pm
Never been the same since he got a 9'er :P
#153 Coxylaad
Coxylaad
  • 517 posts
Posted 01 March 2022 - 02:42 pm
I thought the snowboarding picture from 2008 needed to be updated, so went with the hawaiian drinking a latte look. It was taken at a silent disco which from the outset I let everyone know I thought i was a ridiculous concept, then spent all night jumping round the house like an imbecile
#154 Studley Ramrod
Posted 02 March 2022 - 08:25 am
Haha, I got invited to a silent disco, point blank refused for the exact same reason, maybe I shudda given it a go.
#155 dandywarhol
Posted 19 March 2022 - 11:51 am
Keep takin' the pills Laaaaad
