Those T30's are a challenge to remove, hardest part of the strip for moi. I bent/twisted a few T30 bits trying to remove mine. Think I ended up helicoiling one after carefully drilling the bolt out.
You will get different sized shells. ![]()
Posted 09 June 2019 - 10:04 pm
Posted 09 June 2019 - 11:01 pm
i remember Dappers saying he went the whole hog and did the testing / measuring using plasti gauge (to establish shell size i think?) to get it nigh on perfect. I know some peeps just sling in a used crank and don't seem to consider too much when it comes to replacement shell sizes and maybe the get away with it. Cliff i have a fair sized (messy) garage and am hopefully building anudder outbuilding this year measuring approximately 24' x 13' which will house some of my tree surgery kit and a couple of bikes, hydraulic lift bench etc. Following yer fred with interest blood.
Edited by wicklamulla, 09 June 2019 - 11:07 pm.
Posted 10 June 2019 - 07:44 am
its a scientific fact that the size of your shed is inversely proportional to the amount of crap you put in said shed
Posted 10 June 2019 - 08:38 am
Good to know about the T30 torx bits, will drill them out.
I know you can have different sized shells across the 3 mains, but i have 2 colours on one bearing, will check it all out later, prolly start a new thread re all that stuff to keep it in one place..
I got the dappers thread bookmarked wicki as it's a good reference, still a bit of a mindfook though, my plan is to measure and replace if needed, no point getting this far and not doing it, having said that though i think these motors will tick along just fine if slightly out of spec but not knowing enough about engines i'll go ahead and measure up. Sounds lovely Ken, when you've built that outbuilding you'll just have to destruct one of ya bikes matey, the 9r barrel job maybe ?
Sorted and on the Road Mick
Posted 10 June 2019 - 12:19 pm
Posted 10 June 2019 - 01:04 pm
DO NOT USE NUMBERS QUOTED BELOW AS REF FOR YOUR OWN SHELLS, NOWT IS CERTAIN.
It's all in the Haynes ow to measure up daps, a bit confuzzling but i have the general idea, am going to plastigauge as well, it's funny about the different colour shells innit, i thought maybe i had goofed up and mixed left with right shells but after just looking at wot i marked up i think someone was in here before, these are me findings
Left bearings Upper = 121A = Red/Brown
Lower = 141D = Green !!!
Middle " Upper = 121A = Red/Brown
Lower = 121A = Red/Brown
Right " Upper = 141D = Green!!!
So looking at that you can see i have a Lower on Left side with a Green and an Lower on Right side with a Red, and i know that the shells were marked up with permanent marker before i removed them from the journals so that would discount mixing up lefty and righty after the cases were split...
Different colours would'n make any sense though me thinks as the differences are in thickness of the shell bearings !
Tried a little heat on the Torx but did'nt keep it heating long at all, dont think both me T30 bits were a great fit either,drilling shall commence.
Shall crack on..
Edited by dablik, 17 June 2019 - 01:43 pm.
Posted 14 June 2019 - 06:23 pm
Hurrah a few dry hours today...woopwoop
20190614_162245.jpg 234.84KB
0 downloads
20190614_162224.jpg 177.8KB
0 downloads
That's th elast of the gubbins out now.
20190614_162102.jpg 146.87KB
0 downloads
Torx bolts were well stuck, looks like Red loctite on em, input shaft torx bolts (staked) came out easier than the balance shaft bolts which i need to drill through and retap.
20190614_152059.jpg 161.47KB
0 downloads
Posted 14 June 2019 - 07:02 pm
Good job mucker.
Posted 14 June 2019 - 07:20 pm
you da man Cliff ![]()
Posted 15 June 2019 - 10:37 am
Yahoo ![]()
Posted 15 June 2019 - 10:42 am
Posted 15 June 2019 - 10:53 am
don't mix up all those parts lad!
Posted 15 June 2019 - 06:44 pm
Easy bit done dabbers. !0)
I dunno daps, them blinkin Torx bolts on the balancer shafts, right pain up the jacksie, drilled the heads off to get the shafts out, now i've drilled bang down the centre of screw so i can get an extractor in proper and good but those little bassads aint moving, they only get torqued to around 10nm but ya can see the red shoite in the pic, looks like a drill out an a helicoil.
20190615_185555.jpg 106.67KB
0 downloads
Measured up the side play on the Big ends, 0.20mm so about bang in the middle of spec (0.160-0.272)
Those marks on the top of the cap nuts, do they denote anything or is it just the type of nut !!
20190615_152358.jpg 142.67KB
0 downloads
About to plastigauge the Big ends then got showered on so tomorra and also plastigauge the crank bearings, cant be arsed now me belly is full of food.
20190615_154418.jpg 144.15KB
0 downloads
20190615_154427.jpg 133.26KB
0 downloads
Still waiting on some bits for the die grinder as wrong shaft size sent, dont think the angle grinder cutting blade will quite fit to chop the rotor off,maybe, will see in the morning.
Another thing i noticed inside the crankcase, wot ya think !!
20190615_190338.jpg 135.72KB
0 downloads
Lets see if the numbers clearer.
20190615_150439.jpg 131.63KB
0 downloads
20190615_150456.jpg 138.87KB
0 downloads
Posted 15 June 2019 - 06:50 pm
Pretty sure they're just casting marks. ![]()
Posted 15 June 2019 - 06:52 pm
Think you may be right, had a lot of them on the 9r's camshaft caps iffin ya remember, hope so anyway ![]()
Posted 15 June 2019 - 08:01 pm
Web numbers of skipped shaft....new crankshaft numbers 22 222 so i dont get confused lookin back at this post ![]()
20190615_200620.jpg 125.72KB
0 downloads
Crankcase numbers
20190615_205001.jpg 149.54KB
0 downloads
Righto, daps just for you mucka, in your very very very very old post you said you had only seen one (yours) of these endangered species.
Cap rod number is 5, summit else is scribbled before and after, looks like A after the 5, presume it's the # 5 i'm using, both caps same number.
0 downloads
Just done the calcs for bearings and it would appear wot i though was Red previously on the mains is likely Brown now
fookin silly system..
Will post up me reckoning at some point for a homework check.
Edited by dablik, 13 July 2019 - 10:08 pm.
Posted 15 June 2019 - 08:25 pm
Posted 15 June 2019 - 08:29 pm
Posted 15 June 2019 - 08:30 pm
Cliff watched this Partzilla vid? I'd be suprised if Yamaha had changed the way they do things.
https://www.youtube....h?v=wpnllgm3e1I
Never mind you got the info........ ![]()
Edited by Favs, 15 June 2019 - 08:33 pm.
Posted 15 June 2019 - 08:32 pm
Cheers Al, doubt it also matey, watched a cupla his vids this week, it's all in Haynes and daps post linked above.
