LED indicators
Posted 03 October 2007 - 02:55 pm
In the absence of Nitram (last post about a year ago), I have a couple of questions for anyone who has them fitted, and any electronics experts out there.
1 - Presumably you had to fit a different flasher unit rather than having ballancing resistors built in to the indicator unit? Resistors would be the easier option but I'm a bit concerned about the amount of heat they'd have to dump.
2 - Did he use white LED's or where they yellow/amber? I'm thinking the brilliant white ones might be a little too pale for the indicator, though brilliant for the running lights
3 - How many LED's in the array? Dunno how bright indicators are supposed to be but brake lights are supposed to be 60-185 Candela so I reckon with the high intensity jobbies (12-15 Candela) I could get away with 9-12 (calcs suggest series of 3 is best configuration for 14.4 volt) plus a few more set at an angle. A lot of the automotive LED bulbs use 12-19 LEDs but I guess they're not as bright. If I buy in packs of 100 this isn't going to be a big problem though.
Posted 03 October 2007 - 03:07 pm
ps i tink the beemer winkers woiuld fit easily as i looked into doin it.
Edited by wicklamulla, 03 October 2007 - 03:07 pm.
Posted 03 October 2007 - 03:08 pm
but.....an LED rear light has got to be better than the standard mk1, in the rain and spray it was almost impossible to see your rear light, but Rays tiger LED rear lights where as bright as can be
i was looking at these http://cgi.ebay.co.u...em=250170302266
Posted 03 October 2007 - 03:12 pm
reckon they were dimmer than the ordinary 21/5w jobbies when fitted
(tested using my eyeballs at night !!)
still have them somewhere
found these too
http://cgi.ebay.co.u...em=110174207677
Edited by jht, 03 October 2007 - 03:17 pm.
Posted 03 October 2007 - 03:18 pm
Cheers, I'll take a look a the BMW ones
Tony:
I was only thinking of doing the front ones, Wicky's front indicators showed up pretty well, anmd I like the impression of width the running lights gave (thought it might have been due to the cooked breakfasts and mixed grills) I never got close enough behind him to see how well his rear ones work
Having followed you and Martin a few times recently I reckon the LED brake light strip on the givi rack is a good idea, and you've got a good point about upgrading the rear lights, though watch out which bulbs you get. I'm pretty certain the Mk1 uses dual filament jobbies with rear light and brake light in one bulb, not the type you posted. Plus a lot of bikes use spill from the rear light to illuminate the number plate, not sure if the Mk1 has a seperate bulb for that, but if not you need a different type of LED bulb.
jht:
That looks like the unit Wicky and someone else (must have been either Waspy or Avonne) had last weekend.
Edited by ChrisG, 03 October 2007 - 03:20 pm.
Posted 03 October 2007 - 03:39 pm
Posted 03 October 2007 - 03:50 pm
look at the ones fitted to 1150 GS and Rocksters, if ya cud get a set (stalks, wiring etc) from a breaker you'd save a fortune plus they are 'factory produced' not like the home made shoite ones i had to endure as they failed alot.
jht:
That looks like the unit Wicky and someone else (must have been either Waspy or Avonne) had last weekend. yes we both have this set up and i'd be willing to sell the lamp holder/LED assembly minus the clear lens if yer interested, it's quality looking stuff and has the extra LED's pointing downwards fer the number plate illumination, i simply used the LED bulbs that Tony posted a pic of above and it passed the MOT 2 weeks back with this set up no problem.
i may decide to fit clear front winker lenses as that will then clearly show my running lights in white and me indicators in amber, so t'would be easier to distinguish atween the 2, as fer the rear Givi rack ones i have been trying to hunt down clear lenses fer these but nobody seems to sell em, but i have got a stock pair of TDM rear indicators that have been modded like the fronts (red stop/tail led's & amber winker led's) and i could try to fit these with clear lenses to the wingrack, but i'd need to fabricate a bracket of some description i suppose.
http://nippynormans....ts.asp?dept=201
http://nippynormans....e...m=3&mitem=4
http://nippynormans....ts.asp?dept=238
Posted 03 October 2007 - 04:12 pm
WTF? I thought I'd replied to this but it seems to have dissapeared...
Trouble with replacing the indicator bulbs is mose of the LED ones are designed for cars where the bulb faces forewards/backwards. The TDM's bulbs face sideways so the standard car ones won't work.
That shop does sell a high power resistor with built in heatsink that would save changing the relay though.
Nobody seems to be breaking any BMW's on e-bay at the moment. I'll take a look at the indicators on the next GS I see. I have a look at the stock Mk1 indicator tonight to see if there's space to buildsomething like those Nippy Norman jobbies. If I can then get clear lenses (and another indicator 'cos I've only got the left one and my Motrax replacements are a bit too small) I could try LED running lights and amber incandescent bulb, It that doesn't fit I could have a go at building my own full LED setup.
Posted 03 October 2007 - 07:16 pm
Any ideas where I'd get clear indicator lenses for a Mk1? I can see the BMW idea might be easier as there's a lot more accessories for them
Edited by ChrisG, 03 October 2007 - 07:29 pm.
Posted 03 October 2007 - 10:10 pm
Posted 03 October 2007 - 10:21 pm
copy, pasted and checked link is working.
Edited by wicklamulla, 03 October 2007 - 10:21 pm.
Posted 04 October 2007 - 12:15 am
It seems a lot cheaper (depending on shipping though) if you order from the source: http://www.run-n-lit...m/pricelist.asp
Do you know if the GS blinkers and stalks fit on the TDM900 as well? Seems interesting to replace the front with these amber LED runners and the rear with the red LED runners (both with clear lenses and amber bulbs then), although I do like the look of my black blinkers right now...
www.piloot.com
Posted 04 October 2007 - 12:48 am
I like the overall look of your bike e-njoy.
#14 Guest_Mr Whattie_*
Posted 04 October 2007 - 07:01 am
This will then negate the use of two bulbs or a double filament bulb or using "BMW" parts.
Posted 04 October 2007 - 08:20 am
#16 Guest_Favs_*
Posted 04 October 2007 - 08:47 am
Had some LED rear bulbs fer the VFR from a famous local automotive emporium
still have them somewhere.
I'm with you when it comes to the perceived light from the LED units vs the standard set-up - I thought they were so crap I binned them rather than let someone I know be tailgated one night/dusk/evening/dawn or other mid/poor ambient light condition.
As for running-lights come indicators - a great idea, I tried it in the early 80's with my XS850.
#17
Posted 04 October 2007 - 09:19 am
Something that would fit under grabrail
don't think running lights will give same viz
#18
Posted 04 October 2007 - 09:25 am
#19
Posted 05 October 2007 - 07:34 pm
As an example, I ordered a set of Xenons for the Missussessess motor, I got the wrong fog light code. Alan at Ace sent me the new ones within 2 days of me asking, no extra charge & let me keep the wrong 'uns (which fit my car!)
I'm not affiliated in any way to them, just a really satisfied punter who finds a bit of good custy service very welcome indeed!
Dan
1996 TDM850 in Yellow, Motad Nexxus, MK1 bashplate, Acerbis handguards, K&N, Xenons, Aux lamps, Bluespot calipers, Renthal 755 bars, DIY panniers, JBX-inspired gear indicator. (Currently not on the road.)
- Look at Daniel's website, if you can be arsed.
- The mighty Hot Cold Ground, purveyors of quality blues. Featuring 2 Carpedians: Me- lead vocals/guitar: Trevini - guitar
- Daniel's 2010 Nurburgring Trip Blog
- If you like my animated TDM avatar, nick it here:http://danielcarway....X-900-150px.gif. Full-size version: http://danielcarway....3VD-4TX-900.gif
#20
Posted 05 October 2007 - 08:13 pm
I have some red LED bulbs fitted.
I wouldn't say they are a lot brighter, but from a distance it appears there are 2 brake lights; whereas with the ordinary bulbs its like a red 'blob'. I think it looks better with the LEDs fitted though..
Your number plate won't light up like it should do though. Well it will, but in red not white.
Edited by tdmbrightonuk, 05 October 2007 - 08:13 pm.
