Nowt to do with the cleanliness, it seems vibrations of the bike tend to work them a little loose and the plugs melt when the wires short, happened lots, mine will be having new wiring and no connector.
Edited by dablik, 15 March 2018 - 06:34 pm.
Posted 15 March 2018 - 06:33 pm
Sorted and on the Road Mick
Posted 15 March 2018 - 06:36 pm
Posted 17 March 2018 - 05:12 pm
Posted 20 March 2018 - 11:15 pm
Posted 21 March 2018 - 05:55 am
Posted 21 March 2018 - 09:02 am
Agree, i fitted a double banjo with a bleed nipple to my MC when i swapped for 2 lines, had good results with reverse bleeding though using a syringe.
Posted 21 March 2018 - 02:34 pm
Posted 21 March 2018 - 05:32 pm
It requires a bit of patience eh Tom but can get good results.
Posted 21 March 2018 - 06:30 pm
Posted 21 March 2018 - 07:49 pm
Posted 21 March 2018 - 09:34 pm
Personally, I wouldn't use a caliper with a broken bleed nipple, brakes are the one thing I wouldn't take a chance with.
Posted 21 March 2018 - 11:11 pm
Posted 21 March 2018 - 11:27 pm
Theres two bleed nipples on the rear caliper... do you need to bleed from both? Cause the outer one has snapped and it has also got a snapped removal tool inside it now. It isnt leaking.... the other however, is free.
Yes you need to bleed both. In your situation you will need to remove the caliper from it's mount but leave it piped in. Then keep the broken piston side low and pump fluid into it. Then push the piston back into the cylinder to push the air into the side of the caliper with the working nipple.
It's a faff, and there is little risk of the old nipple causing a problem, but an alternative caliper is the best bet. The mk1 uses the same rear caliper as the FZR600 Genesis (3HE model) from the mid eighties, and fitted to a lot of other bikes of the period, like the XJ900.
I would be tempted to buy a cheap replacement, fit new seals and nipples, and list the old one on ebay listed honestly as ' needs a new nipple, old one seized' and you'll get something back for it.....there are a lot of inventive people who would mess about with that to save a couple of quid !
Ive decided to drill it out and put a new one in.
Need to be a good drill, those removal tools are as hard as a hard thing
Posted 27 March 2018 - 10:00 am
Posted 27 March 2018 - 11:57 am
Dunno what you mean Tom, torque settings are stated in the manual !!
Posted 27 March 2018 - 02:15 pm
Posted 27 March 2018 - 02:25 pm
Posted 27 March 2018 - 04:04 pm
Ive seen somewhere on here, someone thinks the rear wheel setting in the manual is too tight.?
Okay well that's one i do by feely feel
but pretty sure it was the 9r axle torque which was stupid high.
Posted 27 March 2018 - 05:00 pm
Lower shock mount way too high for marshmallow bolt.
Oil filter housing bolt too high.
If you are doing enjun stuff the Heinz and worksop Manuel sometimes vary on torque settings.
I agrozzle. Rest of the torque settings for mk1 are about right iirc.
Posted 27 March 2018 - 06:47 pm
