Fast Idle Plunger Repair (TDM 900) [ie Cold Start ]
153 replies to this topic
#141 Nig
Nig
  • 217 posts
Posted 15 October 2020 - 12:57 pm
Cheers I'll have a meddle about at weekend
#142 dablik
Posted 15 October 2020 - 05:26 pm
In fact if i recall only pushed mine with a long screwdriver...
#143 NickEXO
NickEXO
  • 2 posts
Posted 15 October 2020 - 10:34 pm
Hi. Relative new 900 owner could someone please post a photo of where the fast idle plunger is located. Thanks.
#144 dablik
Posted 16 October 2020 - 08:00 am
Scroll down, Post 55, can be seen quite clearly Nick, and welcome.
#145 NickEXO
NickEXO
  • 2 posts
Posted 16 October 2020 - 05:48 pm
Thank you.
#146 malcopopolo
malcopopolo
  • 7 posts
Posted 06 February 2022 - 02:12 pm
Good Morning.
Did mine yesterday. The screws that hold the unit together are cross head, not phillips and are very tight. I rounded one off. Manage to sort it all, have replaced with bolts so you can use a small spanner.
Another tip rather than use a long piece of wood or similar to hold the tank up - I used a bun-jee cord from the tank bolt hole to the rear grab rail - perfect.
Thank you to all the folks contributing.
#147 Catteeclan
  • 2,574 posts
Posted 06 February 2022 - 07:06 pm
Good Morning.
Think you'll find those screws are Japanese heads, JIS, and you weren't the first to round one off. :rolleyes:
#148 leehenty
  • 5,325 posts
Posted 11 February 2022 - 06:36 pm
they can be uncommonly tight, on Moose's Niner, years ago, I had to remove both throttle bodies and pop them under the miller in a plastic bag and mill off one of the heads. even the shank was still quite tight in the hole. As I started the machine he said "you CAN put this all back together can't you ?" :rotflmmfao:
Edited by leehenty, 11 February 2022 - 06:40 pm.
#149 Studley Ramrod
Posted 11 February 2022 - 09:24 pm
:rotflmmfao:
#150 Norwegian
Norwegian
  • 162 posts
Posted 12 February 2022 - 09:06 am
Well, don't just leave us hanging - could you??
#151 chrisr
Posted 13 February 2022 - 02:50 pm
Lee can strip a tdm, throw all the bits in a box then put it back together better than Yamaha did, so the answer will be yes!
#152 trevini
trevini
  • 1,892 posts
Posted 13 February 2022 - 05:15 pm
I'll stick my neck out and say that there's more than a good chance Lee could put it back together, probably blind folded with one arm tied behind his back, eating a cake with the other and even then it would end up shiney!
#153 leehenty
  • 5,325 posts
Posted 14 February 2022 - 07:49 pm
it all went back together fine. even made him a new stainless plunger pin, as the old one was squashed a bit by his mole grips. ChrisR's blue bike also had a stainless plunger pin made, now in AliG's possession.
Edited by leehenty, 14 February 2022 - 07:50 pm.
#154 Nig
Nig
  • 217 posts
Posted 02 December 2022 - 07:43 am
Bugger - after lubing me plunger with Alu slip back in Oct 2020 all was fine.
It started again last night though - No idle up on cold start up.
Noticed that Guest ET photos have gone at the begining of the thread - are they gone forever??
