Hi all. I have just aquired a 1998 850, it has 4tx on the headstock frame. But when I was servicing it, I noticed a 3vd stamped on the engine...
Is this normal? or have I got a second generation bike with a replacement 1st gen engine?
Posted 07 July 2018 - 09:16 am
Posted 07 July 2018 - 09:20 am
Posted 07 July 2018 - 09:22 am
3VD possibly stamped on various parts throughout the bike but the actual engine number , offside by the clutch housing should be 4TX...4TX engine numbers on both my 97 4TX...hth
Edited by Apache, 07 July 2018 - 09:23 am.
Posted 07 July 2018 - 09:23 am
Thx, I'm guessing the original blew up and was replaced...
Can the stock carbs and ecu of the 4tx run the 3vd p&p?
Bike runs ok, but would have expected more grunt
Posted 07 July 2018 - 09:24 am
Posted 07 July 2018 - 09:26 am
Dapleb beat my edit.....
Posted 07 July 2018 - 09:29 am
100% 3vd
Posted 07 July 2018 - 09:33 am
Edited by Apache, 07 July 2018 - 09:37 am.
Posted 07 July 2018 - 09:35 am
And prolly an awful lot more faffing if ya wanted to revert back to a 4TX engine. Unless someone managed to swap out all the internals of a 4TX into 3VD casings.
Best check the ecu see if its for a 3VD or 4TX.
Posted 07 July 2018 - 09:37 am
Posted 07 July 2018 - 09:39 am
Pic shows 3vd...
Edited by slipperyox, 27 July 2018 - 05:01 pm.
Posted 07 July 2018 - 09:42 am
It's a ridiculous long shot but can a 4tx be rebuilt using 3vd casing....lift the tank. 1 coil = 3vd. 2 coils = 4tx
If you remove the tank don't forget to close the additional fuel tap underside of tank.....hth
As far as I know it can be. Only differences between 4tx and 3vd are the crank, the cams and the gearboxes (but even the gear assembl;ies are swappable. So it's possible to build 4tx internals into 3VD casings I would say.
As pointed out how many ignition coils ? a 3vd has just one coil, follow the spark plug leads back to the coil to find out
If you look on ebay for tdm 850 CDI you will see from the photos the different types between a 4tx and a 3vd cdi (ECU) and be able to compare, because one cdi unit can run the other type
Another thing you can do is remove the spark plugs and put a feeler down the spark plug holes. (a plastic straw will do) if one piston is at the top when the other is at the bottom it's a 3vd, But if the left cylinder is at the top and the right cylinder is halfway up it's a 4tx crank
Edited by fixitsan, 07 July 2018 - 09:47 am.
Posted 07 July 2018 - 09:43 am
Interesting, errrr, for us, as it's a 3vd engine with a 4tx oil tank.
Checking the coils wouldn't necessarily reveal anything, someone on here managed to fit 2 coils to a 3vd. ECU is prolly the best indicator.
Edited by fixitsan, 07 July 2018 - 09:44 am.
Posted 07 July 2018 - 09:47 am
can't see for sure but looks like one coil. both HT leads meeting up there somewhere..
ecu is under front left fairing. no idea which it is
Posted 07 July 2018 - 09:49 am
I think you can see the ecu after removing the side panel.
Posted 07 July 2018 - 09:56 am
i suspect it's a complete 3VD engine that has had the 4TX oil tank piggy backed onto it. Dapleb do ya tink the 4TX loom plug would fit directly into the 3VD TCI (ECU) or are they shaped differently? I wonder if the 4TX loom cud be retained and easily adapted to run the 3VD TCI?
Am i roight in saying that alls ya hafta do with regards to the physical differences is to remove that black rubber cover from the rear of the 3VD engine and fit the 4TX oil tank in place of it? Can't be that difficult shirley?
Studs, i have seen a few converted in this manner over the years. Who fitted 2 coils to a 3VD and more to the point are they both actually firing and in use or is it a bull sh** claim and the second coil is merely bolted onto the frame for some strange aesthetic reasons??
Posted 07 July 2018 - 10:00 am
Can't remember who it was Wicky, long time ago. iirc they altered the wiring and had both coils firing, as in wasted spark.
