Gunson Exhaust Tester
Posted 16 June 2012 - 10:31 am
Does anyone know what the proper CO2 etc values should be for a MK2?
http://www.gunson.co...t=698&item=1835
Posted 16 June 2012 - 10:57 am
I can only find the emissions ferra 1999 mk2a Mick.
13.2 CO2 g/km. (CO2 - Carbon dioxide emission)
Have you read the downloadable booklet regarding multiple carb measurin' ?
Posted 17 June 2012 - 09:24 am
Not sure on the 850 but normal to be around 1.50 to 3.00%
Think you start at 2 turns out (Studley?) on yours and tweek in or out to get a smooth tickover.
Posted 17 June 2012 - 11:42 am
Yeah
Looking around the net it seems that 3.8% is the average CO output of a normally tuned engine.
So 3% would be a good target to aim at, judging by the way it's running at the moment (dropping onto 1 cyl at tickover) it's still probably running rich.
Edited by TDMick, 17 June 2012 - 11:43 am.
Posted 17 June 2012 - 01:49 pm
I'm not sure if you'll get the result you want, unless you can measure the CO level for each carb/cylinder Mick.
I tend to set the pilot screws using the throttle blip method, then balance the carbs, then go back to the pilots, and then back to the carb balance. That way I can set for smooth idle and also remove any flat spots up to 3000rpm etc.
Still, be very interested to know how ya get on. Have fun !
Posted 17 June 2012 - 04:18 pm
I've no idea if it will be any help, but the offer was made along with a carb balancing kit, so I thought I'd ask the 'panel'
At least it might give me an idea about whether its running rich or not.
At the moment its refusing to idle on the left cylinder, and won't run properly on both until 2.5-3 k rpm, so I'm suspecting that even chucking a K&N into it hasn't leaned off the mixture any.
Posted 17 June 2012 - 05:41 pm
Down pipes my measuring the co in each pipe via the little blanked of holes
Pipe in one see what it is then pull it out block off the stuff in other and see what it is I think max 5%
Posted 17 June 2012 - 07:39 pm
2>1 exhaust, which is probably part of the problem
Posted 17 June 2012 - 07:59 pm
Did you fit a new fuel pump a short while back Mick ? I might be confuzzlin' you wi' someone else.
I'm thinking that the vac pipe from the pump goes to the no.1 inlet and might be split somewhere, or possibly letting fuel into the inlet if the pump were faulty. Just a thought.
I'd nip over and have a look if you weren't so far from me.
Edited by Studley Ramrod, 17 June 2012 - 07:59 pm.
Posted 17 June 2012 - 10:17 pm
Posted 18 June 2012 - 12:21 am
Studds . yep that was me, I was wondering whether I might have a knackered float valve that was the original cause of the fuel leak, and this might be causing float height issues leading to a richy rich rich mixture on the left hand cylinder?
Posted 18 June 2012 - 10:39 am
Difficult to say for sure Mick, it could be the float height, or the pilot screw adjustment, or a carb balance, or a worn choke plunger.
You're welcome to post me them, I can set the float height and check the plungers and internals etc although you'd still need to adjust the pilots and do a carb balance.
Or, maybe you could try balancing the carbs first, seeing as you've got a tool ferrit.
Posted 19 June 2012 - 12:10 am
Well I got the float valves changed this afternoon ( didn't try and faf around with float heights) and although it still only ticks over on one cylinder, it seems to run healthier.
Picks up onto both cylinders as soon as it revs up to 2.5-2.75K and revs freely
Next task I guess is to play with the pilot screws?
Posted 19 June 2012 - 10:21 am
I've sended you a errrrm, ahhhh, a David Cameron.
#16
Posted 19 June 2012 - 02:54 pm
I'd rather you send me something useful
Edited by TDMick, 19 June 2012 - 02:55 pm.
#17
Posted 19 June 2012 - 04:54 pm
errrr, lol !
How about a Jeremy Hunt !
