Future Tdm
MT09 and it is never replaced ?
160 replies to this topic
#141 muddy
Posted 12 May 2014 - 12:25 pm
The problem I have with 'TDM replacement' threads is that the bikes suggested often have very little in common with my concept of the TDM. So when I'm looking for future alternatives, the bikes have to tick the same boxes that the TDM ticks and that can be at odds with how others view the TDM. And since the TDM is a one of a kind sort of bike, it all gets a bit confusing.
I mean it's evolved away from being a dual sport and sort of morphed into a tall, rangey tourer with an upright riding position that's able to handle the occasional dirt road. But even that doesn't quite nail it. In fact I don't think it's an easy bike at all to nail. In the end I'd have to say that, for me, it's a bike that meets a specific set of requirements I have which are that it has to be broadly:
Cheap
Reliable
Economical
Comfortable
Moderately Powerful
My test would be that if I ride all day long I'm not feeling shattered at journey's end. That means that the riding position is easy to maintain, the engine is relaxed, quiet and non-vibey and I can go for 200+ miles between stops at 80 mph. Of course there's so much more to a bike than that, but the TDM has just fitted my needs so well. The nearest bikes I can identify that may more or less match it are the Suzuki DL650, the Honda NC750x. I really do want to try both of those bikes as soon as possible just to either rule them in or out.
#142 Eagle6
Eagle6
  • 80 posts
Posted 12 May 2014 - 12:42 pm
Cheap: at todays prices it's as cheap as most and cheaper than a lot.
Reliable: I'd consider it bulletproof in the engine department and as reliable as most Japanese counterparts.
Economical: seems as good as the TDM
Comfortable: reports seem to stress this a one of its good points
Moderately powerful: 116bhp good but not extreme
Regarding your options of the DL650 and NC750X, cheap maybe but I would consider a drop to about 50+bhp quite sustantial.
#143 Studley Ramrod
  • 19,373 posts
Posted 12 May 2014 - 02:48 pm
I doubt it'll ride anything like a TDM, 4cyl engine will probably be higher revving and not have the low down torque of the TDM.
The 1000 Versys wasn't exactly at the front of the queue when they were giving out good looks and it's not to everyone's taste.
I tend to think the 650 versys to be more comparable to the TDM. Two pots, similar performance/economy but lighter than the TDM.
No doubt a test ride will best answer your questions. :)
#144 Eagle6
Eagle6
  • 80 posts
Posted 12 May 2014 - 03:14 pm
You see I don't consider the 650 Versys and V-Strom to be anywhere near a replacement for the TDM. And people, including myself, have/had this thing about high revving 4cyl bikes with no torque. It seems that it's not true! There are a lot of 4cyl engines detuned for specific purposes that produce lots of torque quite low down.
I've had quite a few demos out and nearly every one was pulling 70mph at around 4,000rpm so most bikes seem to keep to the same gearing.
Torque
TDM 60
Versys 1000 75
Versys 650 43
NC750X 50
Edited by Eagle6, 12 May 2014 - 03:15 pm.
#145 jlmtdm
jlmtdm
  • 500 posts
Posted 12 May 2014 - 03:47 pm
I allways say the same my replacement will be the varadero would have been a pan but where I live just not practical for a go to bike.
Failing that if it was not for coin issues I would go for a fookin bmwya.
But im not paying 5k plus for a bike with 50k on it not as my go to .
Good luck with whatever you go for its fun choosing but frustrating at the same time.
#146 leehenty
  • 5,326 posts
Posted 12 May 2014 - 03:56 pm
Have you got anywhere near 100,000 miles on your TDM ?
If not, no reason to change it yet until you have  :)  Unless you got the new bike itch.
I'm on about 25K and do about 5-6k a year so that's more than ten years life left in it for me.
I'll be in me bath chair before I've worn it out. I want's me money's worth  :lol:
Servicing costs will play a part in this, so it's a reason to avoid complex systems like variable valve timing, VTEC etc as you are tied to the stealer otherwise.
Versys thou looks easiest to do valves etc, but they do use stick coils on top of the plug, so if they go it will be about £50 a coil x 4.
Edited by leehenty, 13 May 2014 - 04:57 pm.
#147 muddy
Posted 12 May 2014 - 04:19 pm
Fuel consumption is reported at consistently over 50mpg so on a par with TDM.
Not my TDM, nowhere near it. I'd say 10 mpg is quite a big gap.
#148 muddy
Posted 12 May 2014 - 04:35 pm
I was talking to Larry down in Hampshire about this. He's done a lot of miles on various bikes and has owned the TDM and now has the newer version 650 V-Strom and says it compare very well with the TDM. Of course it's not going to have quite the grunt, but it measure up in all the other departments and returns marginally better mpg to make up for it.
The problem I have with 4 pots is that the ones I've ridden have tended to be noisy (lots of whirring) and vibey and that puts me off trying one. That said, I'd have to try one of the detuned biguns because they may have different characteristics . Anyway two's company...
I was just reading Kevin Ash's review and if they all do this then the Versys would not meet my comfort standards.
"The irritation? Rev the motor harder than 6,000rpm and tingling vibrations become apparent through the various contact points. It's not as bad as the Z1000 but could induce some numb fingers at steady motorway speeds."
Edited by muddy, 12 May 2014 - 04:43 pm.
#149 NickIAM
NickIAM
  • 507 posts
Posted 12 May 2014 - 06:06 pm
Recently I was reading another rave review of the new MT-07, and it was like I was reading one of the negative churned out reviews of the TDM: simple to ride, comfortable, do-it-all bike, easy mechanics and electrics; but it was all sold as positive, where-as the TDM was summed up as predictable and boring.
I am not saying the MT-07 nor MT-09 will be alternatives to the TDM. Only that I was amazed how the same characteristics could be chaged from great to cr*p depending on the point of view.
Yeah, I've done the IAM. And yeah, I recommend it (any so-called 'advanced training' come to that; not just IAM): A low cost training course based on the system used by the police, which is largely common sense once pointed out, making one smoother, quicker and safer. What's not to like? And why would one not want to tell others?  :hide:
#150 jdelfino
jdelfino
  • 603 posts
  • Location:Benalmadena Spain no more, The Hague no more, now Hampshire
Posted 12 May 2014 - 06:33 pm
I think yamaha or honda are better than suzuki or kawasaki, maybe not on performance, but overall quality, longevity and resale value are higher most times for most models, my experience anyway
Sent from my secret Dick Tracy watch
#151 drumwrecker
drumwrecker
  • 440 posts
Posted 12 May 2014 - 07:42 pm
As my 900 seems be getting taller the older I get I thought about how a Gladius could be adapted to a touring bike but others things came up and it was forgotten also I was enjoying the TDM again.
In this months Motorcycle Sport and Leisure Peter Henshaw wrote an article on a route in Somerset and there was a picture of his bike a Gladius with screen, bark busters, fork gaiters and venture luggage. As he is also  a tour guide for MSL Tours he should know something. I wonder how the MT07 would take the same treatment and how it would perform as a tourer. I'm not sure the MT09 would adapt so well.
Any thoughts?
This link might be of when looking for another mount http://cycle-ergo.com/
Edited by drumwrecker, 12 May 2014 - 07:48 pm.
1953 BSA Bantam, 1960 Ariel Arrow, 1948 Vincent Rapide, 1959 Matchless G11, AJS 250CSR, 1986 BMW K75s, Suzuki 1999 GS500E, 2002 Suzuki SV650, 1991 VFR750 FL, 2007 TDM900
#152 Kalts
Kalts
  • 104 posts
Posted 14 May 2014 - 07:35 pm
I've been looking for TDM replacement as well and got stirred by Muddy's very well written essay "the essence of TDM".
TDM is a one of a kind sort of bike, could not say better.
My wife rides DL-650 K7 and althought it is nice and mellow and the engine revs very nicely when pushed.. it's mellow. It has less power than TDM and weighs the same. Also, I have heard that engineers increased "flywheel" inertia along with revised cams, so those go hand-in-hand and create the overall mellow package. I have also heard that TDM has unusually light "flywheel" inertia, so this explains the liveliness, not to mention more raw power. Wee-Strom is no match for TDM, but at the same time can be considered serious replacement if you can compromise a bit. For one thing it's throttle response is smooth as silk and it goes surprisingly well at low revs, probably because of both bigger engine inertia and cams. No experience with new (2012?) DL-650 yet, but I have some thousands of km riding both TDM850, 900 and DL-650. So much about DL-650 I maintain and occasionally ride as well..
I have gone down this "detuned biguns" path and am back in round one. I can only speak for big Bandit 1250, but I guess to be in very good position for comparison: spent last two years vacations on same roads and in same timeframe but with different bikes.
Bandit is no match for TDM, but if you love effortless overtaking and unstressed engine with massive torque you would like it. The engine is fine, bit of handlebar vibe but real weights took care of that and looked good as well. Missing twin rumble of course, but rumble does not ride. Much lower and good match to my height, was easier to push around even if it's heavier.
Now the bad points. Even to my small frame (I am 176cm tall, 68kg naked) riding posture was uncomfortable because of knee bend. Turning the original footrests 180 grade took care of that for me, but will not resolve it for bigger guys. Also had to rise the handlebars by using longer bolts and stacks of big washers. Now we're getting somewhere in the touring sense, but it has small "bubble" type windscreen, so almost no wind protection. Left it at stock because everybody in this forum knows ti's a long and very expensive battle. Good for warm days and no buffeting, and in the end I liked it, got my worth of naked riding over all those years again.
My main gripe was suspension, I could ride it on gravel but my guts were smashed around when riding on bad, paved backroads. It is also unsuitable for bad roads because of wide rims and low profile tyres by default, this is road bike for good roads. What is good and what's bad is of course open question, but rear rim went to straightening shop. I rode alone and lightly loaded with soft bags, no big loads on rear. For that reason my 9er rides on nonstandard, high profile bias-ply tyres and I have yet to see any nicks on rims.
To make matters worse, any less than standard tyre pressure meant wooden steering feel. Given that I loathed suspension and had to lower pressures because of that it was not nice to say the least. I had new front and almost new back tire, no guessing here.
So this pretty much sums it up: I loved the engine even if I missed the rumble, and liked it being lower. On the other hand I could not ride such bike comfortably where I like to go and need to compromise: bit lighter, lot higher, less power but at the same time comfortable. I need comfortable, reliable and economical bike to cover distances and ride the horrible backroads in third world countries. Heh, come to think of it, Estonia is as much a "third world" as Romania I have been lately :-)
Hope you did not fall asleep staring at this wordy mess.
Adding some more points for potential off-the-TDM itchers:
Forget DL-650 if you would like any performance while two-up. Althought pillion arrangements are very good, it barely goes while solo, so now you know what to expect.
Forget GSF1250 if you would like to have lasting friendship, love ties or other such kind of relations with your pillion. Pillion arrangements are terrible, this bike is practically usable only for solo rider.
I would also like to add that althought "rumble does not ride", it seems to be important thing in the mix for me. I am riding by hearing/feeling the engine, never look for tacho for gearshift or somesuch. Perhaps only to confirm that I am cruising on 6-th gear. I feel crippled on Bandit because I have no such feedback. All bikes have standard exhausts and are quiet ones, so I guess it it isn't so simple as to open up Bandit exhaust. I guess it is something more fundamental, owing to V2 or I2 vs I4 differences in vibration or something. I ride one-pot as well and feel just fine. In the end I can only guess that being raised riding on 1957 Russian-made Minsk-125, I am incompatible with I4 topology.
Edited by Kalts, 19 May 2014 - 12:37 pm.
#153 Muppdog
Muppdog
  • 305 posts
Posted 14 May 2014 - 10:03 pm
Whooaa,
go and book a test ride on an MT07. You will know in the first half mile why nobody considers it boring. Pure, concentrated fun! Practical it is not. No replacement for the TDM. It is to Yamaha's credit that were able to build a bike that had all the TDM qualities without the negatives.
By the way, it is nowhere near as comfy as the TDM. But that's beside the point. It is not for touring.
Are not all pure touring bikes a bit bland?
Rob
#154 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 19 May 2014 - 07:54 pm
I have seen the future TDM,puddles and potholes shouldn't be a problem. Turning might be.
http://www.gizmag.co...6d8632-90965377
#155 leehenty
  • 5,326 posts
Posted 20 May 2014 - 04:52 pm
 any misfire on the engines losing thrust drops you on the deck with no wheels. It might be a tad thirsty on fuel.
#156 Nanook
Nanook
  • 772 posts
Posted 21 May 2014 - 10:18 am
It'll probably need to be 4 wheel drive due to the age of some Carpedians!
Beware the whitevanman!
#157 harvey krumpet
harvey krumpet
  • 2,065 posts
Posted 21 May 2014 - 10:58 am
Who knows what our favorite tuning fork company will give us in the future..?
http://www.gizmag.co...ase-2015/31983/
F'all to do with TDM's but having one power plant & numerous bikes really appeals to me.
#158 Dougie69
Dougie69
  • 95 posts
Posted 15 January 2015 - 09:57 pm
Don't know if anyone else has put a pic on here but I'm sure no one will mind seeing it again it looks 😋
#159 Quartermaster
Quartermaster
  • 927 posts
Posted 15 January 2015 - 10:23 pm
Looks rather like an MT-09 Tracer.
#160 Robodene
Robodene
    Robodene
  • 1,547 posts
Posted 15 January 2015 - 11:05 pm
I think it might be one of Yamaha's early versions of the Tracer. You can see them on the 'Design Cafe' section of their website. It does look nice.
