Fork Oil Seal (mkI)
168 replies to this topic
#161 davytdm
davytdm
  • 349 posts
Posted 19 July 2016 - 09:12 pm
I've just done full seals and bush kit on mine not a hard job but the smelly onion water is rough lol 😂😂😂
#162 dablik
  • 10,893 posts
Posted 27 September 2019 - 11:26 am
QUOTE(Bjørge @ Fri 9th May 2008, 11:00 PM) <{POST_SNAPBACK}>
Hi !
I am experiencing the exact same problem today, only the part number is a bit different. I got seals numbered 5VU-23145-00, seemingly belonging to a FZ1000 or something like that. They don't fit, being too thick. Goning to my dealer tomorrow, a bit angry - my teflon bushings lasted the first dismantle, but not the second one ranting.gif
How did the 2006 story end (if you're still a tdm'er) ?
Bjorge
there are apparently 3 different sized fork seals listed for the 3VD 91-95 TDM dry.gif
wish i'd written down the part number i used as it appears to be the right one hidden.gif
Oh that's a long thread innit, well i have the tool in hand to refit new seals BUT according to Tony 5VU-23145-00 seals which is what Fowlers have sent me are to thick to fit so, has anybody managed to change theirs with this same seal since this thread, do we know if thems to big or not, if not where you getting new seals from, or am i gonna be the guinea pig !!
Think maybe i'll dig out the old seals, dunno if i slung them yet and measure up..
Edited by dablik, 27 September 2019 - 04:53 pm.
#163 dablik
  • 10,893 posts
Posted 28 September 2019 - 04:41 pm
Found the old seals which measure up close enough to be the same as the the current supplied seals, in fact code number on the seal is identical, not sure why they would'nt fit for Bjorge, these old seals came out of Big Red's fork for them what remembers, course could of been a different set i spose, so i cant see why the new ones wont fit, forgot to order furkin oil so let ya know.
New on the right
Attached File  20190928_164033.jpg   175.6KB   0 downloads
Edited by dablik, 28 September 2019 - 04:44 pm.
#164 dapleb
  • 18,389 posts
Posted 28 September 2019 - 04:44 pm
Never heard of diff sized seals. Always got 3vd juans and always fitted. Have used both OEM and aftermarket. Hmmm can have a dig when I'm back and see if any bags with part numbers on
#165 dablik
  • 10,893 posts
Posted 28 September 2019 - 04:51 pm
Well them above is the same part number as supplied in 2008 daps, so the letters were superceded yonks ago and part number remained the same, it's common on here for OEM seals to be recommended for a new fit but i wonder if the issue you mentioned re which way up the washer sit's makes any difference, Matlock fitted Wemoto seals to his xtz and it's all good, anyhoo i reckon they should'nt be problematic, hoho.
Edited by dablik, 28 September 2019 - 04:52 pm.
#166 dapleb
  • 18,389 posts
Posted 28 September 2019 - 05:56 pm
Ahhh I see the thread you is on about. Depth of seal? Have fitted both. As long as retaining ring fits no bodder. Dunno when change happened.
Big red forks. I rescued the set that went in Gs boike when Tony started parting it out...so the forks in there when you got it were not mine. Xx
Can't see pics well but neither of them look loike the deep seal where the outer edge is full height and the lip is internal.
#167 Studley Ramrod
Posted 11 July 2021 - 05:57 pm
I'm just about ready for doing the seal change using the Bjorge method.  Do I need to take all the fork gubbinziz out afore filling with oil and then squashing ?  Or could I just remove the cap, fill to top with oil, replase cap and squish ?
Is there a separate topic on the oil fill method ?
#168 dapleb
  • 18,389 posts
Posted 11 July 2021 - 08:11 pm
In this ear thread the one and only bjorgey outlines the procedure. I thought it was somewhere else too but didn't find so ear is copy and paste of his destructions
Well, I finally got to change it - with original seals. Don't know what it has been all about, but there it was.
(see also this thread: http://www.carpe-tdm...o...=12781&st=0)
Now - the important part is the method:
1. Remove spring
2. Extend the tube fully
3. Fill it all up with oil (you need to add few decilitres, less than half a litre, though)
4. Reenter fork cap and tighten by hand
...you do now have a quite rigid suspension.... style_emoticons/#EMO_DIR#/mellow.gif
5. Tie a load strap around the fork (lengthways, dummie !) and inser a car jack under the strap at the bottom of fork
6. Tighten strap
7, Extend jack until seal pops out
8. Clean up mess (it won't be very much oil around, but it's hard to avoid 100%)
No big pooooppp!, just a little "blip" just as pressure is relieved (remember, oil isn't compressed, so very little oil has to expand out of opening). That's the idea about not trapping any air inside it - would cause a ssssplash of oil....
Good luck !
Edit: found bjorgey thread
http://www.carpe-tdm...l=&fromsearch=1
#169 Studley Ramrod
Posted 11 July 2021 - 08:52 pm
You're a star. :good:  Will be giving this a go tomato using a frame wot me bro knocked up.
