#1821 fixitsan
  • 4,855 posts
Posted 12 May 2016 - 06:00 pm
I do....yep 3.1 was first but 3.5 was the precursor to 95.
All of which, including offerings from Apple, were ripoffs of a Xerox designed GUI....and prior to that Doug Englebart's famous but forgotten system...
I used to be a bit geeky, thats how I know ;)
#1822 arthurbikemad
arthurbikemad
  • 573 posts
Posted 12 May 2016 - 06:03 pm
GEM OS was also another, loaded on the PC512, I still have one in the loft, and a PCDOS 8086 at 4.77Mhz, single 360k FDD and green screen lol, has a 14.4 dial up modem, used it with prestel way before the net :)
Gave the TDM a wash, rode it, sadly to work :(
Edited by arthurbikemad, 12 May 2016 - 06:05 pm.
#1823 fixitsan
  • 4,855 posts
Posted 12 May 2016 - 06:59 pm
Doug Englebart's 'mother of all demos' ...first hyperlinking scripting language, first GUI, first computer mouse, first multimedia presentation over distances beyond next door rooms..... all in 1968
At 2m22s in this you see what Steve Jobs stole, shared with Bill Gates, and it makes their longrunning court battle over who invented the GUI pretty insignificant !
Oh, and I took a ride into Edinburgh in the sun :)
Edited by fixitsan, 12 May 2016 - 07:06 pm.
#1824 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 12 May 2016 - 07:49 pm
was windows 3.1 not first after DOS 6? and who remembers Word Perfect use to be market leader - and a hard drive measured in MB
Sirra!
Dost thou knowest of a tool called Delta 4 and bright script, glowing in unearthly greens?
I here tell there would be sheathed blades called floppies, 5 and one quarter inches broad and that would bend in the slightest breeze.
Banshees would screech to telle the spiders web. Fools would trip across power cords to have their heads beaten with Compaq keyboards.
Dropped my front end by 10mm to offset the stiffer front springs and hopefully get rid of the pushing feeling I have at the moment.
Reduced damping to minimum to see how it feels in turns.
Backed off the rear damping by 2 clicks to match.
There is a reason that the TDM has so much front end sag built into it.
My shabby, saggy items turned much better than the current arrangement.
"Beefing things up" is obviously not a proper solution and requires attention to the whole of the bike IME.
Oh and passed MOT again, 5 for 5.
Loud ART cans reattached, luggage rack tucked into corner of garage till needed.
Edited by TYREDNGRUMPEE, 12 May 2016 - 08:00 pm.
#1825 JBX
Posted 12 May 2016 - 10:15 pm
DOS and Windows are two different products.
MS-DOS started with v1.0 from Microsoft and ended with v6.22 - the v7.0 was released by IBM.
Windows started with v1.0, then v2.0, 2.1, 3.0, 3.1, the latter was the most successful.
It was based on a DOS sub-layer until Win95/98/ME which had a DOS layer.
Following Windows versions where based on the NT system - no DOS.
Edited by JBX, 12 May 2016 - 10:16 pm.
#1826 Bjørge
Posted 13 May 2016 - 08:07 am
Windows 3.0 was the first widely spread Windows version, 3.11 was the first version prepared for networking. DOS was part of the Windows stack until Windows 2000, which was based on NT platform.
WordPerfect was my way into computers, spending free hours a couple of weeks made me a "guru" from then on. A couple of years later I started my programming career, and I'm still there. Believe I would still enjoy using WP 5.1, though  ;)
#1827 ProudViking
ProudViking
Posted 13 May 2016 - 08:24 am
This is all going over my head! But I do know that Windows XP was the best, and its been getting worse ever since.
Edited by ProudViking, 13 May 2016 - 08:25 am.
#1828 rustyscrew
rustyscrew
  • 126 posts
Posted 13 May 2016 - 10:01 pm
Fault finding eleci problems,she has let me down last time i was riding.had to get push start and all.second reg/rec gone in so time to finally get round to finding the problem wires.lookin forward to riding wit confidence again that shes not goin to die on me
#1829 fixitsan
  • 4,855 posts
Posted 14 May 2016 - 06:37 am
Swapped handlebars for the non-standard ones on my xj600. They're lower, wider and the sweep back is less than srandard 9er ones..... seem okay....maybe a bit too low
#1830 Favs
Posted 14 May 2016 - 12:13 pm
Paid auntie Carole upfront for her to cover me for another year....had a short ride out to monitor Scottoiler performance/delivery.
#1831 dablik
Posted 14 May 2016 - 02:00 pm
Got a local run out today to get the new rubber scrubbed, even though it does'nt feel necessary these days.
#1832 fixitsan
  • 4,855 posts
Posted 14 May 2016 - 07:10 pm
Did a lot of running about int he sun, after cutting the top off my airbox
http://www.carpe-tdm...=33145&p=333328
Also closed up the AIS system again. After trying to attach an LED to the wiring it seemed like an LED interfered with the sensing or driving being used to control the AIS solenoid.
#1833 TYREDNGRUMPEE
TYREDNGRUMPEE
  • 1,627 posts
Posted 14 May 2016 - 07:43 pm
Got me some brake cleaner for the first time ever in 20+ years of motorcycling.
Attacked the bobbins on the front discs. (Much better feel) and way easier too using brake cleaner.
On return, noticed that one disc was running a little warmer than the other, so did some caliper servicing.
Spied what may have been a bit of perished dust seal protruding from an offending brake piston. (So carefully pulled it free, what could possibly go wrong? 6mm)
Piston action much improved. May add caliper overhaul to winter list.
Determined that dropping the forks by 10mm has made the steering much lighter + positive and reducing damping has worked. (So will stick with that this Summer)
Winter List = valve clearances / carb balance / chain and sprocket set due / caliper overhaul poss. / K&N clean
#1834 Timbo1866
Timbo1866
  • 224 posts
Posted 14 May 2016 - 07:58 pm
Fitted new clutch cable what a difference much better 😃
#1835 Catteeclan
  • 2,577 posts
Posted 15 May 2016 - 08:42 am
Might have to nip out on mine in a bit before the misses get out of bed, weathers looking pretty good.
#1836 ProudViking
ProudViking
Posted 15 May 2016 - 02:53 pm
Mr Henty popped over to remove me rear wheel so I can get the flat sorted. He also took much pleasure in fitting this lovely carbon dash...         Attached File  IMG_0201.JPG   179.05KB   1 downloadsAttached File  IMG_0200.JPG   167.09KB   0 downloads
#1837 TDMick
Posted 15 May 2016 - 03:56 pm
Want!
#1838 Blue
Blue
  • 264 posts
Posted 15 May 2016 - 04:13 pm
Mr Henty popped over to remove me rear wheel so I can get the flat sorted. He also took much pleasure in fitting this lovely carbon dash...         attachicon.gifIMG_0201.JPGattachicon.gifIMG_0200.JPG
Noice! :)
'Be as you wish to seem'
#1839 Pantboy
Pantboy
  • 900 posts
Posted 15 May 2016 - 04:50 pm
Fitted a double bubble screen I bought recently from @latestarter
It is currently the only clean part on the bike, but rest assured i shall be working hard to make it as dirty as the rest as fast as I can.
Edited by Pantboy, 15 May 2016 - 04:52 pm.
#1840 Latestarter
Latestarter
  • 676 posts
Posted 15 May 2016 - 07:43 pm
I'm gutted as that screen looks better on your bike than mine ... Enjoy ;)
Want!
Edited by Latestarter, 15 May 2016 - 07:43 pm.
