Suspension Settings
Posted 20 June 2019 - 08:04 pm
Could somebody please post the standard base settings for front and rear suspension on a 98 850 4tx.
( Front end feels awful so before I start throwing money at it I should at least see what it's like on factory settings )
Many thanks 👍
Posted 23 June 2019 - 05:53 am
Should be a maintenance item, seems like it's a cheap(ish) upgrade in Hungary...
I'm pretty sure I had the first fork oil change done on my '02 9er last week. Bought her this spring.
Same with my 'Zuki a bit earlier...
Posted 23 June 2019 - 08:52 am
Hi mate. Mine's a 900 so can't directly help you, but just to say that full documentation is available here....
http://www.tdm-yamaha.heliohost.org/
Riggers.
Posted 23 June 2019 - 06:33 pm
: Damping turn adjusting screw (hard 0 click out) (standard 4 clicks out) (soft 5 clicks out)
Rear : Preload ( solo lever at S) ( passenger lever at H)
: Damping turn knob (hard 0 click out) ( standard 10 clicks out) (soft 20 clicks out)
Hope this helps
Posted 24 June 2019 - 12:13 pm
Rigger - that link isn't working for me , I'll see if I can find one that works and repost it.
Alan - that's great thank you.
Thanks for all the replies guys.
Posted 24 June 2019 - 12:18 pm
What do you guys use to support the front of the bike if removing the steering assembly?
I've used centre stand and timber blocks under the engine on other bikes but the exhausts don't appear to leave much space for chocking it up
Posted 24 June 2019 - 12:32 pm
Posted 24 June 2019 - 01:25 pm
Stud bar through the front of the engine behind downpipes and axle stand either side, very robust.
Posted 24 June 2019 - 04:10 pm
Dablik - I hadn't thought about using axle stands - nice one !
Thanks guys 👍
Posted 24 June 2019 - 08:33 pm
Christ - I failed to mention mine only has side stand so will have to use paddock stand. I'm not keen on putting all that weight on the pipes, they're fairly old and a bit ropey.
Thanks guys
Whilst Chris is a well respected member on here, I'm not sure he's quite reached that status just yet.
Axle stands work for me.
Posted 24 June 2019 - 08:45 pm
Cool, thanks Studley
Edited by WinstonSmith, 24 June 2019 - 08:47 pm.
Posted 24 June 2019 - 11:27 pm
Posted 27 June 2019 - 01:33 pm
There's always the ladder trick for extra support if you have a paddock stand and trolly jack. Bar and axle stands is probably a better way to support the weight once it's up, but there's no issue with jacking it under the pipes, although I did wedge a bit of wood between the pipes and the engine to take a bit of the load
I found this guide pretty good when playing about with suspension
http://www.gostar-ra...sion_set-up.htm
