6039 replies to this topic
#141 Bjørge
Posted 12 August 2014 - 08:34 am
2001 TDM. 1990 Serow. 2 bikes, three cylinders. Who needs more?
Saw your website - some really nice guitars there. Create the TDM-guitar, and I will be a customer ! Remember, I'm a MkI - guy ;-)
#142 arthurbikemad
arthurbikemad
  • 573 posts
Posted 12 August 2014 - 08:58 am
Wow, just took a look at that web site, amazing!
#143 Favs
Posted 12 August 2014 - 07:03 pm
Fitted this - many thanks to Dapleb for Bplate
#144 JBX
Posted 13 August 2014 - 11:42 pm
Today I had a 5 years old boy of some friends seating on the 9er inside the garage and he was happy like a dog in front of a saussage...
#145 leehenty
  • 5,325 posts
Posted 14 August 2014 - 09:59 am
stripped my right hand brake adjuster bolt thread in the swingarm  :bag:     , got to take the wheel out again, so I can get my thread fixing gear in there.
Alloy threads you are going to rotate fairly often are not really a good idea, they tend to wear out  :sorry:
#146 Graks
Graks
  • 22 posts
Posted 14 August 2014 - 06:22 pm
installed the GPS mount/charger for Garmin Montana 650. Used the alarm wiring under the seat for switched ignition and also for ground. Thanks to JBX`s excellent webpage i found this alarm wire with live ignition: http://www.jbx9.t15....ex.php?page=ALR
 Some pics:
#147 howie
howie
  • 207 posts
Posted 16 August 2014 - 04:04 pm
Walked 2 yards to look at my 9er in my garage, i won't be able to ride it for a while after it fell over on me as i was moving it a few foot in the garage, I tried to hold it up, my back give way the bike is fine but i have now got a cracked vertebrae in lower back A&E say i should be ok after several weeks of pain.Thinking i might need something lighter now i is over 70, the MT07 would be ok but having ridden one it feels a bit small i cant see the dash without bending my head down! a street triple is about the right size
anyone ridden one or have any other suggestions!
#148 Studley Ramrod
Posted 16 August 2014 - 04:22 pm
Geebus !  Get well soon matey :giveusahug:
How about a KTM/Yammy single potter ?  A lot lighter than the TDM.  Or summat loike a BMW twin that keeps the weight lower down perhaps ?
#149 Catteeclan
  • 2,574 posts
Posted 16 August 2014 - 04:32 pm
Fitted a hid kit to the low beam.
Ello, why are those screws missing?
Well that went ok.
Replaced the missing screws, reconnected the fag lighter which I wasn't impressed with and don't need. Scuffy wiring. Started the bike which struggled to turn over at first, clock reset. Looks like a new battery maybe on the cards.
Went for a quick spin, stuck it in the shed, seat off to find the wires going to said fag lighter wrapped around the battery terminals and no fuse. Wires have just been ripped off the battery and the rest will come out later.
Also fitted this givi touring screen which was supplied with the bike just to see what the difference is.
I'm not pointing at it, finger's holding it on.
Ouch.
Plenty to choose from out there but get well soon.
#150 Favs
Posted 17 August 2014 - 04:53 am
Replaced the rear caliper wif a spare I had bought from Ali g and refurbished in anticipation of problems with me nipples.
#151 Favs
Posted 18 August 2014 - 01:31 pm
Made, painted and fitted this bar ready for a sat nav to sit above the clocks.......oh, I fitted bar risers too :)
Edited by Favs, 18 August 2014 - 01:32 pm.
#152 Rallyist
Posted 18 August 2014 - 03:07 pm
Proper Prior Preparation Prevents Piss-Poor Performance
Well paint it again its scratched.
#153 Favs
Posted 18 August 2014 - 03:29 pm
Does look like it but - flash + other light reflections :P
#154 TDMick
Posted 18 August 2014 - 04:23 pm
Took it to get it's 1st service this morning.
#155 rockeye
rockeye
  • 93 posts
  • TDM model: 1995
Posted 18 August 2014 - 06:08 pm
Wired up my electric fuel pump, running a great and so much more responsive,
Fitted a 12 volt accessory socket,
Fitted good ridge rear brake line with stainless unions and new copper washers,
Bread rear brake ready for use,
Purchased new oil and filter,
Purchased new Delkovic 450 mm can
Ordered n Fzr 1000 chain gaurd ready for the Mot
Now just waiting for fuel line reducers and clips( should be here in morn) ready to tidy up fit of new fuel pump and then I'll fit the new can, run her up to temp and change the oil.
I'm almost at the end of this project having gone right through the bike sorting any issues and fitting FZR 1000 exup running gear and brakes. The rear swinger took quite a bit of engineering to make it fit correctly but looks gorgeous on and gives the bike a far better stance and look
I've had quite a bit of help and advice from this good site, I'll post some pic's once finished and see what you think of her. Spent a fortune and far more than she's worth but that's not the point , just like the challenge and seeing the finished product. I've saved all the original parts too so now got two bikes in one with a little spannering !
#156 Studley Ramrod
Posted 18 August 2014 - 06:27 pm
Proper Prior Preparation Prevents Piss-Poor Photographs
:P
#157 Favs
Posted 18 August 2014 - 06:30 pm
:P
#158 Kalts
Kalts
  • 104 posts
Posted 18 August 2014 - 07:38 pm
Removed cam chain tensioner and took it apart. My thanks to dandywarhol for providing knowledge about how to find #1 (left) cylinder TDC.
Wound the CCT spring up as much as possible and then reassembled (the CCT), which is quite tricky business, particularly if the spring tension is high.
Engine is now.. not quiet of course, but certainly less clatter at tickover.
After fiddling with CCT I guess it's plausible that the problems stem from factory assembly. It is so much easier to assemble CCT with spring under low(ish) tension than high.
Little suggestion: do not use only flat-blade screwdriver to lock CCT after retracting, as shown in the manual. Definitely lock it after retracting, the locking piece is very simple to make, I used 0,85mm thick plexiglas scrap laying around. After rewounding spring to higher tension the CCT tends to voluntarily unlock which could be disastrous while installing it. It could bump into camchain and cause it jump or cause overtension, depending on circumstances..
Uh, I guess I was not clear enough wrt to "voluntary unlock". The point being that CCT plunger kind of locks in place after fully retracting it, even without using external locking piece. But this is like walking on the edge of knife, one moment it is still locked and the next it isn't anymore. Higher tensioned spring will aggravate this tendency.
Edited by Kalts, 19 August 2014 - 10:02 am.
#159 shadowjack
shadowjack
  • 173 posts
Posted 19 August 2014 - 09:22 am
Rode it to it's new home in the country. Not like doing a rebuild or anything, but good enough for me.
#160 dicky1
dicky1
  • 837 posts
Posted 19 August 2014 - 11:36 am
I'm finally getting round to wash mine after a week recovering from a 3500 miles round trip to Narvik & the Lofoten Isles off the north of Norway.
Both the TDM and Francois's Varadero behaved perfectly apart from both bikes getting blown off their side-stands & suffering some cosmetic damage.
