EMC Shocks
Posted 31 October 2007 - 11:42 pm
Read from some old posts they kinda halfway between Hagon and Ohlins
Verdicts please!
Posted 01 November 2007 - 12:37 pm
Shock options were Nitron / EMC / Hagon all at under £300
Interestingly WP, Penske and Maxton were all MORE expensive than an Ohlins unit (£371.07 compared to £405- £530 for the others, all + VAT!!)
Well thats EMC out I guess, so leaves Nitron and Hagon....
or little extra fer an Ohlins (no no no must resist)
Planned to fit Racetech Springs and Emulators (or Gold valves if I fit MkI Cartridge forks) at the pointy end
Posted 01 November 2007 - 03:11 pm
Don't forget Wilbers shocks. Basic models are under £300 I believe, and I can warmly recommend one. They're built according to rider weight and riding style. Available from KEDO or directly from Wilbers.
Posted 01 November 2007 - 04:16 pm
Ta fer that
Posted 01 November 2007 - 10:33 pm
They come 10mm longer than the OE shock, in order to improve the ride Hagon have told me
(as there is no linkage a la 900)
This DOES affect the seat height AND the angle of lean on the sidestand !
It's only really a problem if :
1. You are vertically challenged (like me)
2. The bike is a bit top heavy, as in fully laden, with tankbag, panniers, topbox, etc. & you put it on the sidestand at the roadside, as it can get precarious.
Hagon will make it shorter if it is a problem to you, & to be fair, they offered to do mine FOC when I pointed it out to them, but do state that performance will be compromised the shorter they make the stroke
The older I get, the better I was96 MkII in yellow & silver with bluespots, braided lines, Remus 2 into 1, Hagon rear shock & fork springs, bashplate, heated grips,Motech pannier racks, Road Attacks, Jockoiler, Baglux tank cover & bag. Gone to a far better place - hasn't it Remo?
Posted 01 November 2007 - 11:09 pm
Well that Hagon out, just cause as far as I'm aware not one other shock manufacturer has had to 'add' 10mm to length to 'improve' the ride, so that a little suspect in my book and I'd queries Hagon on that one
Edited by jht, 01 November 2007 - 11:10 pm.
#8 Guest_Emmett_*
Posted 02 November 2007 - 02:04 am
Posted 02 November 2007 - 11:50 am
#10 Guest_GuyGraham_*
Posted 02 November 2007 - 12:37 pm
The TDM has quite servere ratio of 3:1 due to its linkless desgin
a 10mm longer shock equates to 30mm extra ride height
