Garmin Quest - How to attach it to the TDM
Posted 02 January 2007 - 01:52 pm
Can you help and advise me on the following points:
- is the orginal safe enough that it won't come loose and fall off?
- I have see one from Touratech (expensive) looks a lot safer and stronger, is it?
- do I need an seperate mount to attach it to the bike's handelbar (what do you recommend?) or should I attach it somewhere else?
If I have posted this topic in the wrong section of the forum, my apologies, I am sure it will be moved to the right one.
Thank you to all of you that reply,
Pippobug.
Skype: Pippobug
Posted 02 January 2007 - 02:22 pm
I went down the route of the gen Garmin Bike mount kit, with a RAM mount 1"bar clamp & 3" ext bar.
I think Dandy has the same set up apart from he used the RAMs own quest holder.
http://www.ram-mount...m/ram-b-149.htm
http://www.ram-mount...am-hol-ga15.htm
http://www.gpsw.co.u...s/prod2642.html
heres a few links of the bits I have used and the RAM quest holder Dandy uses, hope this helps.
Edited by TDMTAM, 02 January 2007 - 02:27 pm.
Posted 02 January 2007 - 02:27 pm
Honda SS50
Honda CG125
Honda 250 Super Drean
Honda 751F1
Honda CX500
Kawasaki Z750E
TDM 900
BMW K1200LT (2000)
Nothing to add, has it all.
Kawasaki Z750E (1981)
In bits.
Posted 02 January 2007 - 02:43 pm
Thank you for your answers, but is there another way to attach it with out using a ram mount that come towards you nearly 3in? maybe something one could attach coser to the bars? it just seems to me a bit too far up in the air and not to safe/solid ?!
Skype: Pippobug
Posted 02 January 2007 - 03:51 pm
Sportouring
I have also e-mailed the guy who makes these handlebar clamps, he claims to make a stronger un-engraved version to take a Garmin Quest but I have not had a reply yet.
Edited by Andy K, 02 January 2007 - 04:39 pm.
Posted 02 January 2007 - 06:36 pm
Ram also do a 1 inch arm. Just check out their website, or give em a call.
Fluteplayer
(\__/)
(")0(")
This is Bunny. Copy and paste Bunny into your signature to help her gain world domination
Posted 02 January 2007 - 07:16 pm
Honda SS50
Honda CG125
Honda 751F1
Honda CX500
Kawasaki Z750E
TDM 900
BMW K1200LT (2000)
In bits.
Posted 02 January 2007 - 07:19 pm
BTW There is no vibration or wobbling when fitted using the three inch arm and the thumb screw on the arm makes it easy to adjust.
Ram also make two fittings that fit to the base of the mirror stem but I have not tried them. I do like the idea of mounting one directly to the 'bar clamps but I think it may need to be rubber mounted to cut down on vibration.
2004 Triumph Speed Triple
2006 Honda Dylan (I know but I don't care when it gets dirty, dropped or stolen)
Gone but not forgotten
2006 TDM900A. Airbox mod (thanks JBX), Fuel cans, Safety lights, Garmin GPS,
2003 TDM900. As above.
Posted 02 January 2007 - 10:57 pm
Edited by Sparra, 02 January 2007 - 10:58 pm.
Posted 02 January 2007 - 11:01 pm
To listen to the directions you use a bluetooth earpiece right?
Any rec on a good comfortable one? (With due consideration for the wallet?)
Tanks.
Posted 03 January 2007 - 05:03 pm
when you know where you are going. Sat Navs are great but you will never beat local knowledge.
I would be interested in peoples views on Bluetooth, so far I have not been impressed with the voice quality in carkits, handsfree or PC applications, there may also be problems with battery life.
Posted 03 January 2007 - 07:39 pm
first thing I do when I go touring with the GPS is turn off "off route recalculation". I hate it. And my 2720 automatically zooms out so that the route always stays on screen (when you go off route) and is easy to get back to, even without directions.
I don't like the bluetooth systems, as it adds the burden of keeping the batteries charges. I've hooked the GPS up to my Starcom so I can listen to the directions, listen to my mp3 player and talk to my girlfriend...
Posted 05 January 2007 - 06:27 pm
Edited by Andy K, 05 January 2007 - 06:28 pm.
Posted 06 January 2007 - 05:06 pm
Hi Andy K,
That look exactly what I was looking for . Once they give you and update please let me know, I am interested and will to wait until they have sorted it out. I take it they are developing it for kind off GPS mounts.
Regards, Pippobug.
Skype: Pippobug
Posted 06 January 2007 - 05:54 pm
Oops sorry, forgot to quote
Honda SS50
Honda CG125
Honda 751F1
Honda CX500
Kawasaki Z750E
TDM 900
BMW K1200LT (2000)
In bits.
#16
Posted 06 January 2007 - 06:14 pm
#17
Posted 06 January 2007 - 06:18 pm
I am also considering the option to mount directly on to the front of the plate. This would remove any conflict with the ignition key and probably look cleaner.
#18
Posted 06 January 2007 - 08:34 pm
Are you adding rubber bushings to isolate it from vibrations (ala the TDM handelbar and footpegs)?
#19
Posted 17 January 2007 - 11:56 pm
Pippobug.
I went for the RAM mount too. Including the wee box behind to provide power for the Quest.
RAM-B-149ZA I think
RAM-HOL-GA15
Quest mount
and RAM-QPAC1
the UK RAM web site is SH1TE
the US one much better:
RAM US for complete list of bits
and
the wired box doodah
I don't use the sound lead just glance down now and again
#20 Guest_nils_*
Posted 18 January 2007 - 07:52 am
I've used plastic straps. They are called bundband in Swedish. Anyone knows the English term?
I've used it for over three years and i've never lost the quest (yet).
/Nils
