Winter Project
405 replies to this topic
#141 Bjørge
  • 1,894 posts
Posted 18 December 2018 - 08:33 pm
No you don't. Half a litre is 0.879877 of a pint in the UK.
You only get more drunk than Americans. :munching_out:
You're F¤#%&ing right ! Forgot about US vs IMP on pints, too!!! Well, another argument added to my list.....
#142 fixitsan
  • 4,850 posts
Posted 19 December 2018 - 09:16 am
I heard that was the cause of one of the Space Shuttle crashes.  One supplying firm using (American) Imperial measurements and another using  Metric......?
I believe that's true, and it's been an issue with many joint projects, from shipbuilding to fighter aircraft
Well, I'm kinda lucky as I very rarely have to cope with other than metric units. It's mainly when communicating with you guys and most often MPG vs l/100km fuel consumption. Then I frequently meet the US Gallon vs IMP Gallon problem, and because the yankees regularily don't remember that other definitions of gallon exist (you're outnumbered, of course, but I suspect that's not the entire reason) this is a real PITA.
Norwegian also use a few odd measures, like "Favn" (2 meters high, 2 meters wide and length of 0.6 meters = 2.4m3) of wood (fuel) and....and.....and....no, I don't think there are any more  :P
...but of course, we have the ÆØÅ letters.... :lol:
The gallon is easy, 10lbs of pure water at room temperature.
1 imperial gallon = 160 imperial fluid ounces (fl. oz.) ** No longer officially used in the United Kingdom. **   = 8 imperial pints   = 19 of a firkin (of beer)   = 18 of an imperial bushel   = 4.54609 litres (exactly)   ≈ 412 litres   ≈ 1.20 U.S. wet gallons   ≈ 1.03 U.S. dry gallons   = 10 pounds of pure water at room temperature
"In 1783 the British inventor James Watt, who was having difficulties in communicating with German scientists, called for the creation of a global decimal measurement system, proposing a system which used the density of water to link length and mass..." Wiki.
So, not only are British measures universal but the metric system is British too. :oldgit:
it always was decimal.... volumetrically, a gallon is exactly 10lbs of pure water at room temperature
#143 Bjørge
  • 1,894 posts
Posted 19 December 2018 - 11:40 am
Yeah, and lb is easy, defined as  0.45359237 kgs  :lol:
The problem with joint ventures, requiring conversions, will be noticably improved with Brexit  :pimp:
#144 fixitsan
  • 4,850 posts
Posted 19 December 2018 - 11:57 am
Easy answer - dont convert to SI units :)
#145 PICARD
  • 1,786 posts
Posted 19 December 2018 - 06:04 pm
As my old dad said....a pint of clear water a pound and a quarter.....simples.
#146 dandywarhol
Posted 19 December 2018 - 06:57 pm
That was the downfall of space shuttle Challenger - somebody shoved a 1/2 inch coupling onto a 13mm pipe - whooosh!
#147 Coxylaad
Coxylaad
  • 517 posts
Posted 20 December 2018 - 04:28 pm
Good job I don't work at NASA
#148 curlylegend
curlylegend
  • 331 posts
Posted 20 December 2018 - 06:50 pm
Anybody do work on late 70's Landrovers ?  That was a bag of shite if ever there was one !   You needed A/F spanners, Whitworth and B/A and a set of Metric....no wonder most farmers just resorted to hammer and chisel and a big monkey wrench 1
#149 dandywarhol
Posted 20 December 2018 - 11:15 pm
Or a BL Maestro - Imperial engine mated to a VW metric gearbox FFS - no wonder they went down the tubes!
#150 Coxylaad
Coxylaad
  • 517 posts
Posted 27 December 2018 - 09:18 pm
Job done. Drilled out and helicoiled. It was hell.
Back onto finishing the clean up operation
Engine is pretty much ready for paint. I plan to remove all the covers and paint them separately, then do the block.
Merry Christmas everyone
Edited by Coxylaad, 27 December 2018 - 09:18 pm.
#151 fixitsan
  • 4,850 posts
Posted 28 December 2018 - 08:10 am
Proper job.  Hopefully the gaskets stay mostly intact when you take the side covers off, but they're cheap enough.
What have you used to degrease the underside ?
#152 wicklamulla
Posted 29 December 2018 - 12:19 pm
FFS s'not rocket science Coxy...
#153 Coxylaad
Coxylaad
  • 517 posts
Posted 17 January 2019 - 03:17 pm
long time of inactivity.
I now have the frame back all cleaned and powder coated. They have done an excellent job.
I've also had a stab at painting the engine. I have some bits to touch up but generally its gone pretty well also.
#154 Studley Ramrod
Posted 18 January 2019 - 10:19 am
Lookin' good. :cool:
#155 Coxylaad
Coxylaad
  • 517 posts
Posted 01 February 2019 - 10:28 pm
I cant remember whether or not I asked this but does anyone know where I can get a full TDM900 lockset from?
Ideally it would include the petrol cap if possible.
#156 Coxylaad
Coxylaad
  • 517 posts
Posted 09 February 2019 - 11:16 pm
At long last I have finally managed to get a day in the garage to progress the 900 project.
so, I finished painting the engine:
Did some more cleaning up of parts.
whilst I was there I replaced the swing arm bearings and one of the bearings in the suspension linkage
started to build it all back up:
I had a rear wheel from a YZF750 kicking about from an old track bike I used to own, offered it up, and its a direct replacement! happy days, I can now run a 180 rear tyre. only drawback is that its pink!
last thing I had a look at today turned out to be quite interesting. I was going to make a start on cleaning up the throttle bodies, they are a bit minging:
then just for the crack I decided to offer up the 42mm F800 throttle bodies on the engine:
They look so good. They may have to stay there!
I have the ignijet ecu so tuning it to the bigger throttle bodies will be a relatively straight forward process. Would be a shame not to do it now I have gone this far.
#157 wicklamulla
Posted 10 February 2019 - 02:04 pm
F800 injector bodies as in BMW?   Looks great so far Coxy.  Don't worry about the TDM900, pink rear rim, Coxylad is Gay comments as they are long gone by now!  I am keen to read your progress with the ignijet setup and resultant dyno runs.
#158 Studley Ramrod
Posted 10 February 2019 - 02:06 pm
Looks like some parts have been cleaned for the first time, ever. lol. Likin' the engine, looks really good.
#159 dablik
  • 10,893 posts
Posted 10 February 2019 - 03:27 pm
Leave it pink, it's pretty, good work so far, cupla questions though.
1. Looks like you left the headstock races in but covered with a big washer both ends, i always assumed they would need to come out for a powdercoat ! guess not.
2. What did you use to clean up the engine, cos it was really manky looking before hand, must of done a good clean as ya paint has stuck on :)
3. Which paint did you settle on for the engine, looks lubberley :good:
#160 dandywarhol
Posted 10 February 2019 - 11:35 pm
You would know all about a pink rim Wicky.
What spin cycle do you use after washing the parts coxxxxxxxxxxxxxxxxylaaaad?
